<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&#x27;01 Honda Xr50 **new Addition**]]></title><description><![CDATA[<p dir="auto">I have an '01 XR50 for sale. It is stock. I replaced the shock/spring, exhaust and handlebars with pieces from an '06 model so they are brand new. Tires are very good. Plastic has wear on it. I'll post some pics when I can.</p>
<p dir="auto">$800</p>
<p dir="auto"><strong><strong>NEW ADDITION</strong></strong></p>
<p dir="auto">For an additional $800 ($1600 total, a new 50 is $1300), I will include and install my 108cc, 4spd, manual clutch motor in this '01 chassis. This is an 11HP motor vs. the stock 2.5HP. This motor includes the following:</p>
<p dir="auto">-108cc stroker with big valve race head<br />
-intake, 24mm carb and foam air filter<br />
-complete bottom end with 4 spd(1 down, 3 up) transmission<br />
-manual clutch set up<br />
-sprockets for the 4 speed transmission (14, 15, 16 &amp; 17)<br />
-jet kit for the carb<br />
-high volume oil pump<br />
-the cases are bored to accept the larger 54mm piston($100 value)</p>
<p dir="auto">This motor is COMPLETE!</p>
<p dir="auto">This does not include aftermarket exhaust.</p>
]]></description><link>https://fargostreet.com/topic/6691/01-honda-xr50-new-addition</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 13:19:12 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/6691.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Jun 2006 17:24:40 GMT</pubDate><ttl>60</ttl></channel></rss>
