<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T]]></title><description><![CDATA[<p dir="auto">1997 Eclipse Spyder GS-T<br />
60,000 Miles - 1300 Miles on Rebuilt / Swap</p>
<p dir="auto">I've spent over a year building this car.  I wanted to do everything right, with the ultimate goal of having it be the Fastest Spyder 4G63 FWD in the world.  But as you all know, it takes a lot of  money to keep and maintain a DSM, and with college, I just can't pull the insurance, car payments, and modding it out anymore.  I wanted to take it to the track this year, but I couldn't bear the thought of breaking something and being stuck without a car for a long time.</p>
<p dir="auto">I just purchased new tires, they are Nexun (made by Toyo, almost exact copies of Proxies).  If you need photos of the tires, let me know I can run out and take pictures of it.</p>
<p dir="auto">The car is in great condition, a few minor cosmetic things are the only issue it has.  First, there is a clear coat spyder behind the drivers door, its very minor, and I didnt want to have the whole quarter panel resprayed, never bothered me.  Scratch on the bottom of the front bumper cover from a curb, can't see it unless your on the ground (passenger side).  Other then that the paint is in awesome condition.  Interior, this car is clean in the inside, only problems is that the on the driver side door, about a 1/4 inch door trim piece is cracked.</p>
<p dir="auto">Car drives strong, surprisingly is very reliable (everything built / rebuilt so no reason why it wouldn't be but hey, its a DSM).  Easily pulls on low 12 second cars on the freeway, with an intake manifold and cams it would would be a low 11 second car.</p>
<p dir="auto">Engine:</p>
<p dir="auto">6 Bolt Full 4G63 Motor Swap / Complete Rebuild<br />
Bored .020 Over<br />
Eagle Rods<br />
Ross Pistons 8.5:1<br />
ARP Head Studs<br />
Metal Headgasket<br />
Balance Shaft Eliminator<br />
1mm Oversized Stainless Steel Valves<br />
1G Intake Manifold</p>
<p dir="auto">Aeromotive Fuel Pressure Regulator<br />
Aeromotive FPR Engine Bay Mounted Gauge<br />
-6AN Stainless Steel Fittings and Hoses<br />
PTE 680cc Injectors<br />
Walbro 255lph High Pressure Fuel Pump</p>
<p dir="auto">Ported 2G Manifold (I also have a Stainless Steel Tubular Manifold, but it cracked, have to send it in for Warranty)<br />
Bullseye Power T04B 50 Trim Turbo<br />
Stainless Steel -AN Oil Return<br />
Stainless Steel -AN Oil Feed<br />
Straightline Specialties 3" Intake<br />
Real K&amp;N Air Filter</p>
<p dir="auto">3" O2 Dump Tube O2 Housing<br />
True 3" Down Pipe<br />
Apex'i 3" Cat-Back</p>
<p dir="auto">Generic Bar and Plate 31x12x3 Intercooler<br />
Straightline Specialties Intercooler Piping<br />
Greddy Type-RS Blow Off Valve</p>
<p dir="auto">Generic Catch Can<br />
Shaved and Polished Valve Cover<br />
Straightline Specialties Boost Controller</p>
<p dir="auto">Transmission:</p>
<p dir="auto">Double Syncro'd 2nd, 3rd, 4th Gears<br />
ACT 2600 Clutch<br />
Evo Shift Forks<br />
Evo Shift Rails<br />
B&amp;M Short Throw Shifter<br />
Greddy Counterweight Shift Knob</p>
<p dir="auto">Electronics:</p>
<p dir="auto">S-AFC II<br />
Straightline Specialties Vent Bezel<br />
Aiwa MP3 Deck<br />
Gen. 2 Reverse Indiglo Gauges<br />
Autometer Ultra Lite A/F Gauge<br />
Autometer Ultra Lite Boost Gauge<br />
Autometer Ultra Lite Oil Pressure Gauge<br />
Lo-Tek Full Replacement 3 Gauge A-Pillar<br />
Dual 6.5" 3-Way Speakers</p>
<p dir="auto">Exterior:</p>
<p dir="auto">Carbon Creations Carbon Fiber OEM Style Hood<br />
Real Sparco Hood Pins<br />
Dual "Real" HID Projector Housings / Headlights<br />
Ace 5 Spoke 17" Rims in Nexun Rubber (less then 500 miles on them)<br />
Replacment Black Convertible Top<br />
Clear Bumper Sidemarkers</p>
<p dir="auto">Suspension:</p>
<p dir="auto">Sparco 1.8" Drop Lowering Springs<br />
New Rotors and Pads</p>
<p dir="auto"><img src="http://www.fargostreet.com/temp/spyder/1.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://www.fargostreet.com/temp/spyder/2.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://www.fargostreet.com/temp/spyder/3.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://www.fargostreet.com/temp/spyder/4.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://www.fargostreet.com/temp/spyder/5.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Photos are before hood pin install.</p>
<p dir="auto">I'm asking $12,000.  I'm also accepting best offer, I need this to sell fast.</p>
<p dir="auto">-James Ross<br />
701-238-2565<br />
<a href="mailto:jameswross2003@yahoo.com" rel="nofollow ugc">jameswross2003@yahoo.com</a><br />
