<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Hub Removal]]></title><description><![CDATA[<p dir="auto">I am trying to get the hub off my DSM, so i can replace the CV shaft.  I have been beating on it for hours and it wont budge, i have beat on the nut on the front, and i have even beat on the back of it with a sledge hammer. It seems it is almost welded to the axle. Any suggestions or help, i have soaked the shit out of it with penetrating lube. I know there are a lot of dsmer's on here so i figured someone could help me out. Thanks in advance</p>
]]></description><link>https://fargostreet.com/topic/4180/hub-removal</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 14:39:43 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/4180.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Sep 2005 20:20:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Hub Removal on Tue, 27 Sep 2005 20:40:18 GMT]]></title><description><![CDATA[<p dir="auto">Make sure you are letting them know it's for an AWD, Driver's side with equal length system.</p>
<p dir="auto">Advance #6751 with ABS or #7927 w/o ABS.  $80 for the axle minus core charge.</p>
<p dir="auto">Wiz</p>
]]></description><link>https://fargostreet.com/post/71471</link><guid isPermaLink="true">https://fargostreet.com/post/71471</guid><dc:creator><![CDATA[Wizard]]></dc:creator><pubDate>Tue, 27 Sep 2005 20:40:18 GMT</pubDate></item><item><title><![CDATA[Reply to Hub Removal on Mon, 26 Sep 2005 02:24:32 GMT]]></title><description><![CDATA[<p dir="auto">well i am in grand forks, so i will try car quest here</p>
]]></description><link>https://fargostreet.com/post/71020</link><guid isPermaLink="true">https://fargostreet.com/post/71020</guid><dc:creator><![CDATA[awd95mn]]></dc:creator><pubDate>Mon, 26 Sep 2005 02:24:32 GMT</pubDate></item><item><title><![CDATA[Reply to Hub Removal on Mon, 26 Sep 2005 00:26:04 GMT]]></title><description><![CDATA[<p dir="auto">I just got one of those axles from M&amp;J (Carquest) on main.  They got the right one the first time, and it was only $50 after the core.</p>
]]></description><link>https://fargostreet.com/post/70993</link><guid isPermaLink="true">https://fargostreet.com/post/70993</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Mon, 26 Sep 2005 00:26:04 GMT</pubDate></item><item><title><![CDATA[Reply to Hub Removal on Sun, 25 Sep 2005 22:29:08 GMT]]></title><description><![CDATA[<p dir="auto">its the drivers side front</p>
]]></description><link>https://fargostreet.com/post/70965</link><guid isPermaLink="true">https://fargostreet.com/post/70965</guid><dc:creator><![CDATA[awd95mn]]></dc:creator><pubDate>Sun, 25 Sep 2005 22:29:08 GMT</pubDate></item><item><title><![CDATA[Reply to Hub Removal on Sun, 25 Sep 2005 22:17:27 GMT]]></title><description><![CDATA[<p dir="auto">um I have had about 5 different ones sent to me... try advanced auto parts which one do you need im sure i can look on a car to get the part number..</p>
]]></description><link>https://fargostreet.com/post/70964</link><guid isPermaLink="true">https://fargostreet.com/post/70964</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Sun, 25 Sep 2005 22:17:27 GMT</pubDate></item><item><title><![CDATA[Reply to Hub Removal on Sun, 25 Sep 2005 22:11:14 GMT]]></title><description><![CDATA[<p dir="auto">ok i went to about 5 different auto parts stores trying to get this damn thing, they all want to sell me a cv shaft with 2 male ends, mine connects to the inner shaft with a female end, is this right?  i need one with abs, and for an awd, with 5 speed, any one know a part # that might be able to help me out? I have the oem one, but no one is able to cross reference it.(mr145597) I am really pissed right now.</p>
]]></description><link>https://fargostreet.com/post/70962</link><guid isPermaLink="true">https://fargostreet.com/post/70962</guid><dc:creator><![CDATA[awd95mn]]></dc:creator><pubDate>Sun, 25 Sep 2005 22:11:14 GMT</pubDate></item><item><title><![CDATA[Reply to Hub Removal on Sun, 25 Sep 2005 02:42:06 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">awd95mn wrote:<br />
well i got it off, i used a big 3 prong puller, it took a lot of force to get it off, cant put the new axle in, because damn napa gave me the wrong one, thanks for the help</p>
<p dir="auto">napa is good at that..</p>
]]></description><link>https://fargostreet.com/post/70853</link><guid isPermaLink="true">https://fargostreet.com/post/70853</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Sun, 25 Sep 2005 02:42:06 GMT</pubDate></item><item><title><![CDATA[Reply to Hub Removal on Sun, 25 Sep 2005 02:20:02 GMT]]></title><description><![CDATA[<p dir="auto">well i got it off, i used a big 3 prong puller, it took a lot of force to get it off, cant put the new axle in, because damn napa gave me the wrong one, thanks for the help</p>
]]></description><link>https://fargostreet.com/post/70850</link><guid isPermaLink="true">https://fargostreet.com/post/70850</guid><dc:creator><![CDATA[awd95mn]]></dc:creator><pubDate>Sun, 25 Sep 2005 02:20:02 GMT</pubDate></item><item><title><![CDATA[Reply to Hub Removal on Sun, 25 Sep 2005 00:10:46 GMT]]></title><description><![CDATA[<p dir="auto">well id get a puller, that would work much better than a hammer, you will just mushroom the axle if you hammer too much, also try a blow torch to heat the axle up! I had the same problem on many 2g's so take my word and get a puller</p>
]]></description><link>https://fargostreet.com/post/70837</link><guid isPermaLink="true">https://fargostreet.com/post/70837</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Sun, 25 Sep 2005 00:10:46 GMT</pubDate></item><item><title><![CDATA[Reply to Hub Removal on Sat, 24 Sep 2005 22:31:11 GMT]]></title><description><![CDATA[<p dir="auto">Yeah have fun w/ that one.  You'll probably have to pull the whole spindle off of the car and have the axle pressed out.  Or if you can find the special tool made for doing axles, use that.  It is sort of like a pulley puller, but it bolts onto 3 of the wheel studs, and then has the bolt thing in the middle and it will turn in to push the axle out.  After all of this, don't be surprised if you need a new wheel bearing.</p>
]]></description><link>https://fargostreet.com/post/70815</link><guid isPermaLink="true">https://fargostreet.com/post/70815</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Sat, 24 Sep 2005 22:31:11 GMT</pubDate></item></channel></rss>
