<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What should I go with???]]></title><description><![CDATA[<p dir="auto">Well i think i have narrowed it down to two engines for my 89 CRX.<br />
-B20B or B16A.<br />
The car is going to be a daily driver but i would also like to be able to Auto X it and Drag it every now and again.. On the track i would like to run mid 13's to low 14's. The two engines are on the link below. Let me know what you think!!</p>
<p dir="auto"><a href="http://www.hmotorsonline.com/shop/sc2000search.cgi?what=category&amp;keyword=JDM%20USDM%20Engines&amp;hit=20" rel="nofollow ugc">http://www.hmotorsonline.com/shop/sc2000search.cgi?what=category&amp;keyword=JDM%20USDM%20Engines&amp;hit=20</a></p>
]]></description><link>https://fargostreet.com/topic/7103/what-should-i-go-with</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 23:58:53 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/7103.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 22 Jul 2006 23:01:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What should I go with??? on Fri, 04 Aug 2006 22:06:24 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">BumpinJCC wrote:<br />
not what i heard..<br />
Stock exhaust from the d16 and before I had my header.</p>
<p dir="auto">Launch; I would take a length or two in first then Matt would catch me at the end of 2nd and pull into third.</p>
<p dir="auto">Fuck it I really don't care.:icon_salut:</p>
]]></description><link>https://fargostreet.com/post/111122</link><guid isPermaLink="true">https://fargostreet.com/post/111122</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Fri, 04 Aug 2006 22:06:24 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Fri, 04 Aug 2006 21:59:46 GMT]]></title><description><![CDATA[<p dir="auto">not what i heard..</p>
]]></description><link>https://fargostreet.com/post/111121</link><guid isPermaLink="true">https://fargostreet.com/post/111121</guid><dc:creator><![CDATA[DelSlow]]></dc:creator><pubDate>Fri, 04 Aug 2006 21:59:46 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Fri, 04 Aug 2006 20:15:27 GMT]]></title><description><![CDATA[<blockquote>
Ur happy with 150 Across???<br />
It kept up with Matt's hatch just fine and that ran a 14.3</p>
]]></description><link>https://fargostreet.com/post/111115</link><guid isPermaLink="true">https://fargostreet.com/post/111115</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Fri, 04 Aug 2006 20:15:27 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Wed, 02 Aug 2006 21:35:48 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">torbs wrote:<br />
I believe he told me that he wasn't looking for boost. He's just looking for a good daily motor that can pull a low 14. A strong stock b16 will get that done for him. And judging by his budget, he doesnt have the $ to buy a d-series swap ($300-400 for a motor and $50-100ish for a Si tranny), buy the engine management (safc would be sufficient, which is cheap $100 for a used safc1), plus the turbo kit too...OBD0 b16 swap can be held for $1500...you just have to look. It's also a bit cheaper bc it's a cable tranny. He can also just then buy a stock JDM obd0 vtec ECU after swapping in the motor and be done...sure, is a boosted d-series faster? hell yea...but he didn't ask for anything that's crazy fast...just something quick that's fairly easy...</p>
<p dir="auto">B16 FTW!</p>
<p dir="auto">and if nothing else, just say you bought the b16 bc it has CRAZY mad loud JDM VTACK y0:icon_cheers: :icon_thumright:</p>
<p dir="auto">My .02  is b16/b18 with N2O.   It is a daily driver and you want reliability just drop a stock motor and leave it stock and then spray at the drags. Done easy swap not retradedly expencive.  It is a simple plan.</p>
]]></description><link>https://fargostreet.com/post/110869</link><guid isPermaLink="true">https://fargostreet.com/post/110869</guid><dc:creator><![CDATA[Hatchling]]></dc:creator><pubDate>Wed, 02 Aug 2006 21:35:48 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Wed, 02 Aug 2006 21:30:56 GMT]]></title><description><![CDATA[<blockquote>
my .o2 buy a z6 or y8 and put head studs in and boost it too 10 psi or build it for around 1000.00 pistons/rods/bearings.... and run 20 psi+</p>
<p dir="auto">I made 250 whp on 10 psi and ran 12.2@113 tufte made 261whp and ran 11.9@113  there is no all motor B20's b18's b16's that can compete with the D16 boosted  it would probly cost your about the same to do a swap or boost a D16..</p>
