<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rear axle Pinion shims]]></title><description><![CDATA[<p dir="auto">Does anyone know where I can buy pinion angle shims in town here?  I need shims to change the pinion angle not to set the pinion itself</p>
]]></description><link>https://fargostreet.com/topic/6171/rear-axle-pinion-shims</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 22:59:10 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/6171.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Apr 2006 18:54:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rear axle Pinion shims on Fri, 14 Apr 2006 19:00:14 GMT]]></title><description><![CDATA[<p dir="auto">ya Im doing a 2/4 drop on it</p>
]]></description><link>https://fargostreet.com/post/98857</link><guid isPermaLink="true">https://fargostreet.com/post/98857</guid><dc:creator><![CDATA[Raider]]></dc:creator><pubDate>Fri, 14 Apr 2006 19:00:14 GMT</pubDate></item><item><title><![CDATA[Reply to Rear axle Pinion shims on Fri, 14 Apr 2006 18:59:00 GMT]]></title><description><![CDATA[<p dir="auto">I had my gears done at Weivoda Auto, all he does is rear ends, he might have something that will work for you, he had everything under the sun that had to do with rear ends so that is probably a good bet.</p>
<p dir="auto">Lowering your truck???</p>
]]></description><link>https://fargostreet.com/post/98856</link><guid isPermaLink="true">https://fargostreet.com/post/98856</guid><dc:creator><![CDATA[Seven1]]></dc:creator><pubDate>Fri, 14 Apr 2006 18:59:00 GMT</pubDate></item></channel></rss>
