<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[electrical problem]]></title><description><![CDATA[<p dir="auto">wondering if anyone had any advice on this one or knew where to start.   I installed some speakers in a 91 ford explorer and now the dome lights won't turn off.  my thoughts are that I maybe broke a door sensor when I was messing with the doors or am back feeding power into that fuse, since the radio and dome lights are on the same one.    any thoughts?</p>
]]></description><link>https://fargostreet.com/topic/6927/electrical-problem</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 22:46:24 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/6927.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Jul 2006 22:24:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to electrical problem on Wed, 05 Jul 2006 04:12:33 GMT]]></title><description><![CDATA[<p dir="auto">Try disconnecting the switch and taping up the connector.  That should also turn off the light.</p>
]]></description><link>https://fargostreet.com/post/107365</link><guid isPermaLink="true">https://fargostreet.com/post/107365</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Wed, 05 Jul 2006 04:12:33 GMT</pubDate></item><item><title><![CDATA[Reply to electrical problem on Wed, 05 Jul 2006 01:33:12 GMT]]></title><description><![CDATA[<p dir="auto">well got it figured out, one of my rear door sensors seperated from it's mount.  so now I guess I'll have to find another one, just taped the two parts for now.  but atleast my dome lights turn off without pulling the fuse:&gt;</p>
]]></description><link>https://fargostreet.com/post/107360</link><guid isPermaLink="true">https://fargostreet.com/post/107360</guid><dc:creator><![CDATA[lord_deastofact]]></dc:creator><pubDate>Wed, 05 Jul 2006 01:33:12 GMT</pubDate></item><item><title><![CDATA[Reply to electrical problem on Tue, 04 Jul 2006 22:20:00 GMT]]></title><description><![CDATA[<p dir="auto">Its the door switches.  I believe that they are in the latch on the rear doors and there is a plunger for hte switch on the front doors.  Take the latches out and clean them up and then spray them with a silicon lubricant and the problem will be gone.</p>
]]></description><link>https://fargostreet.com/post/107351</link><guid isPermaLink="true">https://fargostreet.com/post/107351</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Tue, 04 Jul 2006 22:20:00 GMT</pubDate></item><item><title><![CDATA[Reply to electrical problem on Tue, 04 Jul 2006 02:57:27 GMT]]></title><description><![CDATA[<p dir="auto">bingo, retrace your wires you are using, or use different power/grounds.  if that doesn't work, then check out or door switches, and disconnect each one individually.</p>
<p dir="auto">Ry</p>
]]></description><link>https://fargostreet.com/post/107273</link><guid isPermaLink="true">https://fargostreet.com/post/107273</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Tue, 04 Jul 2006 02:57:27 GMT</pubDate></item></channel></rss>
