<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tire question]]></title><description><![CDATA[<p dir="auto">Let's just say I'm bad at calculating tire sizes... anyway I could use some help from my E-friends <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">My car came stock with 14x5" rims that had 185/60/14 tire's on them, then I upgraded rims to 15x6.5" with 195/55/15 tires on them. The prob is I get tire rub from my car being lowerd and the tire's are a little too big for my car.  I want to run 205's, and that is fine but I found a deal on 205/<strong>60</strong>/15 but is that going to work?  I think I need 205/<strong>50</strong>/15's, what is the diffrence and can I make them work? What does that middle number mean?</p>
<p dir="auto">Thanks for the help on this retarded subject matter <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
]]></description><link>https://fargostreet.com/topic/5564/tire-question</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 06:54:04 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/5564.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Feb 2006 07:15:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tire question on Fri, 03 Feb 2006 20:03:54 GMT]]></title><description><![CDATA[<p dir="auto">Lank you must also take into consideration the backspacing of the wheels you put on the car. If that brings them too far in, the no matter what tire you put on there, you will get rub.</p>
]]></description><link>https://fargostreet.com/post/91423</link><guid isPermaLink="true">https://fargostreet.com/post/91423</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Fri, 03 Feb 2006 20:03:54 GMT</pubDate></item><item><title><![CDATA[Reply to Tire question on Fri, 03 Feb 2006 19:07:37 GMT]]></title><description><![CDATA[<p dir="auto">Whenever I change tire sizes I use this web site</p>
<p dir="auto"><a href="http://www.miata.net/garage/tirecalc.html" rel="nofollow ugc">http://www.miata.net/garage/tirecalc.html</a></p>
<p dir="auto">It will tell you what wheel and tire sizes are closest to stock.</p>
<p dir="auto">Mike</p>
]]></description><link>https://fargostreet.com/post/91421</link><guid isPermaLink="true">https://fargostreet.com/post/91421</guid><dc:creator><![CDATA[wa2fastcamaro]]></dc:creator><pubDate>Fri, 03 Feb 2006 19:07:37 GMT</pubDate></item><item><title><![CDATA[Reply to Tire question on Fri, 03 Feb 2006 18:24:34 GMT]]></title><description><![CDATA[<p dir="auto">anytime.....</p>
]]></description><link>https://fargostreet.com/post/91418</link><guid isPermaLink="true">https://fargostreet.com/post/91418</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Fri, 03 Feb 2006 18:24:34 GMT</pubDate></item><item><title><![CDATA[Reply to Tire question on Fri, 03 Feb 2006 18:16:05 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">2.5RS wrote:<br />
Width x Aspect Ratio = Section Height<br />
Section Height x 2 = Combined Section Height<br />
Combined Section Height + Wheel Diameter = Tire Diameter</p>
<p dir="auto">Example: 185/60R14 85H or 185/60HR14</p>
<p dir="auto">185mm x .60=111mm<br />
111mm x 2=222mm<br />
222mm + 355.6mm(14")= 577.6mm or 22.74"</p>
<p dir="auto">The first number is the width of the tire in millimeters, measured from sidewall to sidewall. To convert to inches, divide by 25.4 In the example above, the width is 185mm or 7.28".</p>
<p dir="auto">The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36".</p>
<p dir="auto">The last number is the diameter of the wheel in inches.</p>
<p dir="auto">To figure the outside diameter of a tire, take the sidewall height and multiply by 2,(remember that the diameter is made up of 2 sidewalls, the one above the wheel, and the one below the wheel) and add the diameter of the wheel to get your answer.<br />
Thank you so much, this helped greatly!  I'm going to go with 195/50/15's thanks a ton for the info!</p>
]]></description><link>https://fargostreet.com/post/91417</link><guid isPermaLink="true">https://fargostreet.com/post/91417</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Fri, 03 Feb 2006 18:16:05 GMT</pubDate></item><item><title><![CDATA[Reply to Tire question on Fri, 03 Feb 2006 10:53:58 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://www.google.com/search?hl=en&amp;q=tire+size+calculator&amp;btnG=Google+Search" rel="nofollow ugc">http://www.google.com/search?hl=en&amp;q=tire+size+calculator&amp;btnG=Google+Search</a></p>
]]></description><link>https://fargostreet.com/post/91406</link><guid isPermaLink="true">https://fargostreet.com/post/91406</guid><dc:creator><![CDATA[pin]]></dc:creator><pubDate>Fri, 03 Feb 2006 10:53:58 GMT</pubDate></item><item><title><![CDATA[Reply to Tire question on Fri, 03 Feb 2006 09:09:52 GMT]]></title><description><![CDATA[<p dir="auto">so in other words.... the 205/60/15 tires will NOT work.... they are a taller/wider tire.....</p>
]]></description><link>https://fargostreet.com/post/91403</link><guid isPermaLink="true">https://fargostreet.com/post/91403</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Fri, 03 Feb 2006 09:09:52 GMT</pubDate></item><item><title><![CDATA[Reply to Tire question on Fri, 03 Feb 2006 09:04:59 GMT]]></title><description><![CDATA[<p dir="auto">Width x Aspect Ratio = Section Height<br />
<p dir="auto">To figure the outside diameter of a tire, take the sidewall height and multiply by 2,(remember that the diameter is made up of 2 sidewalls, the one above the wheel, and the one below the wheel) and add the diameter of the wheel to get your answer.</p>
]]></description><link>https://fargostreet.com/post/91402</link><guid isPermaLink="true">https://fargostreet.com/post/91402</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Fri, 03 Feb 2006 09:04:59 GMT</pubDate></item></channel></rss>
