<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[GRRR, if its not one thing.. 90 Sunbird overheating, help?]]></title><description><![CDATA[<p dir="auto">OK so now my girlfriends car, which we are currently trying to sell, is overheating.  It just started doing this today.  The coolant level is good and doesn't show any signs of oil contamination, and the oil smells like oil, not burnt coolant, so i don't think the headgasket went.  I am thinking maybe the water pump has stopped working, which will require a timing job pretty much to fix.   Is there anything else maybe simpler I could check for? any help is appreciated.  Is there any way to tell if the water pump is bad other that just taking it off and replacing it?  thanks.  yeesh, hopefully this won't take long so I can get the dsm running before too long.</p>
]]></description><link>https://fargostreet.com/topic/3865/grrr-if-its-not-one-thing..-90-sunbird-overheating-help</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 09:03:42 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/3865.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 31 Aug 2005 04:28:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to GRRR, if its not one thing.. 90 Sunbird overheating, help? on Thu, 01 Sep 2005 03:28:38 GMT]]></title><description><![CDATA[<p dir="auto">own3d.<br />
(and fixed)</p>
]]></description><link>https://fargostreet.com/post/65444</link><guid isPermaLink="true">https://fargostreet.com/post/65444</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Thu, 01 Sep 2005 03:28:38 GMT</pubDate></item><item><title><![CDATA[Reply to GRRR, if its not one thing.. 90 Sunbird overheating, help? on Wed, 31 Aug 2005 21:47:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">86fc3s wrote:<br />
81 Eclipse GSX OF DEATH (and broken-ness)</p>
<p dir="auto">it could also be the fact that you claim to have an 81 eclipse. but then again, what do i know? <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":p" alt="😛" /></p>
]]></description><link>https://fargostreet.com/post/65369</link><guid isPermaLink="true">https://fargostreet.com/post/65369</guid><dc:creator><![CDATA[amicheze]]></dc:creator><pubDate>Wed, 31 Aug 2005 21:47:20 GMT</pubDate></item><item><title><![CDATA[Reply to GRRR, if its not one thing.. 90 Sunbird overheating, help? on Wed, 31 Aug 2005 19:16:05 GMT]]></title><description><![CDATA[<p dir="auto">until you fix the fan, you could run the heat at full blast <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":-P" alt="😛" /></p>
]]></description><link>https://fargostreet.com/post/65339</link><guid isPermaLink="true">https://fargostreet.com/post/65339</guid><dc:creator><![CDATA[mym6]]></dc:creator><pubDate>Wed, 31 Aug 2005 19:16:05 GMT</pubDate></item><item><title><![CDATA[Reply to GRRR, if its not one thing.. 90 Sunbird overheating, help? on Wed, 31 Aug 2005 18:17:44 GMT]]></title><description><![CDATA[<p dir="auto">found one culprit.  radiator fan no workee.</p>
]]></description><link>https://fargostreet.com/post/65332</link><guid isPermaLink="true">https://fargostreet.com/post/65332</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Wed, 31 Aug 2005 18:17:44 GMT</pubDate></item><item><title><![CDATA[Reply to GRRR, if its not one thing.. 90 Sunbird overheating, help? on Wed, 31 Aug 2005 15:17:01 GMT]]></title><description><![CDATA[<p dir="auto">Does it overheat only when sitting still or even on the hwy?  If it only overheats while sitting still it could just be the fan.</p>
]]></description><link>https://fargostreet.com/post/65306</link><guid isPermaLink="true">https://fargostreet.com/post/65306</guid><dc:creator><![CDATA[mym6]]></dc:creator><pubDate>Wed, 31 Aug 2005 15:17:01 GMT</pubDate></item><item><title><![CDATA[Reply to GRRR, if its not one thing.. 90 Sunbird overheating, help? on Wed, 31 Aug 2005 12:54:40 GMT]]></title><description><![CDATA[<p dir="auto">Ya, there are way too many things you need to look for in the cooling system, you have to eliminate all of them when you deal with an overheating issue.  Just do it quickly before you ruin the head.</p>
<p dir="auto">Ryan</p>
]]></description><link>https://fargostreet.com/post/65300</link><guid isPermaLink="true">https://fargostreet.com/post/65300</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Wed, 31 Aug 2005 12:54:40 GMT</pubDate></item><item><title><![CDATA[Reply to GRRR, if its not one thing.. 90 Sunbird overheating, help? on Wed, 31 Aug 2005 06:26:17 GMT]]></title><description><![CDATA[<p dir="auto">hey thanks, ill take a look at a couple things in the morning, its a 2.0l 4cyl if that matters.  the shop manual is at my moms place so that doesn't help either.</p>
]]></description><link>https://fargostreet.com/post/65286</link><guid isPermaLink="true">https://fargostreet.com/post/65286</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Wed, 31 Aug 2005 06:26:17 GMT</pubDate></item><item><title><![CDATA[Reply to GRRR, if its not one thing.. 90 Sunbird overheating, help? on Wed, 31 Aug 2005 06:01:33 GMT]]></title><description><![CDATA[<p dir="auto">If your water pump was bad it would be leaking out of the weep hole<br />
Is your thermostat opening<br />
white smoke out of the exhaust<br />
You could pressure test the cooling system<br />
air in the system<br />
just some suggestions and things to look for</p>
]]></description><link>https://fargostreet.com/post/65275</link><guid isPermaLink="true">https://fargostreet.com/post/65275</guid><dc:creator><![CDATA[97lt1]]></dc:creator><pubDate>Wed, 31 Aug 2005 06:01:33 GMT</pubDate></item><item><title><![CDATA[Reply to GRRR, if its not one thing.. 90 Sunbird overheating, help? on Wed, 31 Aug 2005 06:00:25 GMT]]></title><description><![CDATA[<p dir="auto">if it is the 3.1L v-6 look at the intake gasket. it went out on my grand prix and the people at sellands said that that is extremely common on all versions of this motor and usually happens around 100k miles. they quoted me $600. it would over heat just everyonce and a while and then on a cool day it would overheat extremly fast</p>
]]></description><link>https://fargostreet.com/post/65273</link><guid isPermaLink="true">https://fargostreet.com/post/65273</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Wed, 31 Aug 2005 06:00:25 GMT</pubDate></item></channel></rss>
