<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[riddle]]></title><description><![CDATA[<p dir="auto">Three men checked into a hotel room for which they paid $30. The next day, the manager realized that the men had been overcharged. She gave the bellhop $5 to return to the three men. On the way to their room the bellhop decided to keep $2 for himself, and give each of the three men one dollar. The three men had now paid $9 each, or a total of $27. This plus the $2 the bellhop kept makes a total of $29. What happened to the other dollar?</p>
<hr />
<p dir="auto">Hayley wants to know why 3 men checked in to a hotel room?</p>
<p dir="auto">I give up..</p>
]]></description><link>https://fargostreet.com/topic/8239/riddle</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 22:46:32 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/8239.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Nov 2006 05:17:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 16:15:55 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">XJHEAD wrote:<br />
above post at 0307</p>
<p dir="auto">Gotta get used to a new sleep pattern for weekend standy.  Trying to, at least.</p>
<p dir="auto">I normally work 1500-2359, but I've got standby this weekend.  Show time is 3 hrs prior, so I gotta be in at 0300.</p>
<p dir="auto">EDIT:  Hope you (and all other Vets on here) have a good Veteran's Day.  Drink a couple beers for me since I gotta stay sober. :icon_thumright:</p>
]]></description><link>https://fargostreet.com/post/125943</link><guid isPermaLink="true">https://fargostreet.com/post/125943</guid><dc:creator><![CDATA[Afsil80]]></dc:creator><pubDate>Fri, 10 Nov 2006 16:15:55 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 13:28:28 GMT]]></title><description><![CDATA[<p dir="auto">above post at 0307</p>
]]></description><link>https://fargostreet.com/post/125927</link><guid isPermaLink="true">https://fargostreet.com/post/125927</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Fri, 10 Nov 2006 13:28:28 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 09:07:33 GMT]]></title><description><![CDATA[<blockquote>
The point is it doesn't matter if the wheels are at rest, spinning forward or spinning backwards, so long as the plane is moving forward in relation to the ground it will take off....and a conveyor belt will not stop it from doing so if it is pushing on the free spinning wheels which have no affect on if the plane can move regardless.  What you are failing to see is that the aircraft IS NOT STATIONARY, it is being propelled forward (in reference to the ground) via prop or jet turbine (or any sort of forward propulsion mechanism) and the conveyor is moving at the same speed backwards thereby causing the wheels to spin twice as fast which has ZERO affect on the planes ability to move forward.</p>
<p dir="auto">It just clicked in my head, for some odd reason.</p>
<p dir="auto">I think as I kept reading you and xjhead posts, and completely removed the wheels from the equation, it makes total sense.</p>
<p dir="auto">:icon_salut:  to you and xjhead.  I retract most of my statements from earlier.</p>
]]></description><link>https://fargostreet.com/post/125922</link><guid isPermaLink="true">https://fargostreet.com/post/125922</guid><dc:creator><![CDATA[Afsil80]]></dc:creator><pubDate>Fri, 10 Nov 2006 09:07:33 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 03:20:41 GMT]]></title><description><![CDATA[<p dir="auto">Now think about this, can a float plane (airplane with water landing gear) take off against the current?  The answer is yes, so long as it can overcome the friction of the water.</p>
]]></description><link>https://fargostreet.com/post/125880</link><guid isPermaLink="true">https://fargostreet.com/post/125880</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 10 Nov 2006 03:20:41 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 03:19:22 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">AFSil80 wrote:<br />
But isn't that the whole point of the argument?  To see if an a/c will take off while the surface the wheels rest on move in the opposite direction at the same speed, aka, being stationary?  <strong>If that is not the point of the argument, or there is some other factor that hasn't come clear, then I have been arguing for the wrong side.</strong></p>
