<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clutch install]]></title><description><![CDATA[<p dir="auto">How hard is it to install a new clutch in my 97 Civic CX?  Is it something that can be accomplished on the driveway in a day?</p>
<p dir="auto">thanks in advance</p>
]]></description><link>https://fargostreet.com/topic/494/clutch-install</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 17:36:59 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/494.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Sep 2004 17:47:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clutch install on Wed, 06 Oct 2004 07:31:45 GMT]]></title><description><![CDATA[<p dir="auto">you should also probably have ground your flywheel... .02</p>
]]></description><link>https://fargostreet.com/post/7595</link><guid isPermaLink="true">https://fargostreet.com/post/7595</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Wed, 06 Oct 2004 07:31:45 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch install on Wed, 06 Oct 2004 05:27:51 GMT]]></title><description><![CDATA[<p dir="auto">First of all bleed the clutch so that you're sure there's no air in the system.  And second of all, yes you more than likely did buy a POS clutch.  Any parts store like that sells clutches that have no holding power because they're cheap and people supposedly like them for the light pedal feel.  I've done a couple of Carquest clutches in cars and I won't ever even waste my time doing it again.  You're so much better off just buying a cheap ACT, Exedy, or something similar.</p>
]]></description><link>https://fargostreet.com/post/7576</link><guid isPermaLink="true">https://fargostreet.com/post/7576</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Wed, 06 Oct 2004 05:27:51 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch install on Tue, 05 Oct 2004 21:10:17 GMT]]></title><description><![CDATA[<p dir="auto">I just picked one up from Bumper to Bumper.  New not reman: pressure plate, clutch disc, throwout bearing, and pilot bearing.  I did not have the flywheel ground, could that be a problem or did I just spend an entire day putting in a shitty clutch.</p>
]]></description><link>https://fargostreet.com/post/7498</link><guid isPermaLink="true">https://fargostreet.com/post/7498</guid><dc:creator><![CDATA[Schwanger]]></dc:creator><pubDate>Tue, 05 Oct 2004 21:10:17 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch install on Tue, 05 Oct 2004 20:59:52 GMT]]></title><description><![CDATA[<p dir="auto">What kind of clutch did you get...and did you get a new clutch, flywheel everytihng?</p>
]]></description><link>https://fargostreet.com/post/7493</link><guid isPermaLink="true">https://fargostreet.com/post/7493</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 05 Oct 2004 20:59:52 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch install on Tue, 05 Oct 2004 20:35:51 GMT]]></title><description><![CDATA[<p dir="auto">Well I put my new clutch in on Saturday.  It wasn't too bad, it just took sometime to get everything apart.  The only problem now is that the clutch pedal takes almost no effort push, is this because of the pressure plate.  Any thoughts?</p>
]]></description><link>https://fargostreet.com/post/7491</link><guid isPermaLink="true">https://fargostreet.com/post/7491</guid><dc:creator><![CDATA[Schwanger]]></dc:creator><pubDate>Tue, 05 Oct 2004 20:35:51 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch install on Tue, 28 Sep 2004 15:53:58 GMT]]></title><description><![CDATA[<p dir="auto">Schwanger I'd be willing to do it for around $250.  It's not too bad.</p>
]]></description><link>https://fargostreet.com/post/6488</link><guid isPermaLink="true">https://fargostreet.com/post/6488</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Tue, 28 Sep 2004 15:53:58 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch install on Mon, 27 Sep 2004 21:00:42 GMT]]></title><description><![CDATA[<p dir="auto">It's not that hard, but just make sure you know what your doing.</p>
<p dir="auto"><a href="www.Honda-tech.com">www.Honda-tech.com</a> has a ton of information on this topic, just seach for: Clutch install.</p>
]]></description><link>https://fargostreet.com/post/6422</link><guid isPermaLink="true">https://fargostreet.com/post/6422</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Mon, 27 Sep 2004 21:00:42 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch install on Mon, 27 Sep 2004 20:49:26 GMT]]></title><description><![CDATA[<p dir="auto">I have the tools and the know how but if it's a major pain the ass I would just rather take it somewhere.  I've put clutches in other vehicles but none were FWD.</p>
]]></description><link>https://fargostreet.com/post/6421</link><guid isPermaLink="true">https://fargostreet.com/post/6421</guid><dc:creator><![CDATA[Schwanger]]></dc:creator><pubDate>Mon, 27 Sep 2004 20:49:26 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch install on Mon, 27 Sep 2004 20:33:58 GMT]]></title><description><![CDATA[<p dir="auto">Personally i think its really easy but thats just me.</p>
]]></description><link>https://fargostreet.com/post/6419</link><guid isPermaLink="true">https://fargostreet.com/post/6419</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 27 Sep 2004 20:33:58 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch install on Mon, 27 Sep 2004 20:28:52 GMT]]></title><description><![CDATA[<ol>
<li>You <strong>HAVE</strong> to know what your doing.</li>
<li>You have to have the tools.</li>
<li>If I rember right with a 97 civic you cannot just jack up the side of the engine you have to take part way out.</li>
</ol>
<p dir="auto">P.s. If you asking us if you should or can, you should not do it yourself.</p>
]]></description><link>https://fargostreet.com/post/6418</link><guid isPermaLink="true">https://fargostreet.com/post/6418</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Mon, 27 Sep 2004 20:28:52 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch install on Mon, 27 Sep 2004 18:08:02 GMT]]></title><description><![CDATA[<p dir="auto">Sure if you know what your doing, have the right tools and have a lift to hold the tranny up with. You dont want to let it hang on the input shaft - you'll bend it and cause more problems than its worth..</p>
<p dir="auto">I would just take it in.. For 250-300, its almost worth the money to have her done with a lift and power tools...</p>
]]></description><link>https://fargostreet.com/post/6407</link><guid isPermaLink="true">https://fargostreet.com/post/6407</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 27 Sep 2004 18:08:02 GMT</pubDate></item></channel></rss>