<p dir="auto">My D16 now makes 400 whp depending which dyno your on some read low and some high.. and runs 11.5 @125</p>
<p dir="auto">Looks like my d-16 hatch is the quickest and fastest honda around.!!!!</p>
<p dir="auto">How does it stop and turn??</p>
]]></description><link>https://fargostreet.com/post/110867</link><guid isPermaLink="true">https://fargostreet.com/post/110867</guid><dc:creator><![CDATA[Hatchling]]></dc:creator><pubDate>Wed, 02 Aug 2006 21:30:56 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Wed, 02 Aug 2006 12:49:39 GMT]]></title><description><![CDATA[<p dir="auto">Ur happy with 150 Across???</p>
]]></description><link>https://fargostreet.com/post/110830</link><guid isPermaLink="true">https://fargostreet.com/post/110830</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 02 Aug 2006 12:49:39 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Wed, 02 Aug 2006 00:25:40 GMT]]></title><description><![CDATA[<blockquote>
^ Was that with axles ECU and all the goodies? If so thats a good deal, considering it came with hasports. That and where was it shipped to? Your door?<br />
It was $1300 shipped to Matt's place w/ mounts.  The swap + goodies cost me $2300 total.</p>
<p dir="auto">Axles, Haft shaft, Shift linkage, Exedy S1 clutch, CTR valve cover, Vison CF spark plug cover, Bronze DC headers, random nuts and bolts.</p>
<p dir="auto">All and all I'm happy with it.:icon_thumright:</p>
]]></description><link>https://fargostreet.com/post/110760</link><guid isPermaLink="true">https://fargostreet.com/post/110760</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Wed, 02 Aug 2006 00:25:40 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Tue, 01 Aug 2006 23:49:19 GMT]]></title><description><![CDATA[<p dir="auto">i have a buddy who is swappin a JDM D15b into his 91 crx si should be a nice little swap</p>
]]></description><link>https://fargostreet.com/post/110755</link><guid isPermaLink="true">https://fargostreet.com/post/110755</guid><dc:creator><![CDATA[GHETTOBEAST]]></dc:creator><pubDate>Tue, 01 Aug 2006 23:49:19 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Tue, 01 Aug 2006 20:39:45 GMT]]></title><description><![CDATA[<p dir="auto">^ Was that with axles ECU and all the goodies? If so thats a good deal, considering it came with hasports. That and where was it shipped to? Your door?</p>
]]></description><link>https://fargostreet.com/post/110739</link><guid isPermaLink="true">https://fargostreet.com/post/110739</guid><dc:creator><![CDATA[DelSlow]]></dc:creator><pubDate>Tue, 01 Aug 2006 20:39:45 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Tue, 01 Aug 2006 20:36:34 GMT]]></title><description><![CDATA[<p dir="auto">A LS w/B16 tranny, now thats a good cheap combo. My JDM B16a from Hmotorsonline cost $1300 shipped w/Hasport mounts.  Then you need, Clutch $250+, Flywheel resurfaced $35, Axles $200, Shift linkage $150, And I would say another $200 for fluids/seals/random shit.</p>
<p dir="auto">I would say a full LS swap w/b16 tranny &amp; clutch would run you around $1300 for a strong LS.</p>
<p dir="auto">If I could do it all again I think I would have went with a 100% stock JDM D15b vtec.  Hope this helps.</p>
]]></description><link>https://fargostreet.com/post/110736</link><guid isPermaLink="true">https://fargostreet.com/post/110736</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Tue, 01 Aug 2006 20:36:34 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Mon, 24 Jul 2006 12:37:46 GMT]]></title><description><![CDATA[<blockquote>
Not to mention an LS motor is easily as fast as a B16, if not faster!<br />
definitly agree. Way better and more usable power band... Then, eventually, U could always go LS-vtec.</p>
<p dir="auto">The b20 would be cool since no one has one around here... but It's gonna cost u more. U ever thought about a dual cam ZC swap. they make 140hp at the crank, same as an ls, and the cool thing is u can use your D series tranny! this way, U can save money by just buying the block.</p>
]]></description><link>https://fargostreet.com/post/109660</link><guid isPermaLink="true">https://fargostreet.com/post/109660</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Mon, 24 Jul 2006 12:37:46 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Mon, 24 Jul 2006 05:39:44 GMT]]></title><description><![CDATA[<p dir="auto">Not to mention an LS motor is easily as fast as a B16, if not faster!</p>