<p dir="auto">The point is it doesn't matter if the wheels are at rest, spinning forward or spinning backwards, so long as the plane is moving forward in relation to the ground it will take off....and a conveyor belt will not stop it from doing so if it is pushing on the free spinning wheels which have no affect on if the plane can move regardless.  What you are failing to see is that the aircraft IS NOT STATIONARY, it is being propelled forward (in reference to the ground) via prop or jet turbine (or any sort of forward propulsion mechanism) and the conveyor is moving at the same speed backwards thereby causing the wheels to spin twice as fast which has ZERO affect on the planes ability to move forward.</p>
]]></description><link>https://fargostreet.com/post/125879</link><guid isPermaLink="true">https://fargostreet.com/post/125879</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 10 Nov 2006 03:19:22 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:45:51 GMT]]></title><description><![CDATA[<p dir="auto">the wheels could spin 2000000000000000000000000000 miles an hour BACKWARDS and it will not be enough to keep the 90,000 lbs of thrust from pushing the piece of sheetmetal that is a plane forward.  the wheels are a BEARING doing nothing but reducing friction.</p>
]]></description><link>https://fargostreet.com/post/125876</link><guid isPermaLink="true">https://fargostreet.com/post/125876</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:45:51 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:39:23 GMT]]></title><description><![CDATA[<p dir="auto">I realize that an Aircraft Carrier doesn't move very fast, but a plane could easily take off from that without any adverse effects...</p>
]]></description><link>https://fargostreet.com/post/125874</link><guid isPermaLink="true">https://fargostreet.com/post/125874</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:39:23 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:30:16 GMT]]></title><description><![CDATA[<p dir="auto">Not admitting defeat quite yet, I think I missed something, check bold print in my last post.</p>
]]></description><link>https://fargostreet.com/post/125872</link><guid isPermaLink="true">https://fargostreet.com/post/125872</guid><dc:creator><![CDATA[Afsil80]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:30:16 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:28:35 GMT]]></title><description><![CDATA[<p dir="auto">i spent an hour last night explaining it to him as well. Peter, you have been owned accept your defeat and raise the white flag and run.</p>
]]></description><link>https://fargostreet.com/post/125871</link><guid isPermaLink="true">https://fargostreet.com/post/125871</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:28:35 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:28:24 GMT]]></title><description><![CDATA[<blockquote>
I think you better do a little more research on lift.</p>
<p dir="auto">No, I know how it works.  I was simply using the leading edge of the wings as a reference.  Downforce on top, lift on the bottom.</p>
<p dir="auto">how will the conveyor even start to rotate if the plane has not even moved forward, explain that one to me??</p>
<p dir="auto">It won't.  I know that.</p>
<p dir="auto">I agree that is one reason, the other is that it would create alot of havoc during landing w/out them...</p>
<p dir="auto">And a lot of unneccesary work for me, haha.</p>
<p dir="auto">It will hit that speed..</p>
<p dir="auto">Let us look at this way, say you put a bicycle on a treadmill, and you push it forward and the treadmill begans to speed up at the same rate as the tires, not at the rate you are pushing it. With this concept are you stating that you will not be able to push the bike off the treadmill pushing forward????</p>
<p dir="auto">But isn't that the whole point of the argument?  To see if an a/c will take off while the surface the wheels rest on move in the opposite direction at the same speed, aka, being stationary?  <strong>If that is not the point of the argument, or there is some other factor that hasn't come clear, then I have been arguing for the wrong side.</strong></p>
<p dir="auto">I think 5 years in the Marine Corps working on the flight line troubleshooting  F-18 fighter jets maybe makes me a little bit qualified here. Not just watching them take off and land like you and listening to other people who have no clue as to what the fuck they are talking about...</p>
<p dir="auto">Enough said,,  probally not let's hear it...</p>
<p dir="auto">Not saying you're unqualified, or saying that I'm overqualified.  And I do more than just watch them take off.  I work flightline as well.  I'm a structural mechanic, aerodynamic smoothness and structural integrity for the a/c is a critical part of my job.</p>
