<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[90-94 dsm 7 bolt flywheel]]></title><description><![CDATA[<p dir="auto">i need a 7 bolt flywheel for one of my budies. it needs to be for a 90-94 non turbo. he has one form a 95 AWD turbo but the his non turbo clucth and there is 1/2 inch of play!! if any body knows of a 7 bolt flywheel for a 90-94 non turbo or if he can buy a 2nd gen clucth assmebly and if it will work i a 1st gen thanks.</p>
]]></description><link>https://fargostreet.com/topic/3969/90-94-dsm-7-bolt-flywheel</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 10:19:24 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/3969.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Sep 2005 03:08:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 90-94 dsm 7 bolt flywheel on Tue, 13 Sep 2005 16:02:32 GMT]]></title><description><![CDATA[<p dir="auto">thanks every body for the info</p>
]]></description><link>https://fargostreet.com/post/68355</link><guid isPermaLink="true">https://fargostreet.com/post/68355</guid><dc:creator><![CDATA[1990TSI]]></dc:creator><pubDate>Tue, 13 Sep 2005 16:02:32 GMT</pubDate></item><item><title><![CDATA[Reply to 90-94 dsm 7 bolt flywheel on Mon, 12 Sep 2005 13:03:00 GMT]]></title><description><![CDATA[<p dir="auto">how much would you sell the flywheel and tranny for, and thanks for the info</p>
]]></description><link>https://fargostreet.com/post/68127</link><guid isPermaLink="true">https://fargostreet.com/post/68127</guid><dc:creator><![CDATA[1990TSI]]></dc:creator><pubDate>Mon, 12 Sep 2005 13:03:00 GMT</pubDate></item><item><title><![CDATA[Reply to 90-94 dsm 7 bolt flywheel on Mon, 12 Sep 2005 05:27:49 GMT]]></title><description><![CDATA[<p dir="auto">First....ALL NTs flywheels are different from the turbos.  The clutches will not work.  NT flywheels have no step to them at all.  The flywheel surface is totally flat.  7-bolts were equipped in the DSMs starting May 1992.  I have a good 7-bolt NT flywheel.  Out of a 93 NT 2.0L.  Also have said tranny as well.  Both worked good until it hit that tree.</p>
<p dir="auto">You can install a Turbo flywheel (FWD or AWD) in a NT car, but they are thicker (due to the step) and would also require a matching turbo tranny to clear the bellhousing.  In other words....unless you feel like swapping in another tranny....find a 2.0L NT 7-bolt flywheel.</p>
<p dir="auto">And also, you can install a AWD flywheel into a FWD tranny, but your starter will not mesh (smaller diameter ring gear for AWD).  And a FWD flywheel will not fit into an AWD bellhousing.</p>
<p dir="auto">Wiz</p>
]]></description><link>https://fargostreet.com/post/68089</link><guid isPermaLink="true">https://fargostreet.com/post/68089</guid><dc:creator><![CDATA[Wizard]]></dc:creator><pubDate>Mon, 12 Sep 2005 05:27:49 GMT</pubDate></item><item><title><![CDATA[Reply to 90-94 dsm 7 bolt flywheel on Sun, 11 Sep 2005 22:59:46 GMT]]></title><description><![CDATA[<p dir="auto">I think the fwd flywheels are 12 inch's tall and the awd flywheels are 11.5 inch's tall</p>
]]></description><link>https://fargostreet.com/post/67941</link><guid isPermaLink="true">https://fargostreet.com/post/67941</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Sun, 11 Sep 2005 22:59:46 GMT</pubDate></item><item><title><![CDATA[Reply to 90-94 dsm 7 bolt flywheel on Sun, 11 Sep 2005 22:40:27 GMT]]></title><description><![CDATA[<p dir="auto">The FWD parts are the same, but you can't switch AWD and FWD flywheels.  This is assuming you have a 2.0 NT motor, if it's a 1.8, I have no idea.</p>
]]></description><link>https://fargostreet.com/post/67930</link><guid isPermaLink="true">https://fargostreet.com/post/67930</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Sun, 11 Sep 2005 22:40:27 GMT</pubDate></item><item><title><![CDATA[Reply to 90-94 dsm 7 bolt flywheel on Sat, 10 Sep 2005 19:49:56 GMT]]></title><description><![CDATA[<p dir="auto">but is the turbo flywheel different. and can you use a turbo clucth assembly (flywheel, clucth, pressure plate) on a non turbo thats what i need to know if there is any thing different between the turbo and non turbo flywheel, clucth, pressure plate i know the turbo flywheel and clucth are bigger but can you use the turbo setup in a non turbo?   because the non turbo clucth and pressure plate will go on but there is like 1/2 inch of play in the clucth ( up and down whise)</p>
]]></description><link>https://fargostreet.com/post/67756</link><guid isPermaLink="true">https://fargostreet.com/post/67756</guid><dc:creator><![CDATA[1990TSI]]></dc:creator><pubDate>Sat, 10 Sep 2005 19:49:56 GMT</pubDate></item><item><title><![CDATA[Reply to 90-94 dsm 7 bolt flywheel on Fri, 09 Sep 2005 00:30:33 GMT]]></title><description><![CDATA[<p dir="auto">Josh, if there's a 7 bolt flywheel in there.... Someone's done a swap. Guaranteed. And the clutch is the same for a 6 or 7 bolt anyway.</p>
]]></description><link>https://fargostreet.com/post/67378</link><guid isPermaLink="true">https://fargostreet.com/post/67378</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Fri, 09 Sep 2005 00:30:33 GMT</pubDate></item><item><title><![CDATA[Reply to 90-94 dsm 7 bolt flywheel on Fri, 09 Sep 2005 00:24:33 GMT]]></title><description><![CDATA[<p dir="auto">No 90 0r 91 came 7 bolt.  If it has a 7 bolt in it, someone previously swapped it. Clutches from 90-99 all fit.</p>
]]></description><link>https://fargostreet.com/post/67376</link><guid isPermaLink="true">https://fargostreet.com/post/67376</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Fri, 09 Sep 2005 00:24:33 GMT</pubDate></item><item><title><![CDATA[Reply to 90-94 dsm 7 bolt flywheel on Thu, 08 Sep 2005 23:55:32 GMT]]></title><description><![CDATA[<p dir="auto">some 90's came 7 bolt that is what came out of the car and he put in his 91 eclipse. but there is 2 kinds of turbo 7 bolt flywheels one is thicker then the other. so would the thicker 2nd gen clucth work in a first gen.</p>
]]></description><link>https://fargostreet.com/post/67369</link><guid isPermaLink="true">https://fargostreet.com/post/67369</guid><dc:creator><![CDATA[1990TSI]]></dc:creator><pubDate>Thu, 08 Sep 2005 23:55:32 GMT</pubDate></item><item><title><![CDATA[Reply to 90-94 dsm 7 bolt flywheel on Thu, 08 Sep 2005 03:16:12 GMT]]></title><description><![CDATA[<p dir="auto">I thought that they were 6 bolt up until 92.5 I believe.  So I am guessing that a flywheel from any DSM from 92.5 and up would work.</p>
]]></description><link>https://fargostreet.com/post/67133</link><guid isPermaLink="true">https://fargostreet.com/post/67133</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 08 Sep 2005 03:16:12 GMT</pubDate></item></channel></rss>
