<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[new hard drive]]></title><description><![CDATA[<p dir="auto">just got a new OEM hard drive online.  i connected the power and sata cable.  When i turn the computer on it takes like around 2 minutes to start the computer and I hear clicking noise coming from the new hard drive.  Is that normal?  I just got it yesturday and I didn't drop it or shock it.  When I go into my computer it seems like it didn't read the hard drive.  I know bout master and slave drive but first it should be detected in order to do that right?  My computer is almost brand new, i heard newer computers should auto-detect it but it didn't.  I looked at the hard drive's web page and i did what it told me to do and it won't read it either.  i'm pisst because it seems like i have a defected kind.  Anybody have any ideas?  thanks a lot!</p>
]]></description><link>https://fargostreet.com/topic/6302/new-hard-drive</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 15:29:55 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/6302.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 28 Apr 2006 23:58:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to new hard drive on Mon, 01 May 2006 20:42:42 GMT]]></title><description><![CDATA[<p dir="auto">Another idea:</p>
<p dir="auto">Check your computer manufacturer's website and see if there are any bios updates available.  If so, it might provide support for bigger drives (usually the updates and fixes are posted, read through those and see).  Please be careful updating your bios if you choose to do so.</p>
<p dir="auto">Let us know what it ends up being!</p>
]]></description><link>https://fargostreet.com/post/100447</link><guid isPermaLink="true">https://fargostreet.com/post/100447</guid><dc:creator><![CDATA[Stormwalker]]></dc:creator><pubDate>Mon, 01 May 2006 20:42:42 GMT</pubDate></item><item><title><![CDATA[Reply to new hard drive on Sat, 29 Apr 2006 23:40:43 GMT]]></title><description><![CDATA[<blockquote>
did you change your BIOS settings so that it sees that you have the drive installed?  Also, you might want to see if there was any software that is needed to make the drive operational.  Might also want to check boot sequence to see which drive is set up as first boot device.</p>
<p dir="auto">Yes, i did BIOS settings and checked if I enabled the auto-detect already.  I saw that it found my orginal HD but have not for the new one.  It's an OEM HD so I don't think it comes with any CDs to install it.  I also did download a boot-up HD disc online and still no luck.  I want to use the new HD as storage and my orginal as boot device.</p>
<p dir="auto">Well...i asked one of my co-worker and he said "having 500gig is a problem and it's too big to auto-detect."  He said I have to set my computer manually.  I was like wtf?  is that true?</p>
]]></description><link>https://fargostreet.com/post/100376</link><guid isPermaLink="true">https://fargostreet.com/post/100376</guid><dc:creator><![CDATA[Spec_R]]></dc:creator><pubDate>Sat, 29 Apr 2006 23:40:43 GMT</pubDate></item><item><title><![CDATA[Reply to new hard drive on Sat, 29 Apr 2006 23:38:37 GMT]]></title><description><![CDATA[<p dir="auto">shit, i accidently post it twice....:rolleyes:</p>
]]></description><link>https://fargostreet.com/post/100375</link><guid isPermaLink="true">https://fargostreet.com/post/100375</guid><dc:creator><![CDATA[Spec_R]]></dc:creator><pubDate>Sat, 29 Apr 2006 23:38:37 GMT</pubDate></item><item><title><![CDATA[Reply to new hard drive on Sat, 29 Apr 2006 13:10:12 GMT]]></title><description><![CDATA[<p dir="auto">reread my post, I had the exact same problem and had to run the drive setup utility (which involved formating the drive, etc...) and go into the bios setup before my machine would recognize the drive.  I experienced nearly the same symptoms as you described and mine works flawlessly now.</p>
]]></description><link>https://fargostreet.com/post/100344</link><guid isPermaLink="true">https://fargostreet.com/post/100344</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sat, 29 Apr 2006 13:10:12 GMT</pubDate></item><item><title><![CDATA[Reply to new hard drive on Sat, 29 Apr 2006 11:50:07 GMT]]></title><description><![CDATA[<p dir="auto">yeah im guessing its defective because sata is all automatic by what port its plugged in on...no daisy chaining with sata</p>
]]></description><link>https://fargostreet.com/post/100338</link><guid isPermaLink="true">https://fargostreet.com/post/100338</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Sat, 29 Apr 2006 11:50:07 GMT</pubDate></item><item><title><![CDATA[Reply to new hard drive on Sat, 29 Apr 2006 09:26:34 GMT]]></title><description><![CDATA[<p dir="auto">wat are you guys talking about?</p>
<p dir="auto">well anways...I plugged it in other ports but still it doesn't work.  I guess it's the stupid hard drive that's defective.  damn it, i have to ship it back again...</p>
]]></description><link>https://fargostreet.com/post/100335</link><guid isPermaLink="true">https://fargostreet.com/post/100335</guid><dc:creator><![CDATA[Spec_R]]></dc:creator><pubDate>Sat, 29 Apr 2006 09:26:34 GMT</pubDate></item><item><title><![CDATA[Reply to new hard drive on Sat, 29 Apr 2006 08:08:57 GMT]]></title><description><![CDATA[<p dir="auto">no, those are the symptons of low halogen fluid lol  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
]]></description><link>https://fargostreet.com/post/100332</link><guid isPermaLink="true">https://fargostreet.com/post/100332</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sat, 29 Apr 2006 08:08:57 GMT</pubDate></item><item><title><![CDATA[Reply to new hard drive on Sat, 29 Apr 2006 03:39:15 GMT]]></title><description><![CDATA[<p dir="auto">Did you forget to add boost fluid?</p>
]]></description><link>https://fargostreet.com/post/100327</link><guid isPermaLink="true">https://fargostreet.com/post/100327</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Sat, 29 Apr 2006 03:39:15 GMT</pubDate></item><item><title><![CDATA[Reply to new hard drive on Sat, 29 Apr 2006 02:57:04 GMT]]></title><description><![CDATA[<p dir="auto">did you change your BIOS settings so that it sees that you have the drive installed?  Also, you might want to see if there was any software that is needed to make the drive operational.  Might also want to check boot sequence to see which drive is set up as first boot device.</p>
]]></description><link>https://fargostreet.com/post/100326</link><guid isPermaLink="true">https://fargostreet.com/post/100326</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sat, 29 Apr 2006 02:57:04 GMT</pubDate></item></channel></rss>