]]></description><link>https://fargostreet.com/post/125870</link><guid isPermaLink="true">https://fargostreet.com/post/125870</guid><dc:creator><![CDATA[Afsil80]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:28:24 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:16:40 GMT]]></title><description><![CDATA[<p dir="auto">pulled this off another sight, I post on, same subject</p>
<p dir="auto"><strong>Honestly, do some of you have audio implants to remind you to breath for fear of dying or WHAT?????</strong></p>
]]></description><link>https://fargostreet.com/post/125868</link><guid isPermaLink="true">https://fargostreet.com/post/125868</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:16:40 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:14:08 GMT]]></title><description><![CDATA[<blockquote>
Is there windspeed acting on the plane as a result with the thrust being provided?</p>
<p dir="auto">No, there is windspeed acting on the plane as it moves forward which is a result of the thrust pushing the plane forward.  The plane doesn't care that its on a conveyor belt, so long as the wheel can spin and the plane isn't bolted to the conveyor belt, it will take off because it will be moving fast enough IN RELATION TO THE GROUND to cause air to flow over the wings thereby causing lift.  Case closed.</p>
]]></description><link>https://fargostreet.com/post/125867</link><guid isPermaLink="true">https://fargostreet.com/post/125867</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:14:08 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:10:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">There will be lift after the plane reaches a certain speed....</p>
]]></description><link>https://fargostreet.com/post/125866</link><guid isPermaLink="true">https://fargostreet.com/post/125866</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:10:12 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:08:38 GMT]]></title><description><![CDATA[<p dir="auto">Is there windspeed acting on the plane as a result with the thrust being provided?</p>
]]></description><link>https://fargostreet.com/post/125865</link><guid isPermaLink="true">https://fargostreet.com/post/125865</guid><dc:creator><![CDATA[Afsil80]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:08:38 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:07:52 GMT]]></title><description><![CDATA[<p dir="auto">more proof</p>
<p dir="auto"><a href="http://videos.streetfire.net/player.aspx?fileid=35E964D9-38DB-4EFD-BE8D-D6BA1A43A06B" rel="nofollow ugc">http://videos.streetfire.net/player.aspx?fileid=35E964D9-38DB-4EFD-BE8D-D6BA1A43A06B</a></p>
]]></description><link>https://fargostreet.com/post/125864</link><guid isPermaLink="true">https://fargostreet.com/post/125864</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:07:52 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:06:52 GMT]]></title><description><![CDATA[<p dir="auto">Anyone else wanna tell us why this what we have posted is false?</p>
]]></description><link>https://fargostreet.com/post/125863</link><guid isPermaLink="true">https://fargostreet.com/post/125863</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:06:52 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:05:35 GMT]]></title><description><![CDATA[<blockquote>
I think its safe to say that me and Bill just killed this topic</p>
<p dir="auto">AGREED:icon_salut:</p>
]]></description><link>https://fargostreet.com/post/125862</link><guid isPermaLink="true">https://fargostreet.com/post/125862</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:05:35 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:04:22 GMT]]></title><description><![CDATA[<p dir="auto">I think its safe to say that me and Bill just killed this topic</p>
]]></description><link>https://fargostreet.com/post/125861</link><guid isPermaLink="true">https://fargostreet.com/post/125861</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:04:22 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:04:14 GMT]]></title><description><![CDATA[<p dir="auto">the plane will take off, the converyor belt will simply make the wheels spin faster realative to the speed of the forward motion of the jet and the reverse motion of the conveyour belt.</p>
<p dir="auto">because the thrust of the jet engine is pushing the plane forward, and the wheel axels are free spinning, once the applied friction of the wheels to their axels is negated by equal force from the thrust, the plane will make forward motion until it reaches speed to make lift, then if will fly.</p>
