<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[problems with msd ignition]]></title><description><![CDATA[<p dir="auto">I pulled out my msd ignition box to remount it better. Like a dumbass, I forgot exactly were some of the wires reconnected to, the two grounds, and hooked them up to were I thought they were supposed to go, either way around and the car turns over but doesn't start. So I went to msd's website and got the wiring instructions to make sure everthing was in the right place then went back and double checked all the connections and made sure they were all in the right place, so that part is good. So now I go to start my car and it still doesn't start, turn over though, so I went and checked fuses, there all good, went to start again, same result. All I can think of is that there's some bad connections from the distributor to the box or from the box to the coil, which is also an msd blaster 2. Everthing worked just fine before I disconnected the box and took it out. I'm hoping it's not the box or the coil that's messed up, I can't afford a new box right now. What do you guys think is the problem. I need help. <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f615.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--confused" style="height:23px;width:auto;vertical-align:middle" title=":confused:" alt="😕" /></p>
]]></description><link>https://fargostreet.com/topic/4160/problems-with-msd-ignition</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 16:23:48 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/4160.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Sep 2005 01:10:40 GMT</pubDate><ttl>60</ttl></channel></rss>
