<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Honda help...]]></title><description><![CDATA[<p dir="auto">So, I figured I would help my mom out since she got screwed over by Corwin, long story, but she needed a new engine in her 1999 Accord.  So, I get an engine with 24000 miles on it, swap parts over, put it in her car.  I am having a hell of a time getting it to run correctly.  When I hit the gas at all it just wants to bog like it is running out of fuel or something.  Compression is at 175 psi across the board, fuel pressure is at about 75 psi, swapped distributors multiple times (so I assume spark is good), swapped throttle body with MAP and TPS sensor.  The car starts right up, idles, but as soon as I try to rev it up at all it falls on its face.</p>
<p dir="auto">Anyone has any ideas, I am sick of pulling my hair out. :mad:   This was supposed to be easy money!!! heh</p>
]]></description><link>https://fargostreet.com/topic/5088/honda-help...</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 06:31:15 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/5088.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 11 Dec 2005 23:44:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Honda help... on Mon, 12 Dec 2005 02:15:29 GMT]]></title><description><![CDATA[<p dir="auto">his nickname isnt a honda car for no reason...</p>
]]></description><link>https://fargostreet.com/post/84917</link><guid isPermaLink="true">https://fargostreet.com/post/84917</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Mon, 12 Dec 2005 02:15:29 GMT</pubDate></item><item><title><![CDATA[Reply to Honda help... on Mon, 12 Dec 2005 02:05:40 GMT]]></title><description><![CDATA[<p dir="auto">wow, I didn't suspect that, ill keep that in mind.  Good Job, and good luck with the newer engine.</p>
<p dir="auto">Ry</p>
]]></description><link>https://fargostreet.com/post/84914</link><guid isPermaLink="true">https://fargostreet.com/post/84914</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Mon, 12 Dec 2005 02:05:40 GMT</pubDate></item><item><title><![CDATA[Reply to Honda help... on Mon, 12 Dec 2005 01:46:02 GMT]]></title><description><![CDATA[<p dir="auto">Thanks GSR!!!  Like I said guys, I had checked everything.... I guess I never thought an automaker would make two plugs the same for two important sensors that are right next to each other!!!  Damn Honda.</p>
<p dir="auto">Thanks GSR, you ended my depression.</p>
]]></description><link>https://fargostreet.com/post/84911</link><guid isPermaLink="true">https://fargostreet.com/post/84911</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Mon, 12 Dec 2005 01:46:02 GMT</pubDate></item><item><title><![CDATA[Reply to Honda help... on Mon, 12 Dec 2005 00:50:14 GMT]]></title><description><![CDATA[<p dir="auto">Just swap the plugs for the map and TPS sensor around.</p>
]]></description><link>https://fargostreet.com/post/84908</link><guid isPermaLink="true">https://fargostreet.com/post/84908</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 12 Dec 2005 00:50:14 GMT</pubDate></item><item><title><![CDATA[Reply to Honda help... on Mon, 12 Dec 2005 00:35:30 GMT]]></title><description><![CDATA[<p dir="auto">i dont think that this will effect anything, but that fuel pressure seems awefully high.  If you are desperate, bring it by my buddies shop that I work at, we can figure it out for you.</p>
<p dir="auto">West Fargo Car Clinic<br />
100 West Main<br />
West Fargo<br />
701-277-7288</p>
]]></description><link>https://fargostreet.com/post/84905</link><guid isPermaLink="true">https://fargostreet.com/post/84905</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Mon, 12 Dec 2005 00:35:30 GMT</pubDate></item><item><title><![CDATA[Reply to Honda help... on Mon, 12 Dec 2005 00:17:53 GMT]]></title><description><![CDATA[<p dir="auto">how is the altrenator in it???? i know you might be thinking what the fuck are you talking about.....but in the 99 accords for some reason when the alt. is fucked up......everything is fucked up.....</p>
<p dir="auto">happened to a friend of mine and he just replaced the alt..and now it runs fine again.</p>
<p dir="auto">although he has the 3.0v6.....if thats what engine ur talking about.</p>
]]></description><link>https://fargostreet.com/post/84902</link><guid isPermaLink="true">https://fargostreet.com/post/84902</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 12 Dec 2005 00:17:53 GMT</pubDate></item></channel></rss>
