<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[jiffy lube screw over]]></title><description><![CDATA[<p dir="auto">jiffy lube screwed the wrong people</p>
<p dir="auto"><a href="http://www.nbc4.tv/video/9152183/detail.html#" rel="nofollow ugc">http://www.nbc4.tv/video/9152183/detail.html#</a></p>
]]></description><link>https://fargostreet.com/topic/6506/jiffy-lube-screw-over</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 00:16:43 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/6506.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 May 2006 21:29:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to jiffy lube screw over on Mon, 22 May 2006 05:36:05 GMT]]></title><description><![CDATA[<p dir="auto">yeah, a friend of mine went to get an oil change there but for some reason his car was fucked up sometimes afterwards...  He recommended not to go there...</p>
]]></description><link>https://fargostreet.com/post/102484</link><guid isPermaLink="true">https://fargostreet.com/post/102484</guid><dc:creator><![CDATA[Spec_R]]></dc:creator><pubDate>Mon, 22 May 2006 05:36:05 GMT</pubDate></item><item><title><![CDATA[Reply to jiffy lube screw over on Mon, 22 May 2006 03:37:04 GMT]]></title><description><![CDATA[<p dir="auto">yeah jiffy lube sucks..i quit there after a week.</p>
]]></description><link>https://fargostreet.com/post/102455</link><guid isPermaLink="true">https://fargostreet.com/post/102455</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Mon, 22 May 2006 03:37:04 GMT</pubDate></item><item><title><![CDATA[Reply to jiffy lube screw over on Mon, 22 May 2006 00:06:46 GMT]]></title><description><![CDATA[<p dir="auto">Hahahah that's awesome.  There should really be more of this type of investigations.  I know I'd never go to a Jiffy Lube.</p>
]]></description><link>https://fargostreet.com/post/102428</link><guid isPermaLink="true">https://fargostreet.com/post/102428</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Mon, 22 May 2006 00:06:46 GMT</pubDate></item><item><title><![CDATA[Reply to jiffy lube screw over on Sun, 21 May 2006 22:53:38 GMT]]></title><description><![CDATA[<p dir="auto">Doh! Busted!</p>
]]></description><link>https://fargostreet.com/post/102420</link><guid isPermaLink="true">https://fargostreet.com/post/102420</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Sun, 21 May 2006 22:53:38 GMT</pubDate></item><item><title><![CDATA[Reply to jiffy lube screw over on Sun, 21 May 2006 21:33:05 GMT]]></title><description><![CDATA[<p dir="auto">So true. As for the fuel filter, it wasn't the top guys fault, it was the pit guy.</p>
<p dir="auto">When I worked at Jiffy lube, I never saw this happen. However, it is a crap ass place to work.</p>
<p dir="auto">When I worked in the pit, occasionally I would skip greasing zerks, but thats entirely jiffy lubes fault. You are expected to get the car out in 15 minutes, however, if there are 3 one tons in the shop at once, each with 12 or more fittings, It would take 10 minutes alone JUST to grease the zerks. At the same time, you would need to drain the oil, replace the filter, check the front and rear diff levels, transmission levels, and occasionally do fuel filters.</p>
<p dir="auto">No one I know of could physically do all of that in 15 minutes.</p>
<p dir="auto">Also, you need no mechanical background to work at jiffy lube. They would stick 16 year olds in the pit who don't even know what a drain plug looks like one there 2nd day.</p>
]]></description><link>https://fargostreet.com/post/102414</link><guid isPermaLink="true">https://fargostreet.com/post/102414</guid><dc:creator><![CDATA[94NDTA]]></dc:creator><pubDate>Sun, 21 May 2006 21:33:05 GMT</pubDate></item></channel></rss>
