<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[big boost problem!!!]]></title><description><![CDATA[<p dir="auto">i have been having this issue with my laser for a while but when i get on the gas it will build boost but the car just boggs and if i get of the gas and right back on it will be just fine i just need to figure this out...</p>
]]></description><link>https://fargostreet.com/topic/6591/big-boost-problem</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:34:24 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/6591.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 May 2006 00:17:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to big boost problem!!! on Tue, 30 May 2006 02:47:49 GMT]]></title><description><![CDATA[<p dir="auto">hrm, i dunno past the suggestions i've already fielded.  try posting on the newbie section of <a href="http://dsmtuners.com" rel="nofollow ugc">dsmtuners.com</a>, someone there is bound to know.</p>
]]></description><link>https://fargostreet.com/post/103365</link><guid isPermaLink="true">https://fargostreet.com/post/103365</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Tue, 30 May 2006 02:47:49 GMT</pubDate></item><item><title><![CDATA[Reply to big boost problem!!! on Tue, 30 May 2006 01:48:01 GMT]]></title><description><![CDATA[<p dir="auto">ok i wired in a 91+ coil,tansister and gauge cluster also a 91+ ecu( i have a 90) it made the boost problem stop for a bit but my tach still dont work i did everthing this site <a href="http://www.ecanfix.com/users/mdhamilton/ecuconversion.html" rel="nofollow ugc">http://www.ecanfix.com/users/mdhamilton/ecuconversion.html</a> had to say sombody plz help</p>
]]></description><link>https://fargostreet.com/post/103356</link><guid isPermaLink="true">https://fargostreet.com/post/103356</guid><dc:creator><![CDATA[GnArKiLl]]></dc:creator><pubDate>Tue, 30 May 2006 01:48:01 GMT</pubDate></item><item><title><![CDATA[Reply to big boost problem!!! on Mon, 29 May 2006 17:43:45 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://www.mitsubishigraveyard.com/" rel="nofollow ugc">http://www.mitsubishigraveyard.com/</a><br />
if you don't see it, call. chances are, they have it <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/103306</link><guid isPermaLink="true">https://fargostreet.com/post/103306</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Mon, 29 May 2006 17:43:45 GMT</pubDate></item><item><title><![CDATA[Reply to big boost problem!!! on Mon, 29 May 2006 17:17:56 GMT]]></title><description><![CDATA[<p dir="auto">thanx guys this just sux cuz i cant find any parts for a 90!!</p>
]]></description><link>https://fargostreet.com/post/103305</link><guid isPermaLink="true">https://fargostreet.com/post/103305</guid><dc:creator><![CDATA[GnArKiLl]]></dc:creator><pubDate>Mon, 29 May 2006 17:17:56 GMT</pubDate></item><item><title><![CDATA[Reply to big boost problem!!! on Mon, 29 May 2006 06:38:27 GMT]]></title><description><![CDATA[<p dir="auto">definately get yourself a logger or find someone who has one that you could use.  check your o2 voltages to see if the o2 sensor is working properly, and check for knock, and check your timing advance at low rpm.  check your ignition too, see if you can borrow someone elses ignition coil to see if that helps any.  check your alternator voltage and check for fluctuations which could mean a bad ground.  seriously tho dsmitis is right, there are so many things which could cause the symptoms you are getting.  its just a matter of getting all of the information you can (data logger, boost leak tester, etc.) and narrowing the problem down bit by bit.  you need to check out <a href="http://dsmtuners.com" rel="nofollow ugc">dsmtuners.com</a> if you haven't and search the newbie forums.  there is so much usefull information there it's silly.  this may not be something you will be able to diagnose and fix lickety split, so resign yourself to working at it until the problem is solved.  DSMs are great eh?</p>
