<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fuel line question]]></title><description><![CDATA[<p dir="auto">What is the biggest AN-XX fitting end can I get with a 3/4" ORB on the other side??</p>
]]></description><link>https://fargostreet.com/topic/5514/fuel-line-question</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 10:01:21 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/5514.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Jan 2006 23:16:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fuel line question on Mon, 22 Oct 2007 01:40:11 GMT]]></title><description><![CDATA[<p dir="auto">well that is just wrong. jeez why have a bad ass car you cannot drive?</p>
<p dir="auto">Monty</p>
]]></description><link>https://fargostreet.com/post/180363</link><guid isPermaLink="true">https://fargostreet.com/post/180363</guid><dc:creator><![CDATA[musthavemuzk]]></dc:creator><pubDate>Mon, 22 Oct 2007 01:40:11 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Sun, 21 Oct 2007 18:48:13 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">musthavemuzk;191094 wrote:<br />
i cannot imagine that much fuel or pressure. bet it is fun as hell to drive though.</p>
<p dir="auto">I wouldn't know:mad:  Andy won't let me drive my own car</p>
]]></description><link>https://fargostreet.com/post/180320</link><guid isPermaLink="true">https://fargostreet.com/post/180320</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Sun, 21 Oct 2007 18:48:13 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Sun, 21 Oct 2007 16:43:02 GMT]]></title><description><![CDATA[<p dir="auto">i cannot imagine that much fuel or pressure. bet it is fun as hell to drive though.</p>
]]></description><link>https://fargostreet.com/post/180310</link><guid isPermaLink="true">https://fargostreet.com/post/180310</guid><dc:creator><![CDATA[musthavemuzk]]></dc:creator><pubDate>Sun, 21 Oct 2007 16:43:02 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Sun, 21 Oct 2007 09:03:28 GMT]]></title><description><![CDATA[<p dir="auto">Latest update if anyone cares. I had to run Dave's little pump and my little one together. I had to run another -10 feed line to the front of the motor. A pair of -10 now. We were a little concerned about dead heading the pumps through a single regulator with -8 to the tank. Anyways the lowest we could get the fuel pressure to was 80-85 pounds. We then set it up for mine to run at idle and the second to come on right before the pull on the dyno. That didn't work so well, wanted to load up on too much fuel. Anyways Dave came to the rescue again as he pulled his regulator off late Friday night for me in case it worked better. I thought we were going to have to run two regs. We swapped out to Dave's reg turned on both pumps, 40 lbs. no problem. Set base pressure at 60 and made a few pulls.<br />
Normally at end of pull I see about 150 mph. on the last pull same rpm only saw 115 mph. I wonder what is happening now:3gears: I think we are done don't want to push it any further. Need to clean the car and add some more timing into it for SEMA</p>
]]></description><link>https://fargostreet.com/post/180304</link><guid isPermaLink="true">https://fargostreet.com/post/180304</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Sun, 21 Oct 2007 09:03:28 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Sat, 20 Oct 2007 04:49:50 GMT]]></title><description><![CDATA[<p dir="auto">Guess we are going to try Dave's and my pump together. We'll see</p>
]]></description><link>https://fargostreet.com/post/180142</link><guid isPermaLink="true">https://fargostreet.com/post/180142</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Sat, 20 Oct 2007 04:49:50 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Fri, 19 Oct 2007 07:47:05 GMT]]></title><description><![CDATA[<p dir="auto">I guess the -10 feed line is not big enough. Need some new -12 line from the pump to the rails.</p>
<p dir="auto">Dave, thanx for pulling your pump to try, but it still did the same.  We set the base fuel pressure to 90 psi, and it still dropped off, left the boost reference line off. I need about 12+ inches per side for rails. I am going to cut off my existing fittings and have some -12's welded on, mine are just over 5/8". Got into Fargo at about 2:30 AM <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":(" alt="😞" /></p>
]]></description><link>https://fargostreet.com/post/179975</link><guid isPermaLink="true">https://fargostreet.com/post/179975</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Fri, 19 Oct 2007 07:47:05 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Mon, 30 Jan 2006 19:02:26 GMT]]></title><description><![CDATA[<p dir="auto">How about  a head scoop</p>
]]></description><link>https://fargostreet.com/post/90722</link><guid isPermaLink="true">https://fargostreet.com/post/90722</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Mon, 30 Jan 2006 19:02:26 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Mon, 30 Jan 2006 18:29:45 GMT]]></title><description><![CDATA[<p dir="auto">He's kindof skinny though.  Just get a bigger cowl.</p>
]]></description><link>https://fargostreet.com/post/90713</link><guid isPermaLink="true">https://fargostreet.com/post/90713</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 30 Jan 2006 18:29:45 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Mon, 30 Jan 2006 16:19:43 GMT]]></title><description><![CDATA[<blockquote>
I think andy probably has some ball valves that would work....</p>
<p dir="auto">"on ..... offf ..... on ... off" oh fuck out of gas.</p>
<p dir="auto">I may have to check with him on that. Thing is, I will need some sort of inj. driver for that route and I do not think Andy will fit under the hood very well.</p>