]]></description><link>https://fargostreet.com/post/125860</link><guid isPermaLink="true">https://fargostreet.com/post/125860</guid><dc:creator><![CDATA[Colin]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:04:14 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:03:06 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://img.photobucket.com/albums/v354/11sChevelle/plane.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/125859</link><guid isPermaLink="true">https://fargostreet.com/post/125859</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:03:06 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 02:00:52 GMT]]></title><description><![CDATA[<blockquote>
Lift has nothing to do with how much thrust. .<br />
Yes, you are correct there. The engines are pushing the A/C forward the tires are not making it go forward.</p>
It's all about the windspeed hitting the leading edge..<br />
So again, if the wheels are freerolling and the conveyor belt is doing the same, the plane won't move. ..</p>
<p dir="auto">Let me ask you this, how will the conveyor even start to rotate if the plane has not even moved forward, explain that one to me??</p>
The wheels keep the airplane supported until it builds up enough airspeed for the bernoulli effect to take place...</p>
If it can't hit that speed, and it won't while it sits on a belt that can keep up, there will be no forward motion.</p>
You have to think out of the box on this, and a little knowledge of aircraft helps..</p>
]]></description><link>https://fargostreet.com/post/125857</link><guid isPermaLink="true">https://fargostreet.com/post/125857</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Fri, 10 Nov 2006 02:00:52 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 01:52:15 GMT]]></title><description><![CDATA[<p dir="auto">god damnit.....</p>
<p dir="auto">Yes, wheelspeed has NOTHING to do with the aircraft taking off, it is its FORWARD MOVEMENT (or rather the air rushing over the wings) that causes it to lift off.  On an aircraft speed is not measured at the wheels either, it is measured as air speed (the speed the plane is moving through the air) so if a plane is moving forward through the air (with wheels still rolling on ground) at 25mph and the conveyor belt turning in the OPPOSITE DIRECTION at 25 mph it DOES NOT stop the plane dead in its tracks BECAUSE the wheels do not generate the forward movement, nor do they negate any forward movement if a force is being applied to them opposite of the movement of the aircraft, it will just cause them to spin approximately twice as fast as normal.  It is because the wheels have no affect on a planes forward movement that the airplane can in fact lift off when the plane is moving forward at the appropriate speed.  NOWHERE in the riddle does it say that the airplane remains stationary in relation to the ground, it states that as the plane travels forward, the conveyor belt spins backwards at the same rate, but the backwards travel of the conveyor belt has little/no affect on the planes ability to move forward since it is pushed forward by its jets/propellor/whatever and does not get its forward drive by applying power to the wheels.  Again, the airplane does NOT remain stationary, it is in fact moving forward and therefore is able to take off.</p>
]]></description><link>https://fargostreet.com/post/125856</link><guid isPermaLink="true">https://fargostreet.com/post/125856</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 10 Nov 2006 01:52:15 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 01:43:43 GMT]]></title><description><![CDATA[<blockquote>
exactly what mitch said, what conveyor belt can move as fast as a jet?</p>
<p dir="auto">Don't think of it like that.</p>
<p dir="auto">Think objectively, that there IS a conveyor belt that can keep up.</p>
]]></description><link>https://fargostreet.com/post/125852</link><guid isPermaLink="true">https://fargostreet.com/post/125852</guid><dc:creator><![CDATA[Afsil80]]></dc:creator><pubDate>Fri, 10 Nov 2006 01:43:43 GMT</pubDate></item><item><title><![CDATA[Reply to riddle on Fri, 10 Nov 2006 01:43:06 GMT]]></title><description><![CDATA[<p dir="auto">Think about a glider.</p>
<p dir="auto">How does it move?</p>
<p dir="auto">It has no mechanism to provide thrust.</p>
]]></description><link>https://fargostreet.com/post/125851</link><guid isPermaLink="true">https://fargostreet.com/post/125851</guid><dc:creator><![CDATA[Afsil80]]></dc:creator><pubDate>Fri, 10 Nov 2006 01:43:06 GMT</pubDate></item></channel></rss>
