<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Motherboard&#x2F;Processor problem]]></title><description><![CDATA[<p dir="auto">So I got my new mobo installed today and powered it on and it doesnt recognize what processor is in there. It says Unknown Processor. It works but it should recognize that it is an AMD Athlon XP 1900+... Now the power supply is rather small at 200watts but I would think it would atleast work for a little while. I try to set it up in the BIOS and it still says unknown processor. I can select the right speed but its only because of user defined properties. It should have its own settings that I dont have to change that can be set up automatically. Does anyone have any idea? The Processor itself could be the problem but I highly doubt it personally cause it wouldn't boot at all if it was bad...I think it might be either the power supply or the mobo...</p>
]]></description><link>https://fargostreet.com/topic/5695/motherboard-processor-problem</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 11:45:38 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/5695.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Feb 2006 00:17:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Motherboard&#x2F;Processor problem on Sun, 19 Feb 2006 19:00:30 GMT]]></title><description><![CDATA[<p dir="auto">^^^yup^^^ I'd start there as well</p>
]]></description><link>https://fargostreet.com/post/93237</link><guid isPermaLink="true">https://fargostreet.com/post/93237</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sun, 19 Feb 2006 19:00:30 GMT</pubDate></item><item><title><![CDATA[Reply to Motherboard&#x2F;Processor problem on Sun, 19 Feb 2006 18:50:42 GMT]]></title><description><![CDATA[<p dir="auto">Flash the BIOS and I think you might want a larger power supply.</p>
]]></description><link>https://fargostreet.com/post/93232</link><guid isPermaLink="true">https://fargostreet.com/post/93232</guid><dc:creator><![CDATA[TDuck]]></dc:creator><pubDate>Sun, 19 Feb 2006 18:50:42 GMT</pubDate></item></channel></rss>