AIM: jameswross2004</p>
]]></description><link>https://fargostreet.com/topic/3767/1997-6-bolt-d-amp-built-spyder-gs-t</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 05:07:14 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/3767.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 23 Aug 2005 03:23:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Thu, 06 Apr 2006 04:12:10 GMT]]></title><description><![CDATA[<p dir="auto">Looks like a really sweet car good luck with the sale!</p>
]]></description><link>https://fargostreet.com/post/97767</link><guid isPermaLink="true">https://fargostreet.com/post/97767</guid><dc:creator><![CDATA[Nutty]]></dc:creator><pubDate>Thu, 06 Apr 2006 04:12:10 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Mon, 30 Jan 2006 16:28:27 GMT]]></title><description><![CDATA[<blockquote>
I have a few things to replace on it (since last fall), but yeah its def. for sale.  If your actually interested in it, I can put an express on actually getting done (wasn't really inspired since I dont drive it in the winter).</p>
<p dir="auto">Car will have fresh Ross Pistons, new Valve Guides and a brand new turbo...</p>
<p dir="auto">Interested?</p>
<p dir="auto">ya i would be interested....no need to put a rush on it just let me know when you would be looking to try to sell it again and we can go from there, just keep me informed on progress. thanks</p>
]]></description><link>https://fargostreet.com/post/90696</link><guid isPermaLink="true">https://fargostreet.com/post/90696</guid><dc:creator><![CDATA[burnteclipse]]></dc:creator><pubDate>Mon, 30 Jan 2006 16:28:27 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Mon, 30 Jan 2006 02:52:55 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">burnteclipse wrote:<br />
still for sale?? i am interested just wondering if it would be a reliable daily driver cuz i wouldnt have any funds to maintain it.  i asked about it when you came to unicel once when i worked there but never heard back from ya....let me know mybe if there is a time to see it....thanks</p>
<p dir="auto">I have a few things to replace on it (since last fall), but yeah its def. for sale.  If your actually interested in it, I can put an express on actually getting done (wasn't really inspired since I dont drive it in the winter).</p>
]]></description><link>https://fargostreet.com/post/90614</link><guid isPermaLink="true">https://fargostreet.com/post/90614</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Mon, 30 Jan 2006 02:52:55 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Mon, 30 Jan 2006 01:38:30 GMT]]></title><description><![CDATA[<p dir="auto">well as with pretty much any modded car there is gonna be stuff to maintain on it...but its got a built motor and tranny so the big things <em>SHOULD</em> be good...</p>
]]></description><link>https://fargostreet.com/post/90588</link><guid isPermaLink="true">https://fargostreet.com/post/90588</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Mon, 30 Jan 2006 01:38:30 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Mon, 30 Jan 2006 01:33:02 GMT]]></title><description><![CDATA[<p dir="auto">still for sale?? i am interested just wondering if it would be a reliable daily driver cuz i wouldnt have any funds to maintain it.  i asked about it when you came to unicel once when i worked there but never heard back from ya....let me know mybe if there is a time to see it....thanks</p>
]]></description><link>https://fargostreet.com/post/90586</link><guid isPermaLink="true">https://fargostreet.com/post/90586</guid><dc:creator><![CDATA[burnteclipse]]></dc:creator><pubDate>Mon, 30 Jan 2006 01:33:02 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Fri, 30 Sep 2005 01:35:54 GMT]]></title><description><![CDATA[<p dir="auto">If you give me time to acquire 10-12k I would be very interested (currenlty at $7500). Whats the insurance like?</p>
]]></description><link>https://fargostreet.com/post/71981</link><guid isPermaLink="true">https://fargostreet.com/post/71981</guid><dc:creator><![CDATA[3_Series]]></dc:creator><pubDate>Fri, 30 Sep 2005 01:35:54 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Thu, 22 Sep 2005 03:44:35 GMT]]></title><description><![CDATA[<p dir="auto">Jim, i think that you put a lot of time and effort not to mention money into that car.  It would really be hard to sell it after just basically completing it.  Even if you do need money for college.  You dam near have a brand new car right now.  Maybe its just me, but i for sure would'nt sell it.  Even if shit happens and you break something, you still have sweet hook-ups to get it fixed somewhat cheap.  Good luck either way whether you sell it or not.</p>