]]></description><link>https://fargostreet.com/post/109641</link><guid isPermaLink="true">https://fargostreet.com/post/109641</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Mon, 24 Jul 2006 05:39:44 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Mon, 24 Jul 2006 04:30:28 GMT]]></title><description><![CDATA[<p dir="auto">I like troy's idea the most...LS torque is very nice for DD...and if you want, LS's are known for liking boost also.</p>
]]></description><link>https://fargostreet.com/post/109637</link><guid isPermaLink="true">https://fargostreet.com/post/109637</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Mon, 24 Jul 2006 04:30:28 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Mon, 24 Jul 2006 02:43:20 GMT]]></title><description><![CDATA[<p dir="auto">I've said this like 50 times before when people ask for opinions on Honda swaps, and here is mine: complete LS motor/trans swap should run you less than $1000, or buy a whole wrecked integra to take everything out of and then part out the rest of the car, and then get some small slicks, and a small shot of nitrous like a 50 or maybe 75 shot, and you'll run low 13s for very little money.  If you can find a good deal on a wrecked integra that you can part out, you will basically get all the parts you want for free, I've done it, twice.</p>
]]></description><link>https://fargostreet.com/post/109615</link><guid isPermaLink="true">https://fargostreet.com/post/109615</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Mon, 24 Jul 2006 02:43:20 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Sun, 23 Jul 2006 23:36:57 GMT]]></title><description><![CDATA[<blockquote>
You seem to have a good attitude towards stuff. Keep it up!<br />
Thanks! I try to learn things and stuff like that before i step into something i dont know nething about. I dont think there is a better local forum then this to ask questions and recieve feedback.....</p>
]]></description><link>https://fargostreet.com/post/109587</link><guid isPermaLink="true">https://fargostreet.com/post/109587</guid><dc:creator><![CDATA[DWeigs]]></dc:creator><pubDate>Sun, 23 Jul 2006 23:36:57 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Sun, 23 Jul 2006 23:19:19 GMT]]></title><description><![CDATA[<p dir="auto">You seem to have a good attitude towards stuff. Keep it up!</p>
]]></description><link>https://fargostreet.com/post/109586</link><guid isPermaLink="true">https://fargostreet.com/post/109586</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Sun, 23 Jul 2006 23:19:19 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Sun, 23 Jul 2006 23:14:49 GMT]]></title><description><![CDATA[<p dir="auto">Im still young and learning a lot from a lot of different people.... So the more i listen and people tell me things the more i want to do... So keep the suggestions coming if there is any left to give...<br />
Thanks a lot to all of you who helped me out!!</p>
]]></description><link>https://fargostreet.com/post/109585</link><guid isPermaLink="true">https://fargostreet.com/post/109585</guid><dc:creator><![CDATA[DWeigs]]></dc:creator><pubDate>Sun, 23 Jul 2006 23:14:49 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Sun, 23 Jul 2006 23:11:25 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">96Talon wrote:<br />
Well my budget is depending on it i can sell my current car and then i will have a little more to spend.... I would like to run something faster. But i want to spend less then $1500. I have been talking to some people about the D series motor boosted and it sounds kind of kool..</p>
<p dir="auto">Hands down, the best for your money.</p>
]]></description><link>https://fargostreet.com/post/109584</link><guid isPermaLink="true">https://fargostreet.com/post/109584</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Sun, 23 Jul 2006 23:11:25 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Sun, 23 Jul 2006 23:05:41 GMT]]></title><description><![CDATA[<p dir="auto">Well my budget is depending on it i can sell my current car and then i will have a little more to spend.... I would like to run something faster. But i want to spend less then $1500. I have been talking to some people about the D series motor boosted and it sounds kind of kool..</p>