]]></description><link>https://fargostreet.com/post/90694</link><guid isPermaLink="true">https://fargostreet.com/post/90694</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Mon, 30 Jan 2006 16:19:43 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Mon, 30 Jan 2006 14:32:43 GMT]]></title><description><![CDATA[<p dir="auto">I think andy probably has some ball valves that would work....</p>
]]></description><link>https://fargostreet.com/post/90681</link><guid isPermaLink="true">https://fargostreet.com/post/90681</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 30 Jan 2006 14:32:43 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Mon, 30 Jan 2006 14:07:17 GMT]]></title><description><![CDATA[<blockquote>
Sounds to me like a sprinkler system of some sort is being plumbed hahaha.</p>
<p dir="auto">Another thing I am going to be looking for is larger sprinkler heads, I need alot more liquid for this new application..<br />
This is running off a well that pumps 840#/hour @60 psi. Most of you guys would tell me 4-6 heads would be enough but I say fuck-it lets do it with 8</p>
]]></description><link>https://fargostreet.com/post/90679</link><guid isPermaLink="true">https://fargostreet.com/post/90679</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Mon, 30 Jan 2006 14:07:17 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Mon, 30 Jan 2006 07:58:23 GMT]]></title><description><![CDATA[<p dir="auto">Sounds to me like a sprinkler system of some sort is being plumbed hahaha.</p>
]]></description><link>https://fargostreet.com/post/90668</link><guid isPermaLink="true">https://fargostreet.com/post/90668</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 30 Jan 2006 07:58:23 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Mon, 30 Jan 2006 01:43:18 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Fargo wrote:<br />
By the way thanx FARGOSTREET for the help</p>
<p dir="auto">no prob.</p>
]]></description><link>https://fargostreet.com/post/90589</link><guid isPermaLink="true">https://fargostreet.com/post/90589</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Mon, 30 Jan 2006 01:43:18 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Mon, 30 Jan 2006 01:02:43 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">DaveH wrote:<br />
I'm not sure what ORB is?<br />
O-Ring Boss, I guess that is old school</p>
<p dir="auto">dynotune wrote:<br />
They have 90s and stuff, too- but nothing over 3/4 that I can find.  Why are you working on your outdoor sprinkler system this time of year???    <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /><br />
It is not for the sprinkler system this time.  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
<p dir="auto">By the way thanx FARGOSTREET for the help</p>
<p dir="auto">EAR-985012ERL $17.88<br />
Estimated Ship Date:  Monday</p>
<p dir="auto">Brand: Earl's Performance Plumbing<br />
Product Line: Earl's Performance AN Port Adapters<br />
Fitting Attachment 1: Male threads<br />
Fitting Size 1: -12 AN<br />
Fitting Attachment 2: Male threads<br />
Fitting Size 2: -12 AN O-ring<br />
Fitting Angle: Straight<br />
Fitting Finish: Blue anodized<br />
Fitting Material: Aluminum<br />
O-Ring Material: Rubber<br />
Quantity: Sold individually.</p>
<p dir="auto">Fitting, Straight, Male -12 AN to Straight Cut Male -12 AN O-Ring, Aluminum, Blue, Each</p>
<p dir="auto">Special purpose adapters.<br />
Earl's Performance special purpose adapters are manufactured from an aluminum alloy which meets and exceeds the minimum requirements for aerospace fittings. They're precision-machined to exacting tolerances for trouble-free and long lasting performance, and feature a contoured port end for maximum flow.</p>
<p dir="auto">Back to Search Results</p>
<p dir="auto"><img src="http://static.summitracing.com/global/images/prod/norm/ear-985081erl_w_m.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/90579</link><guid isPermaLink="true">https://fargostreet.com/post/90579</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Mon, 30 Jan 2006 01:02:43 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Mon, 30 Jan 2006 00:20:39 GMT]]></title><description><![CDATA[<p dir="auto">They have 90s and stuff, too- but nothing over 3/4 that I can find.  Why are you working on your outdoor sprinkler system this time of year???    <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://fargostreet.com/post/90577</link><guid isPermaLink="true">https://fargostreet.com/post/90577</guid><dc:creator><![CDATA[dynotune]]></dc:creator><pubDate>Mon, 30 Jan 2006 00:20:39 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Mon, 30 Jan 2006 00:16:11 GMT]]></title><description><![CDATA[<p dir="auto"><a href="www.summitracing.com">www.summitracing.com</a></p>
<p dir="auto">MEZ-WP12034B<br />
maybe what you need??</p>
]]></description><link>https://fargostreet.com/post/90576</link><guid isPermaLink="true">https://fargostreet.com/post/90576</guid><dc:creator><![CDATA[dynotune]]></dc:creator><pubDate>Mon, 30 Jan 2006 00:16:11 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Mon, 30 Jan 2006 00:00:43 GMT]]></title><description><![CDATA[<p dir="auto">geez dave, yer dumb.  An ORB is what the genie looks into to see your future.<br />
Psshhttt.... ROOKIES.</p>
]]></description><link>https://fargostreet.com/post/90575</link><guid isPermaLink="true">https://fargostreet.com/post/90575</guid><dc:creator><![CDATA[dynotune]]></dc:creator><pubDate>Mon, 30 Jan 2006 00:00:43 GMT</pubDate></item><item><title><![CDATA[Reply to Fuel line question on Sun, 29 Jan 2006 23:50:25 GMT]]></title><description><![CDATA[<p dir="auto">I'm not sure what ORB is?</p>
<p dir="auto">-12 AN is 3/4" ID if that helps.</p>
]]></description><link>https://fargostreet.com/post/90574</link><guid isPermaLink="true">https://fargostreet.com/post/90574</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Sun, 29 Jan 2006 23:50:25 GMT</pubDate></item></channel></rss>
