<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My car and I]]></title><description><![CDATA[<p dir="auto">Hello everybody.  My name is Corey and i'm from Bismarck.  Here is my shitbox.  Enjoi</p>
<p dir="auto"><img src="http://i53.photobucket.com/albums/g79/meat_wagon/P5290008.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/topic/6705/my-car-and-i</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:04:20 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/6705.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Jun 2006 01:46:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My car and I on Mon, 26 Jun 2006 04:44:24 GMT]]></title><description><![CDATA[<p dir="auto">ha ha Cory its looks like a monster as allways...</p>
<p dir="auto">welcome to the forum.</p>
]]></description><link>https://fargostreet.com/post/106171</link><guid isPermaLink="true">https://fargostreet.com/post/106171</guid><dc:creator><![CDATA[PUREVIL-K20]]></dc:creator><pubDate>Mon, 26 Jun 2006 04:44:24 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Fri, 16 Jun 2006 04:50:25 GMT]]></title><description><![CDATA[<p dir="auto">Props on using e85...i brought it up a couple times here and got shot down each time...love seeing someone use it!</p>
]]></description><link>https://fargostreet.com/post/104901</link><guid isPermaLink="true">https://fargostreet.com/post/104901</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Fri, 16 Jun 2006 04:50:25 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Fri, 16 Jun 2006 04:14:19 GMT]]></title><description><![CDATA[<p dir="auto">welcome, and nice car!</p>
]]></description><link>https://fargostreet.com/post/104892</link><guid isPermaLink="true">https://fargostreet.com/post/104892</guid><dc:creator><![CDATA[1990TSI]]></dc:creator><pubDate>Fri, 16 Jun 2006 04:14:19 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Thu, 15 Jun 2006 00:54:14 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">91nbtsi wrote:<br />
What does your fuel burning cool have to do with your intake temps?  Aside from the small amount of heat transfer that will occur from your head to your intake during operation and any reversion...  Intake temps are dependent on the efficiency of your turbo, IC, and the temp of the intake into the turbo.</p>
<p dir="auto">Anyways though, E85 is higher octane and does have good potential.  But, like you say, you need more of it; about 1.5times as much IIRC.</p>
<p dir="auto">Now, E85 does burn cooler, but your intake temps aren't a direct result of this unless you are maybe sucking in exhaust gasses?? Your combustion and exhaust temps should be lower, which allows wilder tuning:icon_thumleft:</p>
<p dir="auto">I should get some bigger injectors and run the Yota on E85...:icon_scratch:<br />
It works on the same principal as Methanol but just not as effective.  Ethanol vaporizes with the incoming air to reduce intake temps.  The reason need to run 50% more fuel is to have some ethanol injected into the combustion chamber after the vaporization has occured.  Thats why on a car running methanol you don't need an intercooler or sometimes even a radiator.  The cooler the air coming in, the more power you can make.</p>
]]></description><link>https://fargostreet.com/post/104781</link><guid isPermaLink="true">https://fargostreet.com/post/104781</guid><dc:creator><![CDATA[Meat Wagon]]></dc:creator><pubDate>Thu, 15 Jun 2006 00:54:14 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Wed, 14 Jun 2006 21:50:48 GMT]]></title><description><![CDATA[<p dir="auto">E85 has about a 25-30% disparity in mileage compared to gasoline. Car and Driver tested a flex-fuel Tahoe with both fuels and consistently achieved higher mileage with 87 oct (E85 reduced driving range by about 100 miles). Albeit E85 did have slightly better performance, but the figures are insignificant at best.</p>
]]></description><link>https://fargostreet.com/post/104774</link><guid isPermaLink="true">https://fargostreet.com/post/104774</guid><dc:creator><![CDATA[3_Series]]></dc:creator><pubDate>Wed, 14 Jun 2006 21:50:48 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Wed, 14 Jun 2006 21:15:54 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Meat Wagon wrote:<br />
Sorry, but you're wrong.  If you want to compare octane ratings, e85 is rated at 105 octane.  I'm paying $2.49 a gallon right now for e85.  I beleive c16 is around $9-10 a gallon.  You do need to run more ethanol to equal the same amount of gas.  Anywhere from 20-50% more fuel.  I get about 22mpg on e85.  The best part of e85 is that it burns cool.  Last week on an 80 degree day my intake temp was 94 degrees.  After some spirited driving the intake manifold is room temperature to the touch.</p>
