<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[tube frame 4 sale]]></title><description><![CDATA[<p dir="auto">Any one intrested???</p>
<p dir="auto">All parts from <a href="http://SWracecars.com" rel="nofollow ugc">SWracecars.com</a></p>
<p dir="auto">All New</p>
<p dir="auto">24'' 4 Link Frame  Paid $610.45<br />
Lazer Link RodEnd EndPackage $290.00<br />
Track  bars 56.65<br />
Lazer Link 151.95<br />
Shock Spring Mount Kit 95# Spring 179.95<br />
Frame A-Arm Rails Pinto Type, Rack X-member, Shock Support 450.00<br />
A -Arms Upper w Hardwear 185.75<br />
A-arms Lower  239.75<br />
Pinto Tie Rod End Kit 44.95<br />
Rack Mount Kit 19.95<br />
Ball Joint For Pinto Front A-arm Pacakge 79.80<br />
Fabricated Pintos Spindle Left and Right side  400.00<br />
10 pt Front subframe support kit  converts 10 pt to 12 pt. 45.00<br />
Wilwood Rack Pinion 240.00<br />
Hal Corp Alum Coil over shock 2.25 inch Travel  360.00<br />
Coil Over spring 250 lbs 77.00<br />
Wheels tires 250.00</p>
<p dir="auto">Plus a 1991 Mitsubishi Eclipse</p>
<p dir="auto">Make Offer</p>
]]></description><link>https://fargostreet.com/topic/5303/tube-frame-4-sale</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 12:16:54 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/5303.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Jan 2006 08:03:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to tube frame 4 sale on Fri, 07 Apr 2006 21:33:57 GMT]]></title><description><![CDATA[<p dir="auto">what size r the wire wheels and whats the bolt pattern?</p>
]]></description><link>https://fargostreet.com/post/98005</link><guid isPermaLink="true">https://fargostreet.com/post/98005</guid><dc:creator><![CDATA[onebadass383]]></dc:creator><pubDate>Fri, 07 Apr 2006 21:33:57 GMT</pubDate></item><item><title><![CDATA[Reply to tube frame 4 sale on Fri, 07 Apr 2006 14:02:29 GMT]]></title><description><![CDATA[<p dir="auto">bump<br />
bymp</p>
]]></description><link>https://fargostreet.com/post/97948</link><guid isPermaLink="true">https://fargostreet.com/post/97948</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Fri, 07 Apr 2006 14:02:29 GMT</pubDate></item></channel></rss>
