<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[6 Denso Iridium plugs - IK 24]]></title><description><![CDATA[<p dir="auto">I have 6 used Iridium spark plugs for sale.  I had them in my Supra for around 500 miles.  They are not fouled at all and are great plugs - pretty common on high hp Supra's that typically go through plugs every 3k, these last much longer.</p>
<p dir="auto">These plugs are 2 ranges colder than stock. (IK24)</p>
<p dir="auto">$12 per plug new, asking $50 for the 6 of them</p>
<hr />
<p dir="auto">Some information on these plugs:</p>
<h2>Q. What makes Iridium better?<br />
A. Until recently, platinum was considered the best material to use on the top of an electrode because of its durability. However, Iridium is 6 times harder, 8 times stronger, and has a melting point 1200 degrees higher than platinum. Put that into a harsh environment such as an engine piston chamber, and you have a spark plug that can resist wear much better than platinum. Additionally, the DENSO Iridium Power alloy is so durable; it allowed our engineers to produce the world’s smallest center electrode (.4mm) which reduces the voltage requirements, concentrating its sparking power. Also, its smaller size, combined with the tapered U-Groove ground electrode, allows more room for the flame kernel to develop and produce a more efficient combustion.<br />
(from <a href="http://www.densoiridium.com/faq.php" rel="nofollow ugc">http://www.densoiridium.com/faq.php</a>)</h2>
<h2>A "cold plug" has a shorter insulator nose, which minimizes the amount of surface area exposed to the combustion gases. Cold plugs are typically used in racing conditions because of its ability to transfer heat out of the cylinder chamber quickly. Most turbo, supercharged and nitrous oxide applications use this type of plug because of the tremendous heat they generate. A colder plug can also minimize the risk of pre-ignition and detonation, however if the plug is to cold there is risk of fouling during extended periods of idling and low-speed operation.<br />
(from <a href="http://www.densoiridium.com/heatranges.php" rel="nofollow ugc">http://www.densoiridium.com/heatranges.php</a>)</h2>
]]></description><link>https://fargostreet.com/topic/4827/6-denso-iridium-plugs-ik-24</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 22:59:25 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/4827.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Nov 2005 23:06:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 6 Denso Iridium plugs - IK 24 on Fri, 18 Nov 2005 14:26:04 GMT]]></title><description><![CDATA[<p dir="auto">sold</p>
]]></description><link>https://fargostreet.com/post/81104</link><guid isPermaLink="true">https://fargostreet.com/post/81104</guid><dc:creator><![CDATA[Dangler]]></dc:creator><pubDate>Fri, 18 Nov 2005 14:26:04 GMT</pubDate></item></channel></rss>
