<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[new turbo and pregress pics]]></title><description><![CDATA[<p dir="auto">got my new turbo today, its freakin huge.  Borg Warner s400, $550  compressor is a 75mm minor, 105mm major.  the turbine is a 88mm minor, 95mm major. also im almost done with my wiring and have the oil pan shortened, need to cut the pickup tube next.  the new intake and 60# injectors are assembled and all the braided hose and fittings will be here by friday.  Also got the big cam installed last week.  hopefully will have the motor back in for the last time sometime next week so i can start building the headers, thats gonna be a fun one.<br />
Gary</p>
]]></description><link>https://fargostreet.com/topic/8465/new-turbo-and-pregress-pics</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 04:00:18 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/8465.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Nov 2006 03:06:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to new turbo and pregress pics on Thu, 30 Nov 2006 05:11:49 GMT]]></title><description><![CDATA[<p dir="auto">its a 1.32 divided t6, that thing is heavy as hell, i need to figure out how im going to mount the damn thing.  I am a member of <a href="http://turbomustangs.com" rel="nofollow ugc">turbomustangs.com</a>, and those guys know their shit about turbo'ing V8's.  anyway most of the guys with 350s spool it around 3500, and an ls1 around 3200.  with the 6.0 it may spool by 2800, but im expecting around 3200 since i have so much volume to fill.  at any rate, the motor makes around 420hp N/A, and as much torque.  i know keeping the tires planted with my GTO was a chore, and this should be about 15hp more than that, which was around 410hp.<br />
Gary</p>
]]></description><link>https://fargostreet.com/post/128912</link><guid isPermaLink="true">https://fargostreet.com/post/128912</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Thu, 30 Nov 2006 05:11:49 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Thu, 30 Nov 2006 04:56:02 GMT]]></title><description><![CDATA[<p dir="auto">mark up on turbos is huge on some turbos and small on others, i never really have looked on the mark up on switzer turbos. only the garretts and hx35's. it would be intresting to look that stuff up.</p>
]]></description><link>https://fargostreet.com/post/128905</link><guid isPermaLink="true">https://fargostreet.com/post/128905</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Thu, 30 Nov 2006 04:56:02 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Thu, 30 Nov 2006 04:45:39 GMT]]></title><description><![CDATA[<p dir="auto">BW does some interesting stuff.  In garrett terms, your turbo is basically a GT4276 on the compressor side, and a GT47 on the turbine side.  Should work ok with your big cube motor, I'm looking forward to seeing a dyno to see how it spools for you, etc.  What a/r are the housings?</p>
]]></description><link>https://fargostreet.com/post/128903</link><guid isPermaLink="true">https://fargostreet.com/post/128903</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Thu, 30 Nov 2006 04:45:39 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 20:47:19 GMT]]></title><description><![CDATA[<p dir="auto">yeah the new naming system is gay.  one thing people forget is that you make as much of your power on the exhaust side as the compressor.  case in point, a gt35 may be rated for 750hp, but it has such a high pressure turbine, most people never see it.  step up to a gt42 with the same compressor, and the 750hp becomes attainable fairly easily.  now as far as big turbos go, these new designs flow so much better than the older bigger ones.  specifically this 75 mm is the repacement for the TV8101/8102.  the 8101 was an 85mm compressor, and a bigger, heavier turbine.  this new 75mm will keep within 10lbs/min of that old one, and spool is around 800rpm sooner, with a broader efficiency range.  also the 80mm upgrade is $240, and then it actually exceeds the old 85mm a hair.  This s400 is the same turbo that Innovative uses for its $2000 dollar GTB 88.  and i can have the same thing for a little under $1200.  Turbo companies are ridiculous in their markups.  Heres the map for the 75mm compressor.  Ive never seen a map that wide and flat before.  Man you can beat the pricing on these Borg Warner turbos, its really making it easier for alot of these guys to build bitchin setups on a budget.  Also i was looking at a gt42/47 based turbo, but it uses a high pressure turbine, more suited to high rpm, small displacement engines, and is a real choke point on these bigger v8's.  the big turbine is also very kind to the tires as boost is very controlable with the throttle.<br />
