<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[really tight bolt removal]]></title><description><![CDATA[<p dir="auto">I am trying to remove the sprockets on my bike. I dont know what the last person did, but they are way to tight to remove by hand.  I actually ended up stripping my socket.  Any suggestions on how to remove a bolt that is this tight?</p>
]]></description><link>https://fargostreet.com/topic/6388/really-tight-bolt-removal</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 17:50:01 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/6388.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 May 2006 04:04:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to really tight bolt removal on Wed, 10 May 2006 11:15:17 GMT]]></title><description><![CDATA[<p dir="auto">:drunken_smilie: Get a bigger hammer!!!:drunken_smilie:</p>
]]></description><link>https://fargostreet.com/post/101287</link><guid isPermaLink="true">https://fargostreet.com/post/101287</guid><dc:creator><![CDATA[CheapSRT]]></dc:creator><pubDate>Wed, 10 May 2006 11:15:17 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Wed, 10 May 2006 02:07:59 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">jct_4628 wrote:<br />
I have a soldering iron, could I just set it on the bolt and let it warm up?</p>
<p dir="auto">Also, do you think an impact driver might work?</p>
<p dir="auto">No.  A soldering iron is for wires, not bolts.</p>
<p dir="auto">Just go to the store and buy a propane torch.  They are pretty cheap.  Heating the bolt up along with a large breaker bar will remove it pretty easily.</p>
]]></description><link>https://fargostreet.com/post/101247</link><guid isPermaLink="true">https://fargostreet.com/post/101247</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Wed, 10 May 2006 02:07:59 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Wed, 10 May 2006 01:44:57 GMT]]></title><description><![CDATA[<p dir="auto">ALWAYS use a 6pt socket for tight bolts...</p>
]]></description><link>https://fargostreet.com/post/101241</link><guid isPermaLink="true">https://fargostreet.com/post/101241</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Wed, 10 May 2006 01:44:57 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Wed, 10 May 2006 01:41:07 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">No, soldering iron probably won't work.  Use an impact with a 6 pt socket.</p>
]]></description><link>https://fargostreet.com/post/101237</link><guid isPermaLink="true">https://fargostreet.com/post/101237</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Wed, 10 May 2006 01:41:07 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Wed, 10 May 2006 01:33:31 GMT]]></title><description><![CDATA[<p dir="auto">I have a soldering iron, could I just set it on the bolt and let it warm up?</p>
]]></description><link>https://fargostreet.com/post/101235</link><guid isPermaLink="true">https://fargostreet.com/post/101235</guid><dc:creator><![CDATA[jct_4628]]></dc:creator><pubDate>Wed, 10 May 2006 01:33:31 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Tue, 09 May 2006 21:35:45 GMT]]></title><description><![CDATA[<p dir="auto">Um, you heat the bolt with a torch...</p>
]]></description><link>https://fargostreet.com/post/101204</link><guid isPermaLink="true">https://fargostreet.com/post/101204</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Tue, 09 May 2006 21:35:45 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Tue, 09 May 2006 16:24:49 GMT]]></title><description><![CDATA[<p dir="auto">just giving you some crap.......would a heat gun work?</p>
]]></description><link>https://fargostreet.com/post/101158</link><guid isPermaLink="true">https://fargostreet.com/post/101158</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Tue, 09 May 2006 16:24:49 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Tue, 09 May 2006 16:15:04 GMT]]></title><description><![CDATA[<blockquote>
use a blow torch..........:p</p>
<p dir="auto">even if I had one, I dont think I would use it.</p>
]]></description><link>https://fargostreet.com/post/101154</link><guid isPermaLink="true">https://fargostreet.com/post/101154</guid><dc:creator><![CDATA[jct_4628]]></dc:creator><pubDate>Tue, 09 May 2006 16:15:04 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Tue, 09 May 2006 15:53:34 GMT]]></title><description><![CDATA[<p dir="auto">use a blow torch..........:p</p>
]]></description><link>https://fargostreet.com/post/101153</link><guid isPermaLink="true">https://fargostreet.com/post/101153</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Tue, 09 May 2006 15:53:34 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Tue, 09 May 2006 15:49:12 GMT]]></title><description><![CDATA[<p dir="auto">what do you heat the bolt with?</p>
]]></description><link>https://fargostreet.com/post/101152</link><guid isPermaLink="true">https://fargostreet.com/post/101152</guid><dc:creator><![CDATA[jct_4628]]></dc:creator><pubDate>Tue, 09 May 2006 15:49:12 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Tue, 09 May 2006 13:12:36 GMT]]></title><description><![CDATA[<p dir="auto">Impact gun</p>
]]></description><link>https://fargostreet.com/post/101140</link><guid isPermaLink="true">https://fargostreet.com/post/101140</guid><dc:creator><![CDATA[Fitzy]]></dc:creator><pubDate>Tue, 09 May 2006 13:12:36 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Tue, 09 May 2006 05:49:46 GMT]]></title><description><![CDATA[<p dir="auto">lollerskates</p>
<p dir="auto">I have found that just heating the bolt works 95% of the time</p>
]]></description><link>https://fargostreet.com/post/101121</link><guid isPermaLink="true">https://fargostreet.com/post/101121</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Tue, 09 May 2006 05:49:46 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Tue, 09 May 2006 05:46:22 GMT]]></title><description><![CDATA[<blockquote>
Bad idea.  If the bolt is not stripped you will strip it by using vice grips</p>
<p dir="auto">Not if you aren't a pussy.:icon_thumright:</p>
<p dir="auto">I am JK btw, use the vice grips as a last resort...</p>
]]></description><link>https://fargostreet.com/post/101120</link><guid isPermaLink="true">https://fargostreet.com/post/101120</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Tue, 09 May 2006 05:46:22 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Tue, 09 May 2006 05:34:41 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">91nbtsi wrote:<br />
Vise grips.</p>
<p dir="auto">Bad idea.  If the bolt is not stripped you will strip it by using vice grips</p>
]]></description><link>https://fargostreet.com/post/101119</link><guid isPermaLink="true">https://fargostreet.com/post/101119</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Tue, 09 May 2006 05:34:41 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Tue, 09 May 2006 04:34:50 GMT]]></title><description><![CDATA[<p dir="auto">soak it in a quality penetrating fluid like JB-80 or PB Blaster. then wrench on it, sometimes use a box end wrench and a cheater on the end of it to get really stubborn bolts out.</p>
<p dir="auto">next step is heat. heat it up then try wrenching on it. but dont forgot ya heated it up. it hurts. haha</p>
]]></description><link>https://fargostreet.com/post/101113</link><guid isPermaLink="true">https://fargostreet.com/post/101113</guid><dc:creator><![CDATA[moparguy]]></dc:creator><pubDate>Tue, 09 May 2006 04:34:50 GMT</pubDate></item><item><title><![CDATA[Reply to really tight bolt removal on Tue, 09 May 2006 04:07:33 GMT]]></title><description><![CDATA[<p dir="auto">Vise grips.</p>
]]></description><link>https://fargostreet.com/post/101112</link><guid isPermaLink="true">https://fargostreet.com/post/101112</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Tue, 09 May 2006 04:07:33 GMT</pubDate></item></channel></rss>
