<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Corrosions on battery]]></title><description><![CDATA[<p dir="auto">How can I remove corrosions on my battery post?  I have tried cleaning it with baking soda, but it doesn't work.  Thanks</p>
]]></description><link>https://fargostreet.com/topic/5253/corrosions-on-battery</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 09:18:40 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/5253.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Jan 2006 05:23:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Corrosions on battery on Wed, 04 Jan 2006 04:47:22 GMT]]></title><description><![CDATA[<p dir="auto">get anticorrosion rings. Can be bought anywhere that sells car stuff for 2 bucks.</p>
]]></description><link>https://fargostreet.com/post/87135</link><guid isPermaLink="true">https://fargostreet.com/post/87135</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 04 Jan 2006 04:47:22 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Tue, 03 Jan 2006 08:27:31 GMT]]></title><description><![CDATA[<p dir="auto">I had a problem with corrosion on my battery terminals for years. I had my car in the shop at an Interstate Battery store when they determined it was bad, and they installed felt washers along with the new battery. I've had no corrosion problem at all since then. Those washers are less than $3.</p>
]]></description><link>https://fargostreet.com/post/87065</link><guid isPermaLink="true">https://fargostreet.com/post/87065</guid><dc:creator><![CDATA[pin]]></dc:creator><pubDate>Tue, 03 Jan 2006 08:27:31 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Tue, 03 Jan 2006 07:25:05 GMT]]></title><description><![CDATA[<p dir="auto">wd-40 and then coat it with vaseline to protect it.</p>
]]></description><link>https://fargostreet.com/post/87063</link><guid isPermaLink="true">https://fargostreet.com/post/87063</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 03 Jan 2006 07:25:05 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Tue, 03 Jan 2006 06:43:00 GMT]]></title><description><![CDATA[<p dir="auto">i posted</p>
]]></description><link>https://fargostreet.com/post/87062</link><guid isPermaLink="true">https://fargostreet.com/post/87062</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Tue, 03 Jan 2006 06:43:00 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Tue, 03 Jan 2006 06:18:37 GMT]]></title><description><![CDATA[<p dir="auto">I said Degreaser and a pressure washer enough said............... NO one needs to post !!</p>
<p dir="auto">Why pour pop on it ? then it will get sticky.. Do what I said..</p>
]]></description><link>https://fargostreet.com/post/87049</link><guid isPermaLink="true">https://fargostreet.com/post/87049</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Tue, 03 Jan 2006 06:18:37 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Tue, 03 Jan 2006 05:16:15 GMT]]></title><description><![CDATA[<p dir="auto">Mythbusters yesterday covered this....soda and water was far superior to Coca Cola for removing the deposits, however the only way to get them "clean" was with a wire brush or a terminal cleaner.</p>
]]></description><link>https://fargostreet.com/post/87032</link><guid isPermaLink="true">https://fargostreet.com/post/87032</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 03 Jan 2006 05:16:15 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Mon, 02 Jan 2006 18:43:42 GMT]]></title><description><![CDATA[<p dir="auto">degreaser and a battery post cleaner, coke only works as good as water, but it also attracts ants. <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /> I asked a master tech this same question this past summer.</p>
]]></description><link>https://fargostreet.com/post/86975</link><guid isPermaLink="true">https://fargostreet.com/post/86975</guid><dc:creator><![CDATA[darkelvis]]></dc:creator><pubDate>Mon, 02 Jan 2006 18:43:42 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Mon, 02 Jan 2006 09:13:23 GMT]]></title><description><![CDATA[<p dir="auto">didnt mr miller teach you anything?</p>
]]></description><link>https://fargostreet.com/post/86957</link><guid isPermaLink="true">https://fargostreet.com/post/86957</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Mon, 02 Jan 2006 09:13:23 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Mon, 02 Jan 2006 08:44:44 GMT]]></title><description><![CDATA[<p dir="auto">tin baking soda doesnt get rid of the corrosion it just neutralizes the acid...</p>
]]></description><link>https://fargostreet.com/post/86956</link><guid isPermaLink="true">https://fargostreet.com/post/86956</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Mon, 02 Jan 2006 08:44:44 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Mon, 02 Jan 2006 08:12:23 GMT]]></title><description><![CDATA[<p dir="auto">I heard that if you get it really wet, and then hold on to the ground while you lick the postive post it zaps it right off...</p>
]]></description><link>https://fargostreet.com/post/86955</link><guid isPermaLink="true">https://fargostreet.com/post/86955</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Mon, 02 Jan 2006 08:12:23 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Mon, 02 Jan 2006 07:31:39 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">torbs wrote:<br />
that's the way i was taught too haha</p>
<p dir="auto">GHETTO, i guess is our middle name huh? <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://fargostreet.com/post/86954</link><guid isPermaLink="true">https://fargostreet.com/post/86954</guid><dc:creator><![CDATA[itRfan]]></dc:creator><pubDate>Mon, 02 Jan 2006 07:31:39 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Mon, 02 Jan 2006 07:30:21 GMT]]></title><description><![CDATA[<p dir="auto">coke works, wire brush works also..</p>
]]></description><link>https://fargostreet.com/post/86953</link><guid isPermaLink="true">https://fargostreet.com/post/86953</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Mon, 02 Jan 2006 07:30:21 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Mon, 02 Jan 2006 07:22:04 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">itrfan wrote:<br />
it may sound carzy, but my dads old mechanic told him the way to get rid of "corrosion" on a battery is to use COCA COLA i guess it eats it right up, i did it on my old battery in my sable and it worked pretty good, kinda ghetto but it's a thought <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":p" alt="😛" /></p>
<p dir="auto">that's the way i was taught too haha</p>
]]></description><link>https://fargostreet.com/post/86950</link><guid isPermaLink="true">https://fargostreet.com/post/86950</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Mon, 02 Jan 2006 07:22:04 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Mon, 02 Jan 2006 05:42:56 GMT]]></title><description><![CDATA[<p dir="auto">it may sound carzy, but my dads old mechanic told him the way to get rid of "corrosion" on a battery is to use COCA COLA i guess it eats it right up, i did it on my old battery in my sable and it worked pretty good, kinda ghetto but it's a thought <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":p" alt="😛" /></p>
]]></description><link>https://fargostreet.com/post/86938</link><guid isPermaLink="true">https://fargostreet.com/post/86938</guid><dc:creator><![CDATA[itRfan]]></dc:creator><pubDate>Mon, 02 Jan 2006 05:42:56 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Mon, 02 Jan 2006 05:41:17 GMT]]></title><description><![CDATA[<p dir="auto">Go to a car wash and degrease it and spray it off..</p>
]]></description><link>https://fargostreet.com/post/86937</link><guid isPermaLink="true">https://fargostreet.com/post/86937</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Mon, 02 Jan 2006 05:41:17 GMT</pubDate></item><item><title><![CDATA[Reply to Corrosions on battery on Mon, 02 Jan 2006 05:27:23 GMT]]></title><description><![CDATA[<p dir="auto">Use a battery post/terminal cleaner brush.   Like the wire brush that fits over the battery post and spin it.  IT WORKS PERFECT</p>
<p dir="auto">Here is a link to one if you are not sure what Im talking about:<br />
<a href="http://www.toolprice.com/product/8292B" rel="nofollow ugc">http://www.toolprice.com/product/8292B</a></p>
]]></description><link>https://fargostreet.com/post/86935</link><guid isPermaLink="true">https://fargostreet.com/post/86935</guid><dc:creator><![CDATA[krzydrftr93]]></dc:creator><pubDate>Mon, 02 Jan 2006 05:27:23 GMT</pubDate></item></channel></rss>
