<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help for my CF hood]]></title><description><![CDATA[<p dir="auto">I've got some strange,cloudy residue on my hood and haven't got a clue where it came from, it's on the surface because I can feel the difference in surface texture from where the residue is and where it isn't. I was wonder what would work best to buff it out or possibly remove the residue. I don't have access to a DA and all I have are a big and small wal-mart special buffers. I was thinking about using wax remover to see if it would take it off then rewaxing it or wet sanding as a last resort, which I really don't want to do. Let me know what you think or know of any good products that might work.</p>
]]></description><link>https://fargostreet.com/topic/5980/help-for-my-cf-hood</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 06:08:08 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/5980.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Mar 2006 16:06:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help for my CF hood on Sat, 01 Apr 2006 04:33:01 GMT]]></title><description><![CDATA[<p dir="auto">speaking of buffing cf hoods...i need mine on my maxima buffed....who wants money?</p>
]]></description><link>https://fargostreet.com/post/97190</link><guid isPermaLink="true">https://fargostreet.com/post/97190</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Sat, 01 Apr 2006 04:33:01 GMT</pubDate></item><item><title><![CDATA[Reply to Help for my CF hood on Fri, 31 Mar 2006 12:09:50 GMT]]></title><description><![CDATA[<p dir="auto">I buffed collins carbon fiber hood and I suck at buffing. It looked fine. Bring it to kevin. we'll get 'er done.</p>
]]></description><link>https://fargostreet.com/post/97099</link><guid isPermaLink="true">https://fargostreet.com/post/97099</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Fri, 31 Mar 2006 12:09:50 GMT</pubDate></item><item><title><![CDATA[Reply to Help for my CF hood on Fri, 31 Mar 2006 09:01:09 GMT]]></title><description><![CDATA[<p dir="auto">well i haved worked recon for about 4 1/2 years to long what would be the easiest and the cheapest is just get a fine rag buffing compound and gloss, buff it out by hand if its just residue it wont take that long to remove use the compound first and then the gloss make sure to use to different rags for this or you'll end up with a mess.</p>
]]></description><link>https://fargostreet.com/post/97098</link><guid isPermaLink="true">https://fargostreet.com/post/97098</guid><dc:creator><![CDATA[smtomps1955]]></dc:creator><pubDate>Fri, 31 Mar 2006 09:01:09 GMT</pubDate></item><item><title><![CDATA[Reply to Help for my CF hood on Thu, 30 Mar 2006 13:55:48 GMT]]></title><description><![CDATA[<p dir="auto">so you can buff CF just very careful.</p>
<p dir="auto">Theres a guy on another forum that buffed his CF hood and started to peel and looked 10x worse then it did with the haze look</p>
]]></description><link>https://fargostreet.com/post/96939</link><guid isPermaLink="true">https://fargostreet.com/post/96939</guid><dc:creator><![CDATA[krzydrftr93]]></dc:creator><pubDate>Thu, 30 Mar 2006 13:55:48 GMT</pubDate></item><item><title><![CDATA[Reply to Help for my CF hood on Thu, 30 Mar 2006 04:38:11 GMT]]></title><description><![CDATA[<p dir="auto">Take your car to a local detail shop and get a quote to buff it out..</p>
<p dir="auto">shouldnt be more than 40.00 TOPS!</p>
]]></description><link>https://fargostreet.com/post/96916</link><guid isPermaLink="true">https://fargostreet.com/post/96916</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Thu, 30 Mar 2006 04:38:11 GMT</pubDate></item><item><title><![CDATA[Reply to Help for my CF hood on Thu, 30 Mar 2006 03:45:09 GMT]]></title><description><![CDATA[<blockquote>
OR..<br />
Bring it to SLD and I'll see what I can do..</p>
<p dir="auto">My .02</p>
<p dir="auto">I had actually thought about it but I'm 150 miles away and on a tight budget.<br />
PM me with a quote and a time frame that this should take to do. You know, to give me a little more incentive to bring business your way:D  The whole car needs a buff but the hood can do for now, it seems to be the most noticeable, plus i'm gonna remove the rest of my vinyl before I decide to buff it.</p>
]]></description><link>https://fargostreet.com/post/96907</link><guid isPermaLink="true">https://fargostreet.com/post/96907</guid><dc:creator><![CDATA[ichibankilla]]></dc:creator><pubDate>Thu, 30 Mar 2006 03:45:09 GMT</pubDate></item><item><title><![CDATA[Reply to Help for my CF hood on Wed, 29 Mar 2006 23:44:39 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">In my eyes, that's the ONLY option.</p>
]]></description><link>https://fargostreet.com/post/96879</link><guid isPermaLink="true">https://fargostreet.com/post/96879</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Wed, 29 Mar 2006 23:44:39 GMT</pubDate></item><item><title><![CDATA[Reply to Help for my CF hood on Wed, 29 Mar 2006 23:41:31 GMT]]></title><description><![CDATA[<p dir="auto">Well my opinion..</p>
<p dir="auto">Do not wet sand and try to buff out with a dual action walwart buffer..</p>
<pre><code>If your a DIY'er go buy a Dewalt buffer/ polisher turns up to 3000 RPM;s buy a Med cut pad.
</code></pre>
<p dir="auto">1st Step use 3M high cut compound MEd cut pad 1800 RPMS</p>
<p dir="auto">2nd Step use Megs Swirl Removal with a polish/ Final pad 1600 RPMS</p>
<p dir="auto">3nd Step Seal with a sealant  1000 RPM</p>
<p dir="auto">4th Step Wax on wax off  Hand Wax</p>
<p dir="auto">OR..<br />
]]></description><link>https://fargostreet.com/post/96878</link><guid isPermaLink="true">https://fargostreet.com/post/96878</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Wed, 29 Mar 2006 23:41:31 GMT</pubDate></item></channel></rss>
