<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tein Flex with EDFC setup for sale-honda]]></title><description><![CDATA[<p dir="auto">for sale-<br />
selling a setup of tein flex w/edfc that was on a 93 civic ex i beleive will fit 88-00.... used for less than 1k .... please buy this asap.... heres some specs....</p>
<p dir="auto">:: Spring Rate Front: 9/504 (kgf/mm, lbs/in)<br />
:: Spring Rate Rear: 5/280 (kgf/mm, lbs/in)</p>
<p dir="auto">:: Ride Height Front: -25(mm),-1(inch)<br />
:: Ride Height Rear: -35(mm),-1.4(inch)</p>
<p dir="auto">:: Adjust Range:<br />
:: Ride Height Front: -19(mm),-0.7(inch) ~ -69(mm),-2.7(inch)<br />
:: Ride Height Rear: -2(mm),-0.1(inch) ~ -68(mm),-2.7(inch)</p>
<p dir="auto">-Full-length adjustment and height adjustment for separate setting of the height and spring preload.</p>
<p dir="auto">-16 levels of damping force adjustment (compression and rebound together).</p>
<p dir="auto">-Teflon coating for rust prevention.</p>
<p dir="auto">-Newly designed spring seat and spring seat lock for easy height adjusting.</p>
<p dir="auto">someone please buy these asap, im asking 1200.... they go for 1500 new on ebay and these have only had 1k miles on them!!!!!!</p>
]]></description><link>https://fargostreet.com/topic/5541/tein-flex-with-edfc-setup-for-sale-honda</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 22:59:40 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/5541.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Feb 2006 04:51:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Mon, 20 Feb 2006 02:01:54 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">LT1 wrote:<br />
what all cars does this fit</p>
<p dir="auto">88-00 civics<br />
ef, eg, ek, eh, ed, ej, em<br />
90-01 integras<br />
dc2, dc4, db, 1990+ da</p>
<p dir="auto">I'm positive itll fit:<br />
eg, ej, em, eh, ek, dc2, dc4</p>
<p dir="auto">....the others may be different slightly and there might be others, havn't actually looked at them that closely.  All I know is that Honda didn't change the suspension design for many years.....and in 01 when they went to the Macpherson struts in the civics is when they had problems with them leaking very early on.  Actually had some TSB/Recalls i believe.  The older design was perfect in long lasting, most of them lasted a good 100K miles or more before needing replacement.  now the new 06 civics have a new suspension with torsion bars in the rear.  Me not happy.</p>
]]></description><link>https://fargostreet.com/post/93259</link><guid isPermaLink="true">https://fargostreet.com/post/93259</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Mon, 20 Feb 2006 02:01:54 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Mon, 20 Feb 2006 01:39:50 GMT]]></title><description><![CDATA[<blockquote>
are you sure eg, and ek have the same suspension?</p>
<p dir="auto">88-00 civics and integras had the same suspension style, just different spring and shock rates.  01-05 civics and 02+ rsx have similar suspensions too.  Everything bolts up, but have different ride qualities due to handling tuning and vehicle weights.</p>
<p dir="auto">Ry</p>
]]></description><link>https://fargostreet.com/post/93258</link><guid isPermaLink="true">https://fargostreet.com/post/93258</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Mon, 20 Feb 2006 01:39:50 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Sun, 19 Feb 2006 23:19:21 GMT]]></title><description><![CDATA[<p dir="auto">Sold to me, thanks Asa.</p>
]]></description><link>https://fargostreet.com/post/93254</link><guid isPermaLink="true">https://fargostreet.com/post/93254</guid><dc:creator><![CDATA[seanjohn]]></dc:creator><pubDate>Sun, 19 Feb 2006 23:19:21 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Sun, 19 Feb 2006 20:19:07 GMT]]></title><description><![CDATA[<p dir="auto">what all cars does this fit</p>
]]></description><link>https://fargostreet.com/post/93245</link><guid isPermaLink="true">https://fargostreet.com/post/93245</guid><dc:creator><![CDATA[LT1]]></dc:creator><pubDate>Sun, 19 Feb 2006 20:19:07 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Sun, 19 Feb 2006 20:00:37 GMT]]></title><description><![CDATA[<p dir="auto">EF, eg and ek!</p>
]]></description><link>https://fargostreet.com/post/93240</link><guid isPermaLink="true">https://fargostreet.com/post/93240</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Sun, 19 Feb 2006 20:00:37 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Sun, 19 Feb 2006 00:07:36 GMT]]></title><description><![CDATA[<p dir="auto">are you sure eg, and ek have the same suspension?</p>
