<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FS: B&amp;amp;M NewVolt &amp;amp; Kenne Bell Boost-a-Pump]]></title><description><![CDATA[<p dir="auto">Both have been used for roughly a year.  The NewVolt is for increasing voltage to your coil (for hotter spark), it is adjustable to provide from 15v up to 21v to the coil.</p>
<p dir="auto">The Boost-a-Pump is for increasing voltage to your fuel pump, which in turn makes the pump flow more.  It is also adjustable, and puts out from 12v to 18v, but also has a pressure switch so that the fuel pump gets 12v until you make 3 psi of boost, at 3 psi boost and above the voltage increases to 18v (or wherever you have it set).</p>
<p dir="auto"><a href="http://www.prostreetonline.com/buy/b&amp;m_new_volt_power_unit/" rel="nofollow ugc">http://www.prostreetonline.com/buy/b&amp;m_new_volt_power_unit/</a></p>
<p dir="auto"><a href="http://www.kennebell.net/accessories/boostapump/boostapump.htm" rel="nofollow ugc">http://www.kennebell.net/accessories/boostapump/boostapump.htm</a></p>
<p dir="auto">The NewVolt was ~$290 new - asking $140</p>
<p dir="auto">The Boost-a-Pump was ~$250 new - asking $125</p>
]]></description><link>https://fargostreet.com/topic/664/fs-b-amp-m-newvolt-amp-kenne-bell-boost-a-pump</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 09:43:56 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/664.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Oct 2004 14:06:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to FS: B&amp;amp;M NewVolt &amp;amp; Kenne Bell Boost-a-Pump on Tue, 02 Nov 2004 18:50:36 GMT]]></title><description><![CDATA[<p dir="auto">Boost-a-pump sold.  Price reduced on the New Volt to $125.</p>
]]></description><link>https://fargostreet.com/post/11216</link><guid isPermaLink="true">https://fargostreet.com/post/11216</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Tue, 02 Nov 2004 18:50:36 GMT</pubDate></item><item><title><![CDATA[Reply to FS: B&amp;amp;M NewVolt &amp;amp; Kenne Bell Boost-a-Pump on Mon, 01 Nov 2004 21:23:42 GMT]]></title><description><![CDATA[<p dir="auto">Somebody buy this crap already....</p>
]]></description><link>https://fargostreet.com/post/11080</link><guid isPermaLink="true">https://fargostreet.com/post/11080</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Mon, 01 Nov 2004 21:23:42 GMT</pubDate></item><item><title><![CDATA[Reply to FS: B&amp;amp;M NewVolt &amp;amp; Kenne Bell Boost-a-Pump on Fri, 29 Oct 2004 03:14:25 GMT]]></title><description><![CDATA[<p dir="auto">Actual pics:</p>
<p dir="auto"><img src="http://www.speedtoys.com/~daveh/ForSale/KenneBell.JPG" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://www.speedtoys.com/~daveh/ForSale/NewVolt.JPG" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/10761</link><guid isPermaLink="true">https://fargostreet.com/post/10761</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Fri, 29 Oct 2004 03:14:25 GMT</pubDate></item></channel></rss>
