<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tube frame...]]></title><description><![CDATA[<p dir="auto">--------------- <a href="www.swracecars.com------------------">www.swracecars.com------------------</a></p>
<p dir="auto">I have had these parts around for about a year...</p>
<p dir="auto">10-400 Frame 24'' 4 Link Fully welded  610.45</p>
<p dir="auto">10-400H Hardware Kit</p>
<p dir="auto">40-400 Track bar for 10-400 56.65</p>
<p dir="auto">40-121 Lazer Link Rod End package 290.00</p>
<p dir="auto">40-118f Lazer Link less Rod ends, No frame brakets 151.95</p>
<p dir="auto">40-223-95 Shock &amp; spring mount Kit 95# springs 179.95</p>
<p dir="auto">36-000 Frame A- Arm Rails Pinto type , rack X- member , shock support 449.95</p>
<p dir="auto">36-001 A- arm upper with Hardware 185.75</p>
<p dir="auto">36-002 A- Arm Lower With Hardware 239.75</p>
<p dir="auto">35-005 Pinto Tie rod end Kit 44.95</p>
<p dir="auto">36-006 Rack mount Bushing 19.95</p>
<p dir="auto">36-003  (4) ball joint For Pinto Front A-Arm Package 79.80</p>
<p dir="auto">36-008L Fabricated Pinto Spindle- Left Side With 4 Piston Braket 199.00</p>
<p dir="auto">36-008r Fabricated pinto Spindle Right side with piston Braket 199.00</p>
<p dir="auto">35-042 Wilwood Rack &amp; Pinion 239.95</p>
<p dir="auto">50-017a Hal Corp Aluminum Coil Over  shock 2-1/4 '' Travel single ext . ADJ 359.98</p>
<p dir="auto">50-029 Coil Over Spring 250  lbs7x2 1/2 77.00</p>
<p dir="auto">12 point cage for a 1g DSM 255.00</p>
<p dir="auto">Shipping  350.00</p>
<p dir="auto">Also have 27'' DOT slicks, and 15'' rims  250.00</p>
<p dir="auto">plus i have a 1g dsm stripped down and close for install</p>
<p dir="auto">over 4000.00 invested in to this set-up.. its all brand new and never installed. looking for 3000.00 for all.. I may ebay this all soon..</p>
<p dir="auto">I will get pics soon or you can look at it on <a href="www.swracecars.com">www.swracecars.com</a></p>
]]></description><link>https://fargostreet.com/topic/5627/tube-frame...</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 22:46:20 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/5627.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Feb 2006 05:03:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tube frame... on Tue, 28 Feb 2006 05:16:40 GMT]]></title><description><![CDATA[<p dir="auto">I pretty much got a buyer but thanks i think I know what your speaking</p>
]]></description><link>https://fargostreet.com/post/93989</link><guid isPermaLink="true">https://fargostreet.com/post/93989</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Tue, 28 Feb 2006 05:16:40 GMT</pubDate></item><item><title><![CDATA[Reply to Tube frame... on Tue, 28 Feb 2006 02:34:39 GMT]]></title><description><![CDATA[<p dir="auto">Idrags forum is long gone...</p>
]]></description><link>https://fargostreet.com/post/93960</link><guid isPermaLink="true">https://fargostreet.com/post/93960</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Tue, 28 Feb 2006 02:34:39 GMT</pubDate></item><item><title><![CDATA[Reply to Tube frame... on Tue, 28 Feb 2006 01:58:24 GMT]]></title><description><![CDATA[<p dir="auto">Sorry to say this Kevin, but I highly doubt anyone in the area is going to buy this.  That's a huge project to take up.  Maybe try the Idrags forum too?  If some domestics can use that stuff its worth a shot.</p>
]]></description><link>https://fargostreet.com/post/93953</link><guid isPermaLink="true">https://fargostreet.com/post/93953</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Tue, 28 Feb 2006 01:58:24 GMT</pubDate></item><item><title><![CDATA[Reply to Tube frame... on Tue, 28 Feb 2006 00:40:26 GMT]]></title><description><![CDATA[<p dir="auto"><strong>BUMP</strong></p>
]]></description><link>https://fargostreet.com/post/93935</link><guid isPermaLink="true">https://fargostreet.com/post/93935</guid><dc:creator><![CDATA[HandoEX]]></dc:creator><pubDate>Tue, 28 Feb 2006 00:40:26 GMT</pubDate></item><item><title><![CDATA[Reply to Tube frame... on Tue, 14 Feb 2006 08:12:39 GMT]]></title><description><![CDATA[<p dir="auto">bump.</p>
]]></description><link>https://fargostreet.com/post/92588</link><guid isPermaLink="true">https://fargostreet.com/post/92588</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Tue, 14 Feb 2006 08:12:39 GMT</pubDate></item></channel></rss>
