<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rotary help]]></title><description><![CDATA[<p dir="auto">Here's my problem: It used to be when my car warmed up it started sputtering and lossing a lot of power. It would feel like I was running on one rotar for a while and then run like nothing was wrong. I figured I wasn't getting enough spark because of all  the unburned fuel I smelled. I thought this to be a grounding issue so I went through and tightened and cleand my grounds. It helped but didn't solve. Now I can't even engage my clutch in gear without my car stalling out on me. In neutral it'll idle (kind of) and rev, but as soon as I engage the clutch the car will just lose all power and die. Can any one help me on this?</p>
]]></description><link>https://fargostreet.com/topic/6990/rotary-help</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:05:59 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/6990.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Jul 2006 20:15:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rotary help on Tue, 11 Jul 2006 20:54:15 GMT]]></title><description><![CDATA[<p dir="auto">I don't have any rotary-specific experience but the first thing I'd look at is the electrical and the fuel system.  Check your plugs, plug wires.  If you're smelling unburned fuel maybe you have a sticking/leaky injector.  A bottle of fuel system cleaner might be beneficial.</p>
]]></description><link>https://fargostreet.com/post/108177</link><guid isPermaLink="true">https://fargostreet.com/post/108177</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 11 Jul 2006 20:54:15 GMT</pubDate></item></channel></rss>
