<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[why is installing a filter a bitch]]></title><description><![CDATA[<p dir="auto">so i got a k &amp;n high performance filter and it was the bitchiest thing to do for what should be such an easy job.  i could not fit the flange into the tubing.  it literally took me 1 hour to fit it in with a screwdriver. however, I know that the k &amp;n filter has a bigger diameter than the oem filter.  Is there some techniques i should know bout that will make my job easier.  Also, does the rubber ring that helps seal the tubing a critical component to seal the filter?  does it require immediate replacing if the ring is stretched?</p>
]]></description><link>https://fargostreet.com/topic/783/why-is-installing-a-filter-a-bitch</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 18:23:51 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/783.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Nov 2004 07:20:35 GMT</pubDate><ttl>60</ttl></channel></rss>
