<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FS: MTX Amp]]></title><description><![CDATA[<p dir="auto">For Sale: 425 watt mtx 2 channel amp..sold my subs so i dont need the amp...first $100 takes it</p>
<p dir="auto">here are the specs..</p>
<p dir="auto">THUNDER8302<br />
RMS Power measured at 12.5 Volts DC:<br />
75 Watts x 2 into a 4 Ohm load with less than 0.1% Thd+N<br />
150 Watts x 2 into a 2 Ohm load with less than 0.1% Thd+N<br />
300 Watts bridged into a 4 Ohm load with less than 0.1% Thd+N<br />
Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC<br />
120 Watts x 2 into a 4 Ohm load<br />
212 Watts x 2 into a 2 Ohm load<br />
425 Watts bridged into a 4 Ohm load<br />
Signal to Noise Ratio: ≥110dB A-Weighted<br />
Damping Factor: &gt;200<br />
Frequency Response: 20Hz-20kHz ± 0.25dB<br />
Maximum Input: 8Vrms<br />
Thunder EQ: Variable Bass Boost (0-18dB) centered at 40Hz<br />
Crossover: Variable 40Hz to 200Hz, 12dB/octave high pass,<br />
24dB/octave low pass with mono output<br />
Dimensions: 9.2" x 9.75" x 2" (22.8cm x 22.8cm x 5.1cm)<br />
11.5" x 9.75" x 2.1" (29.2cm x 24.8cm x 5.3cm) Including IsoFeet<img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/2122.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--tm" style="height:23px;width:auto;vertical-align:middle" title="™" alt="™" /></p>
]]></description><link>https://fargostreet.com/topic/6883/fs-mtx-amp</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:33:11 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/6883.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 29 Jun 2006 01:24:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to FS: MTX Amp on Sat, 29 Jul 2006 22:16:43 GMT]]></title><description><![CDATA[<p dir="auto">amp is sold...mods can close thread</p>
]]></description><link>https://fargostreet.com/post/110422</link><guid isPermaLink="true">https://fargostreet.com/post/110422</guid><dc:creator><![CDATA[wo1fpack2004]]></dc:creator><pubDate>Sat, 29 Jul 2006 22:16:43 GMT</pubDate></item><item><title><![CDATA[Reply to FS: MTX Amp on Sat, 22 Jul 2006 14:45:28 GMT]]></title><description><![CDATA[<p dir="auto">u wanna trade for the psp yet?</p>
]]></description><link>https://fargostreet.com/post/109397</link><guid isPermaLink="true">https://fargostreet.com/post/109397</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Sat, 22 Jul 2006 14:45:28 GMT</pubDate></item><item><title><![CDATA[Reply to FS: MTX Amp on Fri, 21 Jul 2006 23:15:55 GMT]]></title><description><![CDATA[<p dir="auto">free 12" sub box with purchase of amp</p>
]]></description><link>https://fargostreet.com/post/109334</link><guid isPermaLink="true">https://fargostreet.com/post/109334</guid><dc:creator><![CDATA[wo1fpack2004]]></dc:creator><pubDate>Fri, 21 Jul 2006 23:15:55 GMT</pubDate></item><item><title><![CDATA[Reply to FS: MTX Amp on Fri, 14 Jul 2006 19:38:29 GMT]]></title><description><![CDATA[<p dir="auto">what do u have to trade?</p>
]]></description><link>https://fargostreet.com/post/108450</link><guid isPermaLink="true">https://fargostreet.com/post/108450</guid><dc:creator><![CDATA[wo1fpack2004]]></dc:creator><pubDate>Fri, 14 Jul 2006 19:38:29 GMT</pubDate></item><item><title><![CDATA[Reply to FS: MTX Amp on Fri, 14 Jul 2006 14:06:10 GMT]]></title><description><![CDATA[<p dir="auto">What are you looking for on trade. I will be up to minot on tuesday or weds.</p>
]]></description><link>https://fargostreet.com/post/108436</link><guid isPermaLink="true">https://fargostreet.com/post/108436</guid><dc:creator><![CDATA[95TsiAWD]]></dc:creator><pubDate>Fri, 14 Jul 2006 14:06:10 GMT</pubDate></item><item><title><![CDATA[Reply to FS: MTX Amp on Sat, 01 Jul 2006 20:37:22 GMT]]></title><description><![CDATA[<p dir="auto">bummmmp....</p>
]]></description><link>https://fargostreet.com/post/107072</link><guid isPermaLink="true">https://fargostreet.com/post/107072</guid><dc:creator><![CDATA[wo1fpack2004]]></dc:creator><pubDate>Sat, 01 Jul 2006 20:37:22 GMT</pubDate></item><item><title><![CDATA[Reply to FS: MTX Amp on Thu, 29 Jun 2006 02:53:53 GMT]]></title><description><![CDATA[<p dir="auto">trades considered</p>
]]></description><link>https://fargostreet.com/post/106655</link><guid isPermaLink="true">https://fargostreet.com/post/106655</guid><dc:creator><![CDATA[wo1fpack2004]]></dc:creator><pubDate>Thu, 29 Jun 2006 02:53:53 GMT</pubDate></item></channel></rss>