That s366 should be a nice addition to your ride, now if it was right wheel drive you might be able to do something with all that power!  Hope your driveline holds up for awhile this year.<br />
The rest of my fuel system stuff came today, aeromotive filter, -8 and -6 fittings and braided hose.  can plumb this thing in now and see if my wiring works, hopefully be able to turn it before christmas and see how much shit i f-ed up on this wiring.<br />
Gary<br />
Gary</p>
]]></description><link>https://fargostreet.com/post/128788</link><guid isPermaLink="true">https://fargostreet.com/post/128788</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Wed, 29 Nov 2006 20:47:19 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 19:30:27 GMT]]></title><description><![CDATA[<p dir="auto">Na Ftw!</p>
]]></description><link>https://fargostreet.com/post/128769</link><guid isPermaLink="true">https://fargostreet.com/post/128769</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 29 Nov 2006 19:30:27 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 19:23:16 GMT]]></title><description><![CDATA[<p dir="auto">Yup.  Borg Warner S366 for me this year hahaha.</p>
]]></description><link>https://fargostreet.com/post/128766</link><guid isPermaLink="true">https://fargostreet.com/post/128766</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Wed, 29 Nov 2006 19:23:16 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 19:16:05 GMT]]></title><description><![CDATA[<p dir="auto">Its so fucking stupid...the difference in the naming between the old T series and the new GT series</p>
<p dir="auto">Using the Compressor Major to name the GT's and the Compressor Minor to Name the old T series....It makes a person very confused if you are not aware</p>
<p dir="auto">and the GTXX only denotes the turbine frame size.....whatever i guess</p>
]]></description><link>https://fargostreet.com/post/128764</link><guid isPermaLink="true">https://fargostreet.com/post/128764</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Wed, 29 Nov 2006 19:16:05 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 19:08:56 GMT]]></title><description><![CDATA[<p dir="auto">It's a GT4788 is the other name for the GT4718 IIRC.<br />
88mm compressor inducer</p>
]]></description><link>https://fargostreet.com/post/128760</link><guid isPermaLink="true">https://fargostreet.com/post/128760</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Wed, 29 Nov 2006 19:08:56 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 18:53:30 GMT]]></title><description><![CDATA[<blockquote>
GT4788 is bigger than that s400...</p>
<p dir="auto">I think your talking about either a GT4708 or GT4718, there is no such thing as a GT4788, because that would be a tiny compressor with that big of a turbine</p>
<p dir="auto">GT4708  108mm Major     80.7mm Minor<br />
GT4718  117.6mm Major  88mm Minor<br />
S400     105mm Major    75mm Minor</p>
<p dir="auto">Your right that either GT47xx has a larger compressor, but the turbine is larger<br />
on the S400</p>
<p dir="auto">S400          95mm Major               86 Trim<br />
Gt47xx        92.7mm Major            82 Trim</p>
<p dir="auto">Either way the S400 is going to respond faster than the GT47 even with the larger turbine because of the comp/turbine ratios.... even though the GT47 has a smaller trim to help spool, yet the smaller trim hurts topend flow compared to the S400...with comparable turbine ARs<br />
the S400 will run out of compressor a good deal before though</p>
]]></description><link>https://fargostreet.com/post/128750</link><guid isPermaLink="true">https://fargostreet.com/post/128750</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Wed, 29 Nov 2006 18:53:30 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 15:13:37 GMT]]></title><description><![CDATA[<p dir="auto">GT4788 is bigger than that s400...</p>
]]></description><link>https://fargostreet.com/post/128697</link><guid isPermaLink="true">https://fargostreet.com/post/128697</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Wed, 29 Nov 2006 15:13:37 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 15:06:43 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Grr wrote:<br />
hey dave, you see that you aint got shit on me!  no but yours aint much bigger than mine.  best part is for 450$ i can upgrade to a 80mm which is good to 1250hp, or an 88mm which is good to 1400hp.  but, 1076 is more than enough for me.  anyway thats a t6 all the way.  it makes a gt42 look like a sissy girl.  but you and me both know gt42's are for pansies!.  haha.<br />