]]></description><link>https://fargostreet.com/post/109583</link><guid isPermaLink="true">https://fargostreet.com/post/109583</guid><dc:creator><![CDATA[DWeigs]]></dc:creator><pubDate>Sun, 23 Jul 2006 23:05:41 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Sun, 23 Jul 2006 22:14:39 GMT]]></title><description><![CDATA[<p dir="auto">I believe he told me that he wasn't looking for boost. He's just looking for a good daily motor that can pull a low 14. A strong stock b16 will get that done for him. And judging by his budget, he doesnt have the $ to buy a d-series swap ($300-400 for a motor and $50-100ish for a Si tranny), buy the engine management (safc would be sufficient, which is cheap $100 for a used safc1), plus the turbo kit too...OBD0 b16 swap can be held for $1500...you just have to look. It's also a bit cheaper bc it's a cable tranny. He can also just then buy a stock JDM obd0 vtec ECU after swapping in the motor and be done...sure, is a boosted d-series faster? hell yea...but he didn't ask for anything that's crazy fast...just something quick that's fairly easy...</p>
]]></description><link>https://fargostreet.com/post/109579</link><guid isPermaLink="true">https://fargostreet.com/post/109579</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Sun, 23 Jul 2006 22:14:39 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Sun, 23 Jul 2006 19:47:03 GMT]]></title><description><![CDATA[<blockquote>
there is no all motor B20's b18's b16's that can compete with the D16 boosted  it would probly cost your about the same to do a swap or boost a D16.</p>
<p dir="auto">my thoughts too.  for budget minded people, D16Z6 is the way to go, boosted!!!  If you are on a serious budget, you'll have to settle for a swap and nothing else.</p>
<p dir="auto">Ry</p>
]]></description><link>https://fargostreet.com/post/109570</link><guid isPermaLink="true">https://fargostreet.com/post/109570</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Sun, 23 Jul 2006 19:47:03 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Sun, 23 Jul 2006 19:17:27 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Looks like my d-16 hatch is the quickest and fastest honda around.!!!!<br />
you are cocky</p>
]]></description><link>https://fargostreet.com/post/109566</link><guid isPermaLink="true">https://fargostreet.com/post/109566</guid><dc:creator><![CDATA[STiSchucky]]></dc:creator><pubDate>Sun, 23 Jul 2006 19:17:27 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Sun, 23 Jul 2006 18:26:18 GMT]]></title><description><![CDATA[<p dir="auto">my .o2 buy a z6 or y8 and put head studs in and boost it too 10 psi or build it for around 1000.00 pistons/rods/bearings.... and run 20 psi+</p>
]]></description><link>https://fargostreet.com/post/109560</link><guid isPermaLink="true">https://fargostreet.com/post/109560</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Sun, 23 Jul 2006 18:26:18 GMT</pubDate></item><item><title><![CDATA[Reply to What should I go with??? on Sun, 23 Jul 2006 04:13:09 GMT]]></title><description><![CDATA[<blockquote>
Id go with the B20, get ya nice torque out of that, plus easy to mod with a bigger motor....if money wasn't an issue, you all know what id say....go K series <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
<p dir="auto">edit: ya, Id say go with the B20 and get higher compression pistons.  You'll see a huge gain in power/torque out of that motor compared to the B16.  Plus it is essentially cheaper at first.<br />
my homies plan was just to do a B20 and up the compression, then it turned into a full scale build, because once you dig into the bottom end, you miight as well rebuild the block...then the head...then everything else...</p>
<p dir="auto">Anyways, B16s are fun out of the box. Good transmission, decent power, loud ass VTEC. B20s are cheap, yeah. But you need to buy a different tranny, different intake manifold, and some other shit just to make it swapable...The price will probobly equal out...</p>
<p dir="auto">I'd go with the B16. It will be more fun, less work, and more daily drivable...</p>
]]></description><link>https://fargostreet.com/post/109504</link><guid isPermaLink="true">https://fargostreet.com/post/109504</guid><dc:creator><![CDATA[vart]]></dc:creator><pubDate>Sun, 23 Jul 2006 04:13:09 GMT</pubDate></item></channel></rss>
