<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Weights and weight bench.]]></title><description><![CDATA[<p dir="auto">I'm upgrading to an Olympic set.</p>
<p dir="auto">Weider 138 bench<br />
Standard bar (30lbs)<br />
Standard EZ curl bar<br />
2 Standard dumbbell handles</p>
<p dir="auto">All weights standard<br />
2 50 lb weights<br />
2 25 lb weights<br />
4 10 lb weights<br />
4 5 lb weights<br />
4 2.5 lb weights<br />
2 1 1/4 lb weights</p>
<p dir="auto">$150 obo.</p>
]]></description><link>https://fargostreet.com/topic/7583/weights-and-weight-bench.</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 04:36:56 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/7583.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 Sep 2006 21:52:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Weights and weight bench. on Fri, 08 Sep 2006 16:39:13 GMT]]></title><description><![CDATA[<p dir="auto">Bump, still for sale, will take offers...</p>
]]></description><link>https://fargostreet.com/post/116112</link><guid isPermaLink="true">https://fargostreet.com/post/116112</guid><dc:creator><![CDATA[94NDTA]]></dc:creator><pubDate>Fri, 08 Sep 2006 16:39:13 GMT</pubDate></item><item><title><![CDATA[Reply to Weights and weight bench. on Wed, 06 Sep 2006 16:06:37 GMT]]></title><description><![CDATA[<blockquote>
I had one like that and the position of the pedastals were right where a normal bench grip would be located...is this one like that?<br />
Somewhat. If you have a really wide grip when benching, it wouldn't be for you, but if you keep your lifts normal, it works just fine.</p>
]]></description><link>https://fargostreet.com/post/115657</link><guid isPermaLink="true">https://fargostreet.com/post/115657</guid><dc:creator><![CDATA[94NDTA]]></dc:creator><pubDate>Wed, 06 Sep 2006 16:06:37 GMT</pubDate></item><item><title><![CDATA[Reply to Weights and weight bench. on Wed, 06 Sep 2006 12:24:03 GMT]]></title><description><![CDATA[<p dir="auto">You will get huge using this bench!</p>
]]></description><link>https://fargostreet.com/post/115622</link><guid isPermaLink="true">https://fargostreet.com/post/115622</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Wed, 06 Sep 2006 12:24:03 GMT</pubDate></item><item><title><![CDATA[Reply to Weights and weight bench. on Wed, 06 Sep 2006 02:59:04 GMT]]></title><description><![CDATA[<p dir="auto">I had one like that and the position of the pedastals were right where a normal bench grip would be located...is this one like that?</p>
]]></description><link>https://fargostreet.com/post/115577</link><guid isPermaLink="true">https://fargostreet.com/post/115577</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Wed, 06 Sep 2006 02:59:04 GMT</pubDate></item><item><title><![CDATA[Reply to Weights and weight bench. on Tue, 05 Sep 2006 22:17:43 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://img.epinions.com/images/opti/dd/29/Weider_138_Bench_Exercise_Equipment1.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
It has the side peices and the leg peices, but I never put them on.</p>
]]></description><link>https://fargostreet.com/post/115500</link><guid isPermaLink="true">https://fargostreet.com/post/115500</guid><dc:creator><![CDATA[94NDTA]]></dc:creator><pubDate>Tue, 05 Sep 2006 22:17:43 GMT</pubDate></item><item><title><![CDATA[Reply to Weights and weight bench. on Tue, 05 Sep 2006 21:58:22 GMT]]></title><description><![CDATA[<p dir="auto">of the bench</p>
]]></description><link>https://fargostreet.com/post/115492</link><guid isPermaLink="true">https://fargostreet.com/post/115492</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Tue, 05 Sep 2006 21:58:22 GMT</pubDate></item><item><title><![CDATA[Reply to Weights and weight bench. on Tue, 05 Sep 2006 21:57:56 GMT]]></title><description><![CDATA[<p dir="auto">possible to take some pictures?</p>
]]></description><link>https://fargostreet.com/post/115491</link><guid isPermaLink="true">https://fargostreet.com/post/115491</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Tue, 05 Sep 2006 21:57:56 GMT</pubDate></item></channel></rss>