]]></description><link>https://fargostreet.com/post/103288</link><guid isPermaLink="true">https://fargostreet.com/post/103288</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Mon, 29 May 2006 06:38:27 GMT</pubDate></item><item><title><![CDATA[Reply to big boost problem!!! on Mon, 29 May 2006 04:28:24 GMT]]></title><description><![CDATA[<p dir="auto">i mean if i rev it up and dump the clutch like im racing it never does it</p>
]]></description><link>https://fargostreet.com/post/103279</link><guid isPermaLink="true">https://fargostreet.com/post/103279</guid><dc:creator><![CDATA[GnArKiLl]]></dc:creator><pubDate>Mon, 29 May 2006 04:28:24 GMT</pubDate></item><item><title><![CDATA[Reply to big boost problem!!! on Mon, 29 May 2006 04:12:32 GMT]]></title><description><![CDATA[<p dir="auto">my car kinda does the same...but just studders a little bit...only cuz it runs so damn rich cuz my o2 and mas are bad.</p>
]]></description><link>https://fargostreet.com/post/103275</link><guid isPermaLink="true">https://fargostreet.com/post/103275</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Mon, 29 May 2006 04:12:32 GMT</pubDate></item><item><title><![CDATA[Reply to big boost problem!!! on Mon, 29 May 2006 02:51:23 GMT]]></title><description><![CDATA[<p dir="auto">how do i check for leaks</p>
]]></description><link>https://fargostreet.com/post/103271</link><guid isPermaLink="true">https://fargostreet.com/post/103271</guid><dc:creator><![CDATA[GnArKiLl]]></dc:creator><pubDate>Mon, 29 May 2006 02:51:23 GMT</pubDate></item><item><title><![CDATA[Reply to big boost problem!!! on Mon, 29 May 2006 02:49:01 GMT]]></title><description><![CDATA[<p dir="auto">sounds like you have a case of dsmotitis.  Seriously though, check your ignition system, your injectors, and check for boost leaks.</p>
]]></description><link>https://fargostreet.com/post/103270</link><guid isPermaLink="true">https://fargostreet.com/post/103270</guid><dc:creator><![CDATA[darkelvis]]></dc:creator><pubDate>Mon, 29 May 2006 02:49:01 GMT</pubDate></item><item><title><![CDATA[Reply to big boost problem!!! on Mon, 29 May 2006 02:35:17 GMT]]></title><description><![CDATA[<p dir="auto">no shaft play and yes i have a gauge im set at 15psi</p>
]]></description><link>https://fargostreet.com/post/103266</link><guid isPermaLink="true">https://fargostreet.com/post/103266</guid><dc:creator><![CDATA[GnArKiLl]]></dc:creator><pubDate>Mon, 29 May 2006 02:35:17 GMT</pubDate></item><item><title><![CDATA[Reply to big boost problem!!! on Mon, 29 May 2006 01:39:00 GMT]]></title><description><![CDATA[<p dir="auto">i think you might need to check your boost fluid :icon_thumright: :icon_thumleft:</p>
<p dir="auto">but on a more serious note check the turbo condition</p>
]]></description><link>https://fargostreet.com/post/103262</link><guid isPermaLink="true">https://fargostreet.com/post/103262</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Mon, 29 May 2006 01:39:00 GMT</pubDate></item><item><title><![CDATA[Reply to big boost problem!!! on Mon, 29 May 2006 00:47:21 GMT]]></title><description><![CDATA[<p dir="auto">check for boost leaks first.  also are you sure it's actually building boost, i mean do you have a boost gauge (stupid question but just making sure)?  if you have a data logger, check your timing retard and knock.  i had the same problem with my previous turbo.  the oil seals were blown and it had mega shaft play.  a new turbo solved my problem..  just some ideas on what to check.  im no dsm guru tho.  check <a href="http://dsmtuners.com" rel="nofollow ugc">dsmtuners.com</a> also, lots of info there.</p>
]]></description><link>https://fargostreet.com/post/103259</link><guid isPermaLink="true">https://fargostreet.com/post/103259</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Mon, 29 May 2006 00:47:21 GMT</pubDate></item></channel></rss>
