<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[5 hp 480 volt 3 ph motor for free]]></title><description><![CDATA[<p dir="auto">I just got a screamin deal on an air compressor.  But I only have single phase 220  so I bought a new motor.   It's just taking up room so if you need it it's free, yours for the taking.</p>
]]></description><link>https://fargostreet.com/topic/7714/5-hp-480-volt-3-ph-motor-for-free</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 07:02:36 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/7714.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 Sep 2006 03:34:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 5 hp 480 volt 3 ph motor for free on Fri, 15 Sep 2006 23:40:29 GMT]]></title><description><![CDATA[<p dir="auto">it's a little older,  but works good,  it's a heavy bastard, probably 75 lbs +, I think the shaft is an inch in diameter, but I'll have to look. No splines, just a keyway. I would say it's approx. 18" long and 12" in diameter. It also has a magnetic starter control box if someone wants it. If someone's really interested I can run to glyndon and get some definite dimensions and pictures. But how can you go wrong with free??</p>
]]></description><link>https://fargostreet.com/post/117636</link><guid isPermaLink="true">https://fargostreet.com/post/117636</guid><dc:creator><![CDATA[rustychevy]]></dc:creator><pubDate>Fri, 15 Sep 2006 23:40:29 GMT</pubDate></item><item><title><![CDATA[Reply to 5 hp 480 volt 3 ph motor for free on Fri, 15 Sep 2006 13:33:54 GMT]]></title><description><![CDATA[<p dir="auto">How many inches from front to back and side to side?  output shaft size and number of splines, if any. Is there a switch or control box of any sort?  What color is it?  Who is your daddy and what does he do?</p>
<p dir="auto">re-enema: how big is your cornhole if you had to have a second enema?</p>
]]></description><link>https://fargostreet.com/post/117520</link><guid isPermaLink="true">https://fargostreet.com/post/117520</guid><dc:creator><![CDATA[Zero]]></dc:creator><pubDate>Fri, 15 Sep 2006 13:33:54 GMT</pubDate></item><item><title><![CDATA[Reply to 5 hp 480 volt 3 ph motor for free on Fri, 15 Sep 2006 12:46:13 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Zero wrote:<br />
I'm interested, but how big is it?<br />
5 HP</p>
<p dir="auto">480volt</p>
<p dir="auto">3 phase</p>
]]></description><link>https://fargostreet.com/post/117513</link><guid isPermaLink="true">https://fargostreet.com/post/117513</guid><dc:creator><![CDATA[RE-Enema]]></dc:creator><pubDate>Fri, 15 Sep 2006 12:46:13 GMT</pubDate></item><item><title><![CDATA[Reply to 5 hp 480 volt 3 ph motor for free on Fri, 15 Sep 2006 03:53:37 GMT]]></title><description><![CDATA[<p dir="auto">I'm interested, but how big is it?</p>
]]></description><link>https://fargostreet.com/post/117447</link><guid isPermaLink="true">https://fargostreet.com/post/117447</guid><dc:creator><![CDATA[Zero]]></dc:creator><pubDate>Fri, 15 Sep 2006 03:53:37 GMT</pubDate></item></channel></rss>
