<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Transfer Case Shift Motor]]></title><description><![CDATA[<p dir="auto">Long story short, Ford should burn in hell for making a shitty 4x4 shift motor.  The saga of my weekend under the Explorer will follow later.  BUT, the 4x4 works now.  I will pwn winter this year.</p>
]]></description><link>https://fargostreet.com/topic/7872/transfer-case-shift-motor</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:34:14 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/7872.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Oct 2006 12:59:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Transfer Case Shift Motor on Tue, 03 Oct 2006 02:35:16 GMT]]></title><description><![CDATA[<p dir="auto">I have sold many of them over the years...and there not cheap either</p>
]]></description><link>https://fargostreet.com/post/119878</link><guid isPermaLink="true">https://fargostreet.com/post/119878</guid><dc:creator><![CDATA[Raider]]></dc:creator><pubDate>Tue, 03 Oct 2006 02:35:16 GMT</pubDate></item><item><title><![CDATA[Reply to Transfer Case Shift Motor on Mon, 02 Oct 2006 23:06:20 GMT]]></title><description><![CDATA[<blockquote>
Yeah, the motor itself is usually fine.  There is a little rubber bushing that gets old, hardens and crumbles away causing the motor to get knocked out of position.  Its a rather simple fix, however you need to take the motor apart.  Thats where my old motor had the problem.  I overhauled it, but when I went to put the cover back on I had snapped 2 of the 3 bolts off in the housing.  RTV didn't hold the cover on so the damn thing wouldn't shift into 4 anymore since the position sensor didn't work because of the cover.</p>
<p dir="auto">thats why they have problems with the "motor" and people usually just replace the whole thing.  I can't count how many of those things I have replaced.</p>
]]></description><link>https://fargostreet.com/post/119838</link><guid isPermaLink="true">https://fargostreet.com/post/119838</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Mon, 02 Oct 2006 23:06:20 GMT</pubDate></item><item><title><![CDATA[Reply to Transfer Case Shift Motor on Mon, 02 Oct 2006 13:25:11 GMT]]></title><description><![CDATA[<p dir="auto">Yeah, the motor itself is usually fine.  There is a little rubber bushing that gets old, hardens and crumbles away causing the motor to get knocked out of position.  Its a rather simple fix, however you need to take the motor apart.  Thats where my old motor had the problem.  I overhauled it, but when I went to put the cover back on I had snapped 2 of the 3 bolts off in the housing.  RTV didn't hold the cover on so the damn thing wouldn't shift into 4 anymore since the position sensor didn't work because of the cover.</p>
]]></description><link>https://fargostreet.com/post/119716</link><guid isPermaLink="true">https://fargostreet.com/post/119716</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Mon, 02 Oct 2006 13:25:11 GMT</pubDate></item><item><title><![CDATA[Reply to Transfer Case Shift Motor on Mon, 02 Oct 2006 13:02:34 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Very common problem. I sold ALOT of them when I worked at the local salvage yard.</p>
]]></description><link>https://fargostreet.com/post/119714</link><guid isPermaLink="true">https://fargostreet.com/post/119714</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Mon, 02 Oct 2006 13:02:34 GMT</pubDate></item></channel></rss>
