<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[KLZE Probe owners]]></title><description><![CDATA[<p dir="auto">Would it be worth it/possible to use an autotragic with a KLZE?<br />
When you buy the KLZE does the stock Probe tranny fit it?<br />
What would be the best bang for the buck computer with the KLZE and do you need to dyno tune it or can you do it in your garage?</p>
]]></description><link>https://fargostreet.com/topic/4869/klze-probe-owners</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 04:43:51 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/4869.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Nov 2005 04:22:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to KLZE Probe owners on Fri, 25 Nov 2005 01:24:18 GMT]]></title><description><![CDATA[<p dir="auto">Sorry here is a better one.  I posted the wrong one.</p>
<p dir="auto"><a href="http://www.mx6.com/forums/showthread.php?t=28967" rel="nofollow ugc">http://www.mx6.com/forums/showthread.php?t=28967</a></p>
]]></description><link>https://fargostreet.com/post/82212</link><guid isPermaLink="true">https://fargostreet.com/post/82212</guid><dc:creator><![CDATA[2slo50h]]></dc:creator><pubDate>Fri, 25 Nov 2005 01:24:18 GMT</pubDate></item><item><title><![CDATA[Reply to KLZE Probe owners on Fri, 25 Nov 2005 01:16:59 GMT]]></title><description><![CDATA[<p dir="auto">I think it would be kind of a headache.</p>
<p dir="auto">Here is a good forum for you to read through.</p>
<p dir="auto">Mx6 forum same principal <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
<p dir="auto"><a href="http://www.mx6.com/forums/showthread.php?t=84188" rel="nofollow ugc">http://www.mx6.com/forums/showthread.php?t=84188</a></p>
]]></description><link>https://fargostreet.com/post/82211</link><guid isPermaLink="true">https://fargostreet.com/post/82211</guid><dc:creator><![CDATA[2slo50h]]></dc:creator><pubDate>Fri, 25 Nov 2005 01:16:59 GMT</pubDate></item><item><title><![CDATA[Reply to KLZE Probe owners on Thu, 24 Nov 2005 19:38:47 GMT]]></title><description><![CDATA[<p dir="auto">hum.... what about using a SE instead of a GT.  I know the motor mounts and Electrical wouldn't be the same.  How bad would that get?</p>
]]></description><link>https://fargostreet.com/post/82135</link><guid isPermaLink="true">https://fargostreet.com/post/82135</guid><dc:creator><![CDATA[barthygt]]></dc:creator><pubDate>Thu, 24 Nov 2005 19:38:47 GMT</pubDate></item><item><title><![CDATA[Reply to KLZE Probe owners on Thu, 24 Nov 2005 02:49:06 GMT]]></title><description><![CDATA[<p dir="auto">I've never done an auto-manual tranny swap. I know you have to swap the pedal assemblies, change axles, install the clutch hydraulic parts, and more.</p>
]]></description><link>https://fargostreet.com/post/82026</link><guid isPermaLink="true">https://fargostreet.com/post/82026</guid><dc:creator><![CDATA[pin]]></dc:creator><pubDate>Thu, 24 Nov 2005 02:49:06 GMT</pubDate></item><item><title><![CDATA[Reply to KLZE Probe owners on Wed, 23 Nov 2005 23:43:15 GMT]]></title><description><![CDATA[<p dir="auto">thanks a lot.  I'm just asking cuz I found a nice GT Probe, but it's an auto.  If I would buy it how hard/or pricy would it be to swap in a manual tranny sence I could get the KLZE motor, tranny, and ECU.</p>
]]></description><link>https://fargostreet.com/post/82008</link><guid isPermaLink="true">https://fargostreet.com/post/82008</guid><dc:creator><![CDATA[barthygt]]></dc:creator><pubDate>Wed, 23 Nov 2005 23:43:15 GMT</pubDate></item><item><title><![CDATA[Reply to KLZE Probe owners on Wed, 23 Nov 2005 08:47:23 GMT]]></title><description><![CDATA[<p dir="auto">It depends. It's been done, but the one guy I have in mind was a diehard automatic guy. If you intended to do any drag racing you might want to check out Level 10. <a href="http://www.levelten.com/store/ford/packages/parts_probe.htm" rel="nofollow ugc">http://www.levelten.com/store/ford/packages/parts_probe.htm</a></p>
]]></description><link>https://fargostreet.com/post/81903</link><guid isPermaLink="true">https://fargostreet.com/post/81903</guid><dc:creator><![CDATA[pin]]></dc:creator><pubDate>Wed, 23 Nov 2005 08:47:23 GMT</pubDate></item><item><title><![CDATA[Reply to KLZE Probe owners on Wed, 23 Nov 2005 03:54:09 GMT]]></title><description><![CDATA[<p dir="auto">would it be a waste of time putting a KLZE and an auto-tragic together or would it still have good power?</p>
]]></description><link>https://fargostreet.com/post/81817</link><guid isPermaLink="true">https://fargostreet.com/post/81817</guid><dc:creator><![CDATA[barthygt]]></dc:creator><pubDate>Wed, 23 Nov 2005 03:54:09 GMT</pubDate></item><item><title><![CDATA[Reply to KLZE Probe owners on Mon, 21 Nov 2005 06:09:31 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">barthygt wrote:<br />
Would it be worth it/possible to use an autotragic with a KLZE?</p>
<p dir="auto">It's possible. The KLZE only came with an automatic tranny in Japan. I believe it's quite comparable to the US-spec automatic tranny.</p>
<p dir="auto">What would be the best bang for the buck computer with the KLZE and do you need to dyno tune it or can you do it in your garage?</p>
<p dir="auto">The cheapo way is to use the stock US-spec ECU and combine that with an adjustable fuel pressure regulator and bump the pressure up a bit. This won't be optimal for power output by any means. The KLZE ECU can be ordered from <a href="www.corksport.com">www.corksport.com</a>, and it will have the correct VRIS activation RPM points. The best way for maximizing the power band on the ZE is to switch over to a Megasquirt standalone and either dyno tune it or do a good road tune.</p>
]]></description><link>https://fargostreet.com/post/81455</link><guid isPermaLink="true">https://fargostreet.com/post/81455</guid><dc:creator><![CDATA[pin]]></dc:creator><pubDate>Mon, 21 Nov 2005 06:09:31 GMT</pubDate></item></channel></rss>
