<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Civic EG Wire tuck&#x2F;engine bay cleanup]]></title><description><![CDATA[<p dir="auto">I dont know if this would be considered a mod or not but i got this off HT for when i do a wire tuck(if i get the motivation)  Also this is steps for an EG only, other civics will be different(wiring will need to be shortened)</p>
<p dir="auto">This is what i removed<br />
Ripped out the AC system. pump, condenser, lines ect. everythings gotta come out.<br />
Heat shields on the exhaust manifold<br />
intake resonator</p>
<p dir="auto">Wiring that was re routed. No wires were shortened or lenghtened. when extending or shortening wiring you can effect the resistance in that line. and could affect how your engine performs</p>
<p dir="auto">Passanger side Headlight, horn, turn signal, ground box harness was taken and ran in the inner fenderwell gound box was hooked up to the 10mm bolt that held on the intake resonator.</p>
<p dir="auto">Driver side headlight turn signal ground box harness was ran through the fenderwell and held up with a open 10mm spot by the windshield washer fluid resivoir.</p>
<p dir="auto">Distributor wiring was taken off the clip and hide under the intake manifold</p>
<p dir="auto">Driver side harness was removed and tucked underneath the battery/fuse box. and no i did not extend any of the wiring.</p>
<p dir="auto">Passanger side harness was removed off the clips and tucked in the corner under the Slave cylinder and zip tied down</p>
<p dir="auto">Fuel injector wiring. the box was removed off of the injector harness. the heat shrink was removed off of the wires. becareful doing this not to cut the wires. and the clips were ran up through the gaps in the intake manifold runners.</p>
<p dir="auto">Cleaning<br />
removed battery and covered all electronics.... dizzy, alternator, Harness clips with bags and zip tied them.<br />
Sprayed the entire engine bay, engine, firewall with simple green 75 SG/25 H20. let it sit for 5-10 mins and rinsed off with garden hose. dry the engine bay with shop towels or shop rags.</p>
<p dir="auto">i used 2 cans of gunk for the engine and transmission for the heavy grease. do the same steps as i did with simple green.</p>
]]></description><link>https://fargostreet.com/topic/4434/civic-eg-wire-tuck-engine-bay-cleanup</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 23:55:01 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/4434.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Oct 2005 20:25:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Civic EG Wire tuck&#x2F;engine bay cleanup on Mon, 23 Jul 2007 16:45:45 GMT]]></title><description><![CDATA[<p dir="auto">Back From The Dead ...very Nice</p>
]]></description><link>https://fargostreet.com/post/167712</link><guid isPermaLink="true">https://fargostreet.com/post/167712</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Mon, 23 Jul 2007 16:45:45 GMT</pubDate></item><item><title><![CDATA[Reply to Civic EG Wire tuck&#x2F;engine bay cleanup on Sun, 22 Jul 2007 00:40:35 GMT]]></title><description><![CDATA[<p dir="auto">you dont happen to have any b4 n after pics of that</p>
]]></description><link>https://fargostreet.com/post/167611</link><guid isPermaLink="true">https://fargostreet.com/post/167611</guid><dc:creator><![CDATA[CRX_Civic]]></dc:creator><pubDate>Sun, 22 Jul 2007 00:40:35 GMT</pubDate></item><item><title><![CDATA[Reply to Civic EG Wire tuck&#x2F;engine bay cleanup on Mon, 06 Mar 2006 15:45:52 GMT]]></title><description><![CDATA[<p dir="auto">I was just wondering if anyone had an exact write up on what to do, I know I can probably figure it out, but if somone else already has done it, I would be more comfortable with extending/shortening wires and what not.</p>
]]></description><link>https://fargostreet.com/post/94679</link><guid isPermaLink="true">https://fargostreet.com/post/94679</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Mon, 06 Mar 2006 15:45:52 GMT</pubDate></item><item><title><![CDATA[Reply to Civic EG Wire tuck&#x2F;engine bay cleanup on Mon, 06 Mar 2006 15:12:59 GMT]]></title><description><![CDATA[<p dir="auto">It's not very difficult...</p>
]]></description><link>https://fargostreet.com/post/94677</link><guid isPermaLink="true">https://fargostreet.com/post/94677</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 06 Mar 2006 15:12:59 GMT</pubDate></item><item><title><![CDATA[Reply to Civic EG Wire tuck&#x2F;engine bay cleanup on Mon, 06 Mar 2006 14:38:28 GMT]]></title><description><![CDATA[<p dir="auto">anyone find a DIY b series EK wire tuck? I need one! I checked all over and can't find a good description.</p>
]]></description><link>https://fargostreet.com/post/94674</link><guid isPermaLink="true">https://fargostreet.com/post/94674</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Mon, 06 Mar 2006 14:38:28 GMT</pubDate></item><item><title><![CDATA[Reply to Civic EG Wire tuck&#x2F;engine bay cleanup on Tue, 20 Dec 2005 19:21:34 GMT]]></title><description><![CDATA[<p dir="auto">Damn I got all excited to see your Civic again... I need to do a photo shoot of that car.</p>
]]></description><link>https://fargostreet.com/post/86083</link><guid isPermaLink="true">https://fargostreet.com/post/86083</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Tue, 20 Dec 2005 19:21:34 GMT</pubDate></item><item><title><![CDATA[Reply to Civic EG Wire tuck&#x2F;engine bay cleanup on Tue, 20 Dec 2005 04:28:22 GMT]]></title><description><![CDATA[<p dir="auto">naw just checking out the site seeing how everybody is,,,frezzing there ass off lololololol</p>
]]></description><link>https://fargostreet.com/post/86036</link><guid isPermaLink="true">https://fargostreet.com/post/86036</guid><dc:creator><![CDATA[4ornia]]></dc:creator><pubDate>Tue, 20 Dec 2005 04:28:22 GMT</pubDate></item><item><title><![CDATA[Reply to Civic EG Wire tuck&#x2F;engine bay cleanup on Sun, 18 Dec 2005 02:45:35 GMT]]></title><description><![CDATA[<p dir="auto">Jerry, what the hell your back???</p>
]]></description><link>https://fargostreet.com/post/85896</link><guid isPermaLink="true">https://fargostreet.com/post/85896</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Sun, 18 Dec 2005 02:45:35 GMT</pubDate></item><item><title><![CDATA[Reply to Civic EG Wire tuck&#x2F;engine bay cleanup on Sun, 18 Dec 2005 00:44:34 GMT]]></title><description><![CDATA[<p dir="auto">hahah harwood i seen a eg civic with this done, you can lengthen or shorten certain wires with no effects? trust me i did a few. but props for trying it yourself and not getting someone to do it for you</p>
]]></description><link>https://fargostreet.com/post/85889</link><guid isPermaLink="true">https://fargostreet.com/post/85889</guid><dc:creator><![CDATA[4ornia]]></dc:creator><pubDate>Sun, 18 Dec 2005 00:44:34 GMT</pubDate></item></channel></rss>