]]></description><link>https://fargostreet.com/post/70323</link><guid isPermaLink="true">https://fargostreet.com/post/70323</guid><dc:creator><![CDATA[Slow97Camaro]]></dc:creator><pubDate>Thu, 22 Sep 2005 03:44:35 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Mon, 12 Sep 2005 07:00:37 GMT]]></title><description><![CDATA[<p dir="auto">well its basically 50 trim turbo..id say 400whp+ on 25psi or so...</p>
]]></description><link>https://fargostreet.com/post/68110</link><guid isPermaLink="true">https://fargostreet.com/post/68110</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Mon, 12 Sep 2005 07:00:37 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Mon, 12 Sep 2005 06:53:37 GMT]]></title><description><![CDATA[<p dir="auto">jim do u have any horsepower numbers? what is insureance on the spyder is it pretty high?</p>
]]></description><link>https://fargostreet.com/post/68106</link><guid isPermaLink="true">https://fargostreet.com/post/68106</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 12 Sep 2005 06:53:37 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Mon, 12 Sep 2005 06:07:07 GMT]]></title><description><![CDATA[<p dir="auto">Very interested just let me sell the stang</p>
]]></description><link>https://fargostreet.com/post/68099</link><guid isPermaLink="true">https://fargostreet.com/post/68099</guid><dc:creator><![CDATA[CivicEX7777777]]></dc:creator><pubDate>Mon, 12 Sep 2005 06:07:07 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Mon, 12 Sep 2005 05:52:25 GMT]]></title><description><![CDATA[<p dir="auto">There's been some people talking shit about my car, and how its going to blow up.</p>
<p dir="auto">All I can say is you must be retarded!</p>
<p dir="auto">New 6-Bolt motor w/ Ross Pistons, Eagle Rods, New Oil Pump, Water Pump, etc etc etc.  1500 miles on the motor.</p>
<p dir="auto">Built / New Transmission.</p>
<p dir="auto">Ok. You guys are really smart...?!? How would it "blow up?"</p>
<p dir="auto">Don't listen to the haters, if your interested in the car, give me a call, get it checked out for yourself.  Apparently there are some people out there who feel it betters themselves to talk smack...</p>
]]></description><link>https://fargostreet.com/post/68097</link><guid isPermaLink="true">https://fargostreet.com/post/68097</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Mon, 12 Sep 2005 05:52:25 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Fri, 26 Aug 2005 05:57:30 GMT]]></title><description><![CDATA[<p dir="auto">good luck.  Sweet car.  Wish I was rich</p>
]]></description><link>https://fargostreet.com/post/64324</link><guid isPermaLink="true">https://fargostreet.com/post/64324</guid><dc:creator><![CDATA[youngin2nr]]></dc:creator><pubDate>Fri, 26 Aug 2005 05:57:30 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Wed, 24 Aug 2005 02:29:28 GMT]]></title><description><![CDATA[<p dir="auto">Yeah i'm negotiable... call me up if you're serious, you can take a look / drive whatever...</p>
<p dir="auto">701-238-2565<br />
or  catch me on AIM:</p>
<p dir="auto">jameswross2004</p>
]]></description><link>https://fargostreet.com/post/63972</link><guid isPermaLink="true">https://fargostreet.com/post/63972</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Wed, 24 Aug 2005 02:29:28 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Wed, 24 Aug 2005 02:01:28 GMT]]></title><description><![CDATA[<p dir="auto">any chance on taking about 10 for it?</p>
]]></description><link>https://fargostreet.com/post/63966</link><guid isPermaLink="true">https://fargostreet.com/post/63966</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Wed, 24 Aug 2005 02:01:28 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Tue, 23 Aug 2005 04:30:47 GMT]]></title><description><![CDATA[<p dir="auto">sweet car, good luck with the sale Jim.</p>
]]></description><link>https://fargostreet.com/post/63853</link><guid isPermaLink="true">https://fargostreet.com/post/63853</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Tue, 23 Aug 2005 04:30:47 GMT</pubDate></item><item><title><![CDATA[Reply to 1997 - 6 Bolt&#x27;d &amp;amp; Built - Spyder GS-T on Tue, 23 Aug 2005 03:50:10 GMT]]></title><description><![CDATA[<p dir="auto">Whore my thread and get banned. That simple.</p>
]]></description><link>https://fargostreet.com/post/63846</link><guid isPermaLink="true">https://fargostreet.com/post/63846</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Tue, 23 Aug 2005 03:50:10 GMT</pubDate></item></channel></rss>