<p dir="auto">What does your fuel burning cool have to do with your intake temps?  Aside from the small amount of heat transfer that will occur from your head to your intake during operation and any reversion...  Intake temps are dependent on the efficiency of your turbo, IC, and the temp of the intake into the turbo.</p>
<p dir="auto">I should get some bigger injectors and run the Yota on E85...:icon_scratch:</p>
]]></description><link>https://fargostreet.com/post/104769</link><guid isPermaLink="true">https://fargostreet.com/post/104769</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Wed, 14 Jun 2006 21:15:54 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Wed, 14 Jun 2006 20:56:47 GMT]]></title><description><![CDATA[<blockquote>
wouldn't you pull more power with regular 93 or higher unleaded octane?  or just adding a little racing fuel to the tank too?  I believe E85 has lower power figures and worse gas mileage.</p>
<p dir="auto">Ry</p>
<p dir="auto">Sorry, but you're wrong.  If you want to compare octane ratings, e85 is rated at 105 octane.  I'm paying $2.49 a gallon right now for e85.  I beleive c16 is around $9-10 a gallon.  You do need to run more ethanol to equal the same amount of gas.  Anywhere from 20-50% more fuel.  I get about 22mpg on e85.  The best part of e85 is that it burns cool.  Last week on an 80 degree day my intake temp was 94 degrees.  After some spirited driving the intake manifold is room temperature to the touch.</p>
]]></description><link>https://fargostreet.com/post/104764</link><guid isPermaLink="true">https://fargostreet.com/post/104764</guid><dc:creator><![CDATA[Meat Wagon]]></dc:creator><pubDate>Wed, 14 Jun 2006 20:56:47 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Wed, 14 Jun 2006 03:04:25 GMT]]></title><description><![CDATA[<p dir="auto">It doesnt have low power figures you just need to run a little more rich than usual...people are converting their cars to it and having decent results because they can run an overhaul higher boost map...</p>
]]></description><link>https://fargostreet.com/post/104690</link><guid isPermaLink="true">https://fargostreet.com/post/104690</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Wed, 14 Jun 2006 03:04:25 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Wed, 14 Jun 2006 02:56:29 GMT]]></title><description><![CDATA[<p dir="auto">wouldn't you pull more power with regular 93 or higher unleaded octane?  or just adding a little racing fuel to the tank too?  I believe E85 has lower power figures and worse gas mileage.</p>
]]></description><link>https://fargostreet.com/post/104687</link><guid isPermaLink="true">https://fargostreet.com/post/104687</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Wed, 14 Jun 2006 02:56:29 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Tue, 13 Jun 2006 23:34:49 GMT]]></title><description><![CDATA[<blockquote>
pussy........<br />
hahahha  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/104677</link><guid isPermaLink="true">https://fargostreet.com/post/104677</guid><dc:creator><![CDATA[Meat Wagon]]></dc:creator><pubDate>Tue, 13 Jun 2006 23:34:49 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Tue, 13 Jun 2006 04:38:15 GMT]]></title><description><![CDATA[<p dir="auto">pussy........</p>
]]></description><link>https://fargostreet.com/post/104619</link><guid isPermaLink="true">https://fargostreet.com/post/104619</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Tue, 13 Jun 2006 04:38:15 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 22:36:15 GMT]]></title><description><![CDATA[<blockquote>
Sweet car!  You need to come up to Interstate so we can watch you spin out;) (on the street nights anyways)<br />
I prefer to keep it on the streets.:D</p>
]]></description><link>https://fargostreet.com/post/104584</link><guid isPermaLink="true">https://fargostreet.com/post/104584</guid><dc:creator><![CDATA[Meat Wagon]]></dc:creator><pubDate>Mon, 12 Jun 2006 22:36:15 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 14:00:50 GMT]]></title><description><![CDATA[<p dir="auto">Mmmm 5 lug!  Nice civic, more pictures please.</p>
]]></description><link>https://fargostreet.com/post/104542</link><guid isPermaLink="true">https://fargostreet.com/post/104542</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Mon, 12 Jun 2006 14:00:50 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 11:57:48 GMT]]></title><description><![CDATA[<p dir="auto">Sweet car!  You need to come up to Interstate so we can watch you spin out;) (on the street nights anyways)</p>
]]></description><link>https://fargostreet.com/post/104535</link><guid isPermaLink="true">https://fargostreet.com/post/104535</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Mon, 12 Jun 2006 11:57:48 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 10:33:52 GMT]]></title><description><![CDATA[<blockquote>
I can't find any thing to race.<br />
Thats cuz they all see your FMIC from two miles away and RUN! Nice car, nice setup!</p>