]]></description><link>https://fargostreet.com/post/93197</link><guid isPermaLink="true">https://fargostreet.com/post/93197</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Sun, 19 Feb 2006 00:07:36 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Sat, 18 Feb 2006 21:01:16 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">bipedbear wrote:<br />
final price-lowest ill go is 700, someone buy this shit<br />
Very interested in your suspension. Let me check my money status and pm you back later tonight. Just letting you know someone is interested.<br />
-Joel</p>
]]></description><link>https://fargostreet.com/post/93187</link><guid isPermaLink="true">https://fargostreet.com/post/93187</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Sat, 18 Feb 2006 21:01:16 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Fri, 17 Feb 2006 14:33:51 GMT]]></title><description><![CDATA[<p dir="auto">this will fit those years integras too.  Just will have different spring rates.</p>
<p dir="auto">ry</p>
]]></description><link>https://fargostreet.com/post/93123</link><guid isPermaLink="true">https://fargostreet.com/post/93123</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Fri, 17 Feb 2006 14:33:51 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Fri, 17 Feb 2006 13:58:33 GMT]]></title><description><![CDATA[<p dir="auto">final price-lowest ill go is 700, someone buy this shit</p>
]]></description><link>https://fargostreet.com/post/93120</link><guid isPermaLink="true">https://fargostreet.com/post/93120</guid><dc:creator><![CDATA[bipedbear]]></dc:creator><pubDate>Fri, 17 Feb 2006 13:58:33 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Thu, 16 Feb 2006 13:50:34 GMT]]></title><description><![CDATA[<blockquote>
one week only special..... 750 picked up with EDFC</p>
<p dir="auto">thats more of a better price that you'll find someone to buy.  goodluck again.</p>
]]></description><link>https://fargostreet.com/post/92996</link><guid isPermaLink="true">https://fargostreet.com/post/92996</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Thu, 16 Feb 2006 13:50:34 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Tue, 14 Feb 2006 19:50:18 GMT]]></title><description><![CDATA[<p dir="auto">come on people</p>
]]></description><link>https://fargostreet.com/post/92607</link><guid isPermaLink="true">https://fargostreet.com/post/92607</guid><dc:creator><![CDATA[bipedbear]]></dc:creator><pubDate>Tue, 14 Feb 2006 19:50:18 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Mon, 06 Feb 2006 21:48:03 GMT]]></title><description><![CDATA[<p dir="auto">Will Trade For B Series Turbo Parts!!!!!!!</p>
]]></description><link>https://fargostreet.com/post/91696</link><guid isPermaLink="true">https://fargostreet.com/post/91696</guid><dc:creator><![CDATA[bipedbear]]></dc:creator><pubDate>Mon, 06 Feb 2006 21:48:03 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Mon, 06 Feb 2006 16:30:30 GMT]]></title><description><![CDATA[<p dir="auto">one week only special..... 750 picked up with EDFC</p>
]]></description><link>https://fargostreet.com/post/91668</link><guid isPermaLink="true">https://fargostreet.com/post/91668</guid><dc:creator><![CDATA[bipedbear]]></dc:creator><pubDate>Mon, 06 Feb 2006 16:30:30 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Mon, 06 Feb 2006 16:09:01 GMT]]></title><description><![CDATA[<p dir="auto">good suspension... bump</p>
]]></description><link>https://fargostreet.com/post/91665</link><guid isPermaLink="true">https://fargostreet.com/post/91665</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Mon, 06 Feb 2006 16:09:01 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Fri, 03 Feb 2006 20:12:10 GMT]]></title><description><![CDATA[<p dir="auto">Goodluck on the sale.  Bump for a damn good suspension.</p>
]]></description><link>https://fargostreet.com/post/91424</link><guid isPermaLink="true">https://fargostreet.com/post/91424</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Fri, 03 Feb 2006 20:12:10 GMT</pubDate></item><item><title><![CDATA[Reply to Tein Flex with EDFC setup for sale-honda on Fri, 03 Feb 2006 19:06:10 GMT]]></title><description><![CDATA[<p dir="auto">up</p>
]]></description><link>https://fargostreet.com/post/91420</link><guid isPermaLink="true">https://fargostreet.com/post/91420</guid><dc:creator><![CDATA[bipedbear]]></dc:creator><pubDate>Fri, 03 Feb 2006 19:06:10 GMT</pubDate></item></channel></rss>
