<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Timing and balance shaft belt...]]></title><description><![CDATA[<p dir="auto">I was wondering if anyone wanted to do a timing and balance shaft belt on my sisters Hyundai Sante Fe...oh yeah it also needs a crankshaft position sensor...I believe its the 4G64 motor as well...</p>
<p dir="auto">Tony</p>
]]></description><link>https://fargostreet.com/topic/6204/timing-and-balance-shaft-belt...</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 17:36:17 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/6204.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Apr 2006 05:30:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Timing and balance shaft belt... on Fri, 21 Apr 2006 12:18:47 GMT]]></title><description><![CDATA[<p dir="auto">Ok, got a better estimate....well, at least more accurate since its a different engine.  Youre looking at approx $410, that labor for both belts and sensor, along with parts on both belts and cranks sensor.  I usually like to replace other parts in these engines (similar to talon/eclipse/laser) like the hydralic tensioner (got one in the shop right now that slacked up too much and bent all intake valves), both tensioner and idler pulleys, along with camshaft seals too.  If this vehicle has low miles (like 60K) you should be fine to go another round with these parts till 120K service.  Otherwise if you are in the 90-120K range right now, you might wanna rethink replacing these parts too so you dont end up...well, you know.  Anyways, just let me know.</p>
<p dir="auto">Ry</p>
]]></description><link>https://fargostreet.com/post/99481</link><guid isPermaLink="true">https://fargostreet.com/post/99481</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Fri, 21 Apr 2006 12:18:47 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Fri, 21 Apr 2006 11:35:53 GMT]]></title><description><![CDATA[<p dir="auto">I looked up the 2.7 liter V6, which doesn't have the balance shaft.  Didn't know if you had that or the I4, which is a mistake on my part.  I just assumed that it had the V6 since the majority of them out there have it.  As for the price, that INCLUDES labor along with parts.  Ill get pricing for the 4 cylinder today.</p>
<p dir="auto">PS, as for engine codes, I only recognize honda ones, as for other makes, like the majority of shops out there, we like to go by size and vehicle VIN.</p>
]]></description><link>https://fargostreet.com/post/99479</link><guid isPermaLink="true">https://fargostreet.com/post/99479</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Fri, 21 Apr 2006 11:35:53 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Fri, 21 Apr 2006 01:33:14 GMT]]></title><description><![CDATA[<p dir="auto">$390 for parts?!?! just out of the curiousity how much is the sensor itself? and there are balance shafts on it because its the 4G64 from the mitsubishi line...</p>
]]></description><link>https://fargostreet.com/post/99448</link><guid isPermaLink="true">https://fargostreet.com/post/99448</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Fri, 21 Apr 2006 01:33:14 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Thu, 20 Apr 2006 22:27:09 GMT]]></title><description><![CDATA[<p dir="auto">I'm not tryin to throw a stink here but, I just looked it up on Alldata and it clearly shows balance shats in the engine.</p>
<p dir="auto"><a href="http://img391.imageshack.us/my.php?image=4g649gm.gif" rel="nofollow ugc"><img src="http://img391.imageshack.us/img391/9987/4g649gm.th.gif" alt="legacy image" class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://fargostreet.com/post/99425</link><guid isPermaLink="true">https://fargostreet.com/post/99425</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Thu, 20 Apr 2006 22:27:09 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Thu, 20 Apr 2006 21:55:31 GMT]]></title><description><![CDATA[<p dir="auto">for the belt and sensor, youre looking at about $390 for it.  there isn't a balance shaft belt at all, at least from what I have seen in diagrams.  the sensor is dealer only, so the price you'll pay is the price that you'll get charged from us.  let me know if you are interested at all.</p>
]]></description><link>https://fargostreet.com/post/99424</link><guid isPermaLink="true">https://fargostreet.com/post/99424</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Thu, 20 Apr 2006 21:55:31 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Thu, 20 Apr 2006 11:22:44 GMT]]></title><description><![CDATA[<p dir="auto">ill get you a quote later today when im at work so i know what the parts run.</p>
]]></description><link>https://fargostreet.com/post/99362</link><guid isPermaLink="true">https://fargostreet.com/post/99362</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Thu, 20 Apr 2006 11:22:44 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Thu, 20 Apr 2006 06:14:29 GMT]]></title><description><![CDATA[<p dir="auto">it is an 03 for sure...so I just need a timing belt, balance shaft belt, and a crankshaft position sensor..</p>
]]></description><link>https://fargostreet.com/post/99359</link><guid isPermaLink="true">https://fargostreet.com/post/99359</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Thu, 20 Apr 2006 06:14:29 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Wed, 19 Apr 2006 23:11:08 GMT]]></title><description><![CDATA[<blockquote>
well if you say 3 hour job , looks like 150.00 labor, plus parts...</p>
<p dir="auto">yeah sounds about right...</p>
]]></description><link>https://fargostreet.com/post/99289</link><guid isPermaLink="true">https://fargostreet.com/post/99289</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Wed, 19 Apr 2006 23:11:08 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Wed, 19 Apr 2006 23:07:52 GMT]]></title><description><![CDATA[<p dir="auto">well if you say 3 hour job , looks like 150.00 labor, plus parts...</p>
]]></description><link>https://fargostreet.com/post/99288</link><guid isPermaLink="true">https://fargostreet.com/post/99288</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Wed, 19 Apr 2006 23:07:52 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Wed, 19 Apr 2006 22:46:29 GMT]]></title><description><![CDATA[<p dir="auto">i think its like an 03?</p>
]]></description><link>https://fargostreet.com/post/99287</link><guid isPermaLink="true">https://fargostreet.com/post/99287</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Wed, 19 Apr 2006 22:46:29 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Wed, 19 Apr 2006 22:36:38 GMT]]></title><description><![CDATA[<p dir="auto">I'll do it.  What year Santa Fe?</p>
]]></description><link>https://fargostreet.com/post/99285</link><guid isPermaLink="true">https://fargostreet.com/post/99285</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Wed, 19 Apr 2006 22:36:38 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Wed, 19 Apr 2006 14:17:08 GMT]]></title><description><![CDATA[<p dir="auto">can you give me a quote Ry?</p>
]]></description><link>https://fargostreet.com/post/99225</link><guid isPermaLink="true">https://fargostreet.com/post/99225</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Wed, 19 Apr 2006 14:17:08 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Wed, 19 Apr 2006 12:08:03 GMT]]></title><description><![CDATA[<p dir="auto">4g64 FTL!<br />
(10 CHARACTER POST LIMITS ARE GAY)</p>
]]></description><link>https://fargostreet.com/post/99209</link><guid isPermaLink="true">https://fargostreet.com/post/99209</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 19 Apr 2006 12:08:03 GMT</pubDate></item><item><title><![CDATA[Reply to Timing and balance shaft belt... on Wed, 19 Apr 2006 11:38:53 GMT]]></title><description><![CDATA[<p dir="auto">Its only a 3 hour job, we can do it at my buddies shop no problem.  Let us know.</p>
<p dir="auto">Ryan<br />
277-7288<br />
West Fargo Car Clinic</p>
]]></description><link>https://fargostreet.com/post/99203</link><guid isPermaLink="true">https://fargostreet.com/post/99203</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Wed, 19 Apr 2006 11:38:53 GMT</pubDate></item></channel></rss>
