<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Need headliner recovered]]></title><description><![CDATA[<p dir="auto">I need the headliner recovered in my 79 Trans AM, its one of those hard cardboard ones that has cloth glued to it. Well I have yet to find a glue that will work to fix those, so I was wondering if anyone knew of a glue to use or a upholstry shop to recover it for me that dosen't cost a arm and a leg. I do not want to pay $100 to have it redone.</p>
<p dir="auto">Mike</p>
]]></description><link>https://fargostreet.com/topic/6137/need-headliner-recovered</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 08:12:48 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/6137.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Apr 2006 18:01:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Need headliner recovered on Wed, 24 May 2006 03:34:06 GMT]]></title><description><![CDATA[<p dir="auto">I'm by no means an expert, but when I went to autobody school my instructor said not to even mess with "trim" or "headliner" adhesives and just go straight for the stuff they use for vinyl tops. Clean the cardboard and headliner then spray the stuff out of a cheap paint gun.  One good coat on each one, let it tack up for a little bit then carefully stick the headliner to the cardboard trying not to get any runs in it.  It's been a couple of years but I'm pretty sure that's all there is to it.  Good luck</p>
]]></description><link>https://fargostreet.com/post/102696</link><guid isPermaLink="true">https://fargostreet.com/post/102696</guid><dc:creator><![CDATA[rustychevy]]></dc:creator><pubDate>Wed, 24 May 2006 03:34:06 GMT</pubDate></item><item><title><![CDATA[Reply to Need headliner recovered on Sun, 30 Apr 2006 01:25:00 GMT]]></title><description><![CDATA[<p dir="auto">gotta take them out to do them..</p>
]]></description><link>https://fargostreet.com/post/100387</link><guid isPermaLink="true">https://fargostreet.com/post/100387</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Sun, 30 Apr 2006 01:25:00 GMT</pubDate></item><item><title><![CDATA[Reply to Need headliner recovered on Sat, 29 Apr 2006 19:27:59 GMT]]></title><description><![CDATA[<p dir="auto">good luck gluing the T/A headliners yourself.  We fought with the one on our trans am for a while and then just took it down.  2 or 3 years ago we had it redone at a professional upholstery place and its been great ever since.</p>
]]></description><link>https://fargostreet.com/post/100361</link><guid isPermaLink="true">https://fargostreet.com/post/100361</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sat, 29 Apr 2006 19:27:59 GMT</pubDate></item><item><title><![CDATA[Reply to Need headliner recovered on Sun, 23 Apr 2006 02:28:06 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">wa2fastcamaro wrote:<br />
I need the headliner recovered in my 79 Trans AM, its one of those hard cardboard ones that has cloth glued to it.<br />
Mike</p>
<p dir="auto">Thought I had seen it on Main and Univ. last night, what color is it???</p>
]]></description><link>https://fargostreet.com/post/99601</link><guid isPermaLink="true">https://fargostreet.com/post/99601</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Sun, 23 Apr 2006 02:28:06 GMT</pubDate></item><item><title><![CDATA[Reply to Need headliner recovered on Wed, 12 Apr 2006 13:58:47 GMT]]></title><description><![CDATA[<p dir="auto">i took my eclipse to Elite Trim shop and they did an awesome job i dont remember wat the headliner cost alone but for that carpets, cargo area and visors it was only a little over 400 dollars.</p>
]]></description><link>https://fargostreet.com/post/98551</link><guid isPermaLink="true">https://fargostreet.com/post/98551</guid><dc:creator><![CDATA[BomexE]]></dc:creator><pubDate>Wed, 12 Apr 2006 13:58:47 GMT</pubDate></item><item><title><![CDATA[Reply to Need headliner recovered on Wed, 12 Apr 2006 02:21:58 GMT]]></title><description><![CDATA[<p dir="auto">the spray on headliner adhesive (3M or others) works great.  The "trick" is to spray it on both the cloth material AND the cardboard and let it set-up a bit before placing the cloth on the cardboard, believe it or not it bonds better when nearly dry than it does when it is wet.  Read any quality can of Spray Adhesive or Contact Cement and they will tell you that.</p>
]]></description><link>https://fargostreet.com/post/98467</link><guid isPermaLink="true">https://fargostreet.com/post/98467</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Wed, 12 Apr 2006 02:21:58 GMT</pubDate></item><item><title><![CDATA[Reply to Need headliner recovered on Wed, 12 Apr 2006 00:36:45 GMT]]></title><description><![CDATA[<p dir="auto">I did the headliner in my talon last summer....use 3M General Trim Adhesive -clear #08088  You can pick it up at any auto parts store...I got mine at napa.  Make sure you pick up a wire brush and get ALL the excess fabric off the cardboard...and then spray the board up and down....and back and forth.  Get a friend to hold one end of the fabric up off the board, while you lay it down a strip at a time....its really easy...and worth the work! <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/98455</link><guid isPermaLink="true">https://fargostreet.com/post/98455</guid><dc:creator><![CDATA[TsiTom]]></dc:creator><pubDate>Wed, 12 Apr 2006 00:36:45 GMT</pubDate></item><item><title><![CDATA[Reply to Need headliner recovered on Tue, 11 Apr 2006 23:47:12 GMT]]></title><description><![CDATA[<p dir="auto">I think i saw on SLD's website that they do headliners...</p>
]]></description><link>https://fargostreet.com/post/98450</link><guid isPermaLink="true">https://fargostreet.com/post/98450</guid><dc:creator><![CDATA[tweak]]></dc:creator><pubDate>Tue, 11 Apr 2006 23:47:12 GMT</pubDate></item><item><title><![CDATA[Reply to Need headliner recovered on Tue, 11 Apr 2006 19:11:54 GMT]]></title><description><![CDATA[<p dir="auto">go to the interior shop by valley imports on the North side between corwin and i thik interstate</p>
]]></description><link>https://fargostreet.com/post/98424</link><guid isPermaLink="true">https://fargostreet.com/post/98424</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Tue, 11 Apr 2006 19:11:54 GMT</pubDate></item><item><title><![CDATA[Reply to Need headliner recovered on Tue, 11 Apr 2006 18:41:53 GMT]]></title><description><![CDATA[<p dir="auto">if you want it done by a trained professional the right way, your gonna pay for it!</p>
]]></description><link>https://fargostreet.com/post/98419</link><guid isPermaLink="true">https://fargostreet.com/post/98419</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Tue, 11 Apr 2006 18:41:53 GMT</pubDate></item></channel></rss>
