<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[150 miles to my last tank?!]]></title><description><![CDATA[<p dir="auto">Just replaced the o2 sensors I had in my car with some fresh ones...figured a little maintenence wouldn't hurt anyone. Well, after replacing them with some universal bosch's I got around 150 to the tank which is pretty unusual beings I usually get 240ish. I suspect the o2 sensors...is there any way I can check them????</p>
]]></description><link>https://fargostreet.com/topic/5636/150-miles-to-my-last-tank</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 04:35:47 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/5636.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Feb 2006 05:52:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 150 miles to my last tank?! on Thu, 23 Feb 2006 19:51:20 GMT]]></title><description><![CDATA[<p dir="auto">Glad you found it. Good call Tony.</p>
]]></description><link>https://fargostreet.com/post/93641</link><guid isPermaLink="true">https://fargostreet.com/post/93641</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Thu, 23 Feb 2006 19:51:20 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Thu, 23 Feb 2006 19:37:04 GMT]]></title><description><![CDATA[<p dir="auto">FYI update: located the problem...it was a torn injector o-ring on injector #1. Cause: AEM fuel rail; as it turn out, the opening of the aim rail are not as large as stock, making the o-rings easily torn.</p>
]]></description><link>https://fargostreet.com/post/93639</link><guid isPermaLink="true">https://fargostreet.com/post/93639</guid><dc:creator><![CDATA[seanjohn]]></dc:creator><pubDate>Thu, 23 Feb 2006 19:37:04 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Mon, 13 Feb 2006 07:16:58 GMT]]></title><description><![CDATA[<blockquote>
if youve R&amp;R'd the injectors a lot maybe its a good idea to replace the O-rings...its a cheap insurance policy if nothing else...</p>
<p dir="auto">Yeah, I'm going to go ahead and get a new injector o-ring set. The old 02 sensors have moved on to a better place. I'm going to replace them and the o-rings and see what happens.</p>
]]></description><link>https://fargostreet.com/post/92459</link><guid isPermaLink="true">https://fargostreet.com/post/92459</guid><dc:creator><![CDATA[seanjohn]]></dc:creator><pubDate>Mon, 13 Feb 2006 07:16:58 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Mon, 13 Feb 2006 04:54:30 GMT]]></title><description><![CDATA[<p dir="auto">if youve R&amp;R'd the injectors a lot maybe its a good idea to replace the O-rings...its a cheap insurance policy if nothing else...</p>
]]></description><link>https://fargostreet.com/post/92447</link><guid isPermaLink="true">https://fargostreet.com/post/92447</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Mon, 13 Feb 2006 04:54:30 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Mon, 13 Feb 2006 04:28:09 GMT]]></title><description><![CDATA[<p dir="auto">if there is gas around it i would replace it just to be sure try that and see what happens then try the old o2 sensors in there again</p>
]]></description><link>https://fargostreet.com/post/92445</link><guid isPermaLink="true">https://fargostreet.com/post/92445</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Mon, 13 Feb 2006 04:28:09 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Mon, 13 Feb 2006 03:55:22 GMT]]></title><description><![CDATA[<p dir="auto">Who cares if the old o2 sensors have carbon?  If they work better than the Bosch's, why don't you want to put them back in?</p>
]]></description><link>https://fargostreet.com/post/92440</link><guid isPermaLink="true">https://fargostreet.com/post/92440</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Mon, 13 Feb 2006 03:55:22 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Mon, 13 Feb 2006 01:00:24 GMT]]></title><description><![CDATA[<p dir="auto">Nope, haven't touched the timing since the new dizzy...only thing to change is the 02 sensors. However, I double checked under my hood tonight because I have to order some<br />
-an fittings for my fuel line...and I noticed it reaked of gas...and I notice a little pool of fuel accumulating on my intake manifold. Looked like it might have come out of injector #1....dunno if it's not getting a good seal or what?!?! Stoopid cars.</p>
]]></description><link>https://fargostreet.com/post/92426</link><guid isPermaLink="true">https://fargostreet.com/post/92426</guid><dc:creator><![CDATA[seanjohn]]></dc:creator><pubDate>Mon, 13 Feb 2006 01:00:24 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Sun, 12 Feb 2006 23:03:23 GMT]]></title><description><![CDATA[<p dir="auto">I know its a shot in the dark, but did you touch your timing?</p>
]]></description><link>https://fargostreet.com/post/92405</link><guid isPermaLink="true">https://fargostreet.com/post/92405</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Sun, 12 Feb 2006 23:03:23 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Sun, 12 Feb 2006 23:00:33 GMT]]></title><description><![CDATA[<p dir="auto">A way you can check to see if they are putting out the proper voltage, is to use a multi meter, and read the signal wire at the ECU to see if it is fluctuating between 0-1 volt DC.  It will bounce all around at idle and normal cruise, but under full throttle it will sit at a value closer to 1v.</p>