]]></description><link>https://fargostreet.com/post/104532</link><guid isPermaLink="true">https://fargostreet.com/post/104532</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Mon, 12 Jun 2006 10:33:52 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 04:29:31 GMT]]></title><description><![CDATA[<p dir="auto">Hi Corey.  <em>waves</em></p>
]]></description><link>https://fargostreet.com/post/104515</link><guid isPermaLink="true">https://fargostreet.com/post/104515</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 12 Jun 2006 04:29:31 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 03:32:51 GMT]]></title><description><![CDATA[<p dir="auto">That's a crazy setup!  Big props for running e85!!</p>
]]></description><link>https://fargostreet.com/post/104503</link><guid isPermaLink="true">https://fargostreet.com/post/104503</guid><dc:creator><![CDATA[Erik]]></dc:creator><pubDate>Mon, 12 Jun 2006 03:32:51 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 03:24:36 GMT]]></title><description><![CDATA[<p dir="auto">Not to change the thread but do you ever see a blue 1Gb Talon AWD with FMIC, 50 trim etc running around? I heard it was broken awhile ago but I want to find the guy that owns it because I kinda want it back haha...</p>
]]></description><link>https://fargostreet.com/post/104500</link><guid isPermaLink="true">https://fargostreet.com/post/104500</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Mon, 12 Jun 2006 03:24:36 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 03:20:21 GMT]]></title><description><![CDATA[<blockquote>
nice! nobody from bismarck ever shows their face, its hard to tell if theres any life over there...never really seen any cars from there</p>
<p dir="auto">There is no life over here.  I can't find any thing to race.  Once i get new axles i will be traveling for some action.</p>
]]></description><link>https://fargostreet.com/post/104499</link><guid isPermaLink="true">https://fargostreet.com/post/104499</guid><dc:creator><![CDATA[Meat Wagon]]></dc:creator><pubDate>Mon, 12 Jun 2006 03:20:21 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 03:17:15 GMT]]></title><description><![CDATA[<p dir="auto">nice! nobody from bismarck ever shows their face, its hard to tell if theres any life over there...never really seen any cars from there</p>
]]></description><link>https://fargostreet.com/post/104497</link><guid isPermaLink="true">https://fargostreet.com/post/104497</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Mon, 12 Jun 2006 03:17:15 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 02:56:50 GMT]]></title><description><![CDATA[<blockquote>
mods?</p>
<p dir="auto">.....</p>
<p dir="auto">Benson Sleeved 84mm b18C5<br />
B20 Crank<br />
CP Pistons<br />
Manley Rods<br />
ITR Cams<br />
VictorX Intake Mani<br />
MSD Pro Billet Distributor</p>
<p dir="auto">Ramhorn Mani<br />
t3 T67<br />
Big Intercooler<br />
Tial BOV<br />
Tial 38mm wastegate<br />
3in downpipe with 3in exhaust</p>
<p dir="auto">Bosch External Fuel Pump<br />
All steel braided fuel lines<br />
Hondata s300<br />
Runs on E85 fuel</p>
<p dir="auto">b16 trans<br />
itr diff<br />
RPS clutch<br />
ITR 5 lug<br />
M&amp;H 235/60/15 DOT's</p>
<p dir="auto">It made 472whp and 360tq on a dyno dynanmics machine on 24psi.  Dyno dynamics dyno's read lower than most.  Its comes out to about 527whp on a dynojet.  This was on E85 fuel.  Would have tuned on more than 24psi but the greddy Profec type S wouldn't go any higher on the 10lb wastegate spring.</p>
]]></description><link>https://fargostreet.com/post/104493</link><guid isPermaLink="true">https://fargostreet.com/post/104493</guid><dc:creator><![CDATA[Meat Wagon]]></dc:creator><pubDate>Mon, 12 Jun 2006 02:56:50 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 02:40:53 GMT]]></title><description><![CDATA[<p dir="auto">welcome to the boards!</p>
]]></description><link>https://fargostreet.com/post/104490</link><guid isPermaLink="true">https://fargostreet.com/post/104490</guid><dc:creator><![CDATA[smtomps1955]]></dc:creator><pubDate>Mon, 12 Jun 2006 02:40:53 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 02:37:30 GMT]]></title><description><![CDATA[<p dir="auto">Welcome to Fargostreet!</p>
]]></description><link>https://fargostreet.com/post/104489</link><guid isPermaLink="true">https://fargostreet.com/post/104489</guid><dc:creator><![CDATA[HandoEX]]></dc:creator><pubDate>Mon, 12 Jun 2006 02:37:30 GMT</pubDate></item><item><title><![CDATA[Reply to My car and I on Mon, 12 Jun 2006 02:06:13 GMT]]></title><description><![CDATA[<p dir="auto">That is titties.</p>
]]></description><link>https://fargostreet.com/post/104483</link><guid isPermaLink="true">https://fargostreet.com/post/104483</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Mon, 12 Jun 2006 02:06:13 GMT</pubDate></item></channel></rss>
