<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Need your DSM expertise]]></title><description><![CDATA[<p dir="auto">Got John's GSX running, and it dosen't seem to have mechanical problems, but it does run funny. Seems like its running way too rich and the exhaust it thick and stinks like gas. Also it backfires a little. Does the cam sensor get the wrong reading if its 180* off, kinda like a V8 distribuor when you put it in 180 off?</p>
<p dir="auto">But other wise I got it all connected correctly and running but needs tuning, and I don't have enough knowledge to figure it out.</p>
<p dir="auto">Mike</p>
]]></description><link>https://fargostreet.com/topic/5916/need-your-dsm-expertise</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 04:35:53 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/5916.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Mar 2006 06:16:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Need your DSM expertise on Sat, 25 Mar 2006 04:03:58 GMT]]></title><description><![CDATA[<blockquote>
are you 100% sure the timing belt isnt a clog off?</p>
<p dir="auto">I checked it like 15 times, damnit, it has to be right from what my manual says. If you would come look at it, and help get it running correctly I will give you a little $$ for your time.</p>
]]></description><link>https://fargostreet.com/post/96279</link><guid isPermaLink="true">https://fargostreet.com/post/96279</guid><dc:creator><![CDATA[wa2fastcamaro]]></dc:creator><pubDate>Sat, 25 Mar 2006 04:03:58 GMT</pubDate></item><item><title><![CDATA[Reply to Need your DSM expertise on Sat, 25 Mar 2006 03:50:02 GMT]]></title><description><![CDATA[<p dir="auto">are you 100% sure the timing belt isnt a clog off?</p>
]]></description><link>https://fargostreet.com/post/96277</link><guid isPermaLink="true">https://fargostreet.com/post/96277</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Sat, 25 Mar 2006 03:50:02 GMT</pubDate></item><item><title><![CDATA[Reply to Need your DSM expertise on Sat, 25 Mar 2006 03:37:26 GMT]]></title><description><![CDATA[<p dir="auto">it backfires when it first starts sometime...</p>
<p dir="auto">it revs all the way to 7k without too much popping from what i remember yes.</p>
]]></description><link>https://fargostreet.com/post/96275</link><guid isPermaLink="true">https://fargostreet.com/post/96275</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Sat, 25 Mar 2006 03:37:26 GMT</pubDate></item><item><title><![CDATA[Reply to Need your DSM expertise on Sat, 25 Mar 2006 03:10:19 GMT]]></title><description><![CDATA[<p dir="auto">If you really want I may be able to come out there and take a look at it...</p>
<p dir="auto">does it rev all the way to 7k? with out much popping? I got a few ideas but would like to look at it first</p>
]]></description><link>https://fargostreet.com/post/96274</link><guid isPermaLink="true">https://fargostreet.com/post/96274</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Sat, 25 Mar 2006 03:10:19 GMT</pubDate></item><item><title><![CDATA[Reply to Need your DSM expertise on Wed, 22 Mar 2006 06:32:45 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">wa2fastcamaro wrote:<br />
<p dir="auto">CAS works both ways.  Check for boost leaks, timing belt alignment, and firing order.</p>
]]></description><link>https://fargostreet.com/post/96047</link><guid isPermaLink="true">https://fargostreet.com/post/96047</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Wed, 22 Mar 2006 06:32:45 GMT</pubDate></item></channel></rss>