]]></description><link>https://fargostreet.com/post/92404</link><guid isPermaLink="true">https://fargostreet.com/post/92404</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Sun, 12 Feb 2006 23:00:33 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Sun, 12 Feb 2006 22:49:30 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Sweet-WRX-Lovin wrote:<br />
You're not out of boost fluid again right?</p>
<p dir="auto">Yeah, check out your vtak cleaner too.  I heard honda is going to stop selling the vtak cleaner so stock up now..  after this year you will just have to buy a new vtak.  (or go grey market for 'tak cleaner... shhh).</p>
<p dir="auto">Just funnin..  I had a civic ex when I was 17 and didn't know shit about cars and let me tell you, v-tec was the shit.</p>
]]></description><link>https://fargostreet.com/post/92401</link><guid isPermaLink="true">https://fargostreet.com/post/92401</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Sun, 12 Feb 2006 22:49:30 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Sun, 12 Feb 2006 17:23:54 GMT]]></title><description><![CDATA[<p dir="auto">there is zero warranty on OEM o2 sensors?</p>
<p dir="auto">damn...honda is gay</p>
]]></description><link>https://fargostreet.com/post/92358</link><guid isPermaLink="true">https://fargostreet.com/post/92358</guid><dc:creator><![CDATA[slowvo]]></dc:creator><pubDate>Sun, 12 Feb 2006 17:23:54 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Sun, 12 Feb 2006 13:29:20 GMT]]></title><description><![CDATA[<p dir="auto">I wish I could get 150 miles to a tank</p>
]]></description><link>https://fargostreet.com/post/92349</link><guid isPermaLink="true">https://fargostreet.com/post/92349</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Sun, 12 Feb 2006 13:29:20 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Sun, 12 Feb 2006 09:07:45 GMT]]></title><description><![CDATA[<p dir="auto">You're not out of boost fluid again right?</p>
]]></description><link>https://fargostreet.com/post/92345</link><guid isPermaLink="true">https://fargostreet.com/post/92345</guid><dc:creator><![CDATA[Sweet-WRX-Lovin]]></dc:creator><pubDate>Sun, 12 Feb 2006 09:07:45 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Sun, 12 Feb 2006 08:28:41 GMT]]></title><description><![CDATA[<p dir="auto">OEM is an idea, but they don't come w/ a warranty....ever. Also, these bosch's have a warranty on them, so I should be able to replace them with something else at autozone...i.e. denso's</p>
]]></description><link>https://fargostreet.com/post/92343</link><guid isPermaLink="true">https://fargostreet.com/post/92343</guid><dc:creator><![CDATA[seanjohn]]></dc:creator><pubDate>Sun, 12 Feb 2006 08:28:41 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Sun, 12 Feb 2006 08:20:08 GMT]]></title><description><![CDATA[<p dir="auto">go with some OEM ones.  try resetting your ecu if you can.  i'm not too familiar with hondas but it took my gsx a little while to get used to the idea of my new o2 sensor.  just some thoughts.</p>
]]></description><link>https://fargostreet.com/post/92342</link><guid isPermaLink="true">https://fargostreet.com/post/92342</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Sun, 12 Feb 2006 08:20:08 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Sun, 12 Feb 2006 08:18:23 GMT]]></title><description><![CDATA[<p dir="auto">Anyone have any experience w/ denso's?</p>
]]></description><link>https://fargostreet.com/post/92341</link><guid isPermaLink="true">https://fargostreet.com/post/92341</guid><dc:creator><![CDATA[seanjohn]]></dc:creator><pubDate>Sun, 12 Feb 2006 08:18:23 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Sun, 12 Feb 2006 07:18:06 GMT]]></title><description><![CDATA[<p dir="auto">bosch doesn't agree with any car imo</p>
]]></description><link>https://fargostreet.com/post/92336</link><guid isPermaLink="true">https://fargostreet.com/post/92336</guid><dc:creator><![CDATA[bluejays]]></dc:creator><pubDate>Sun, 12 Feb 2006 07:18:06 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Sun, 12 Feb 2006 06:47:16 GMT]]></title><description><![CDATA[<p dir="auto">Old ones are coated with carbon from running a piss-poor tune. I had heard that bosch's don't agree with honda's....but what I really need to know is if I can simply have these tested...where, and how much.</p>
]]></description><link>https://fargostreet.com/post/92335</link><guid isPermaLink="true">https://fargostreet.com/post/92335</guid><dc:creator><![CDATA[seanjohn]]></dc:creator><pubDate>Sun, 12 Feb 2006 06:47:16 GMT</pubDate></item><item><title><![CDATA[Reply to 150 miles to my last tank?! on Sun, 12 Feb 2006 06:39:59 GMT]]></title><description><![CDATA[<p dir="auto">Well, I would say put the old ones back in.</p>
]]></description><link>https://fargostreet.com/post/92334</link><guid isPermaLink="true">https://fargostreet.com/post/92334</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sun, 12 Feb 2006 06:39:59 GMT</pubDate></item></channel></rss>