Zack you need a 4 rotor p-port to even think about spooling that, you just stay with your wussy little t-4s and get ready for a ass whoopin!<br />
Gary<br />
talk shit after you run a 9.46 or lower!</p>
]]></description><link>https://fargostreet.com/post/128694</link><guid isPermaLink="true">https://fargostreet.com/post/128694</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 29 Nov 2006 15:06:43 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 08:30:12 GMT]]></title><description><![CDATA[<p dir="auto">hey dave, you see that you aint got shit on me!  no but yours aint much bigger than mine.  best part is for 450$ i can upgrade to a 80mm which is good to 1250hp, or an 88mm which is good to 1400hp.  but, 1076 is more than enough for me.  anyway thats a t6 all the way.  it makes a gt42 look like a sissy girl.  but you and me both know gt42's are for pansies!.  haha.<br />
Gary</p>
]]></description><link>https://fargostreet.com/post/128683</link><guid isPermaLink="true">https://fargostreet.com/post/128683</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Wed, 29 Nov 2006 08:30:12 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 04:51:03 GMT]]></title><description><![CDATA[<p dir="auto">Looks good man!  Hard to tell from the pics, is it a T4 or T6 turbine housing?  Can't wait to hear how it works for you.</p>
]]></description><link>https://fargostreet.com/post/128639</link><guid isPermaLink="true">https://fargostreet.com/post/128639</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Wed, 29 Nov 2006 04:51:03 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 04:34:27 GMT]]></title><description><![CDATA[<p dir="auto">Gary do you smell that???..........smells like pussy,<br />
more like sex lol</p>
<p dir="auto">Give me a 200 shot and a another rotor and i might spool that..... at least i still get frist ride....</p>
]]></description><link>https://fargostreet.com/post/128637</link><guid isPermaLink="true">https://fargostreet.com/post/128637</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Wed, 29 Nov 2006 04:34:27 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 04:07:57 GMT]]></title><description><![CDATA[<p dir="auto">nice as hell turbo!!</p>
]]></description><link>https://fargostreet.com/post/128631</link><guid isPermaLink="true">https://fargostreet.com/post/128631</guid><dc:creator><![CDATA[blindsp1]]></dc:creator><pubDate>Wed, 29 Nov 2006 04:07:57 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 04:05:03 GMT]]></title><description><![CDATA[<p dir="auto">Daaang.  That thing is big!!</p>
]]></description><link>https://fargostreet.com/post/128629</link><guid isPermaLink="true">https://fargostreet.com/post/128629</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Wed, 29 Nov 2006 04:05:03 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 03:37:45 GMT]]></title><description><![CDATA[<p dir="auto">jus the cam for now, like i said, 500-550whp is more than enough this year, im not even gonna paint it up till next winter, want all the bugs and shit worked out of it first.  Want to do some interior and body work before i go for a 1000hp motor.  still dont think im gonna put a bar in it so wont be going to the track much, thats why i went with the 4l80e, should get in the low 20s for milage, i got 24 with the GTO on the highway, similar weight and gearing.<br />
Gary</p>
]]></description><link>https://fargostreet.com/post/128623</link><guid isPermaLink="true">https://fargostreet.com/post/128623</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Wed, 29 Nov 2006 03:37:45 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 03:33:38 GMT]]></title><description><![CDATA[<p dir="auto">Damn, that thing is gonna be badass in the Buick...</p>
]]></description><link>https://fargostreet.com/post/128620</link><guid isPermaLink="true">https://fargostreet.com/post/128620</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Wed, 29 Nov 2006 03:33:38 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 03:32:28 GMT]]></title><description><![CDATA[<p dir="auto">is it built?</p>
]]></description><link>https://fargostreet.com/post/128619</link><guid isPermaLink="true">https://fargostreet.com/post/128619</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Wed, 29 Nov 2006 03:32:28 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 03:32:18 GMT]]></title><description><![CDATA[<p dir="auto">oh, no the GTO is long gone, this things going in the Buick.  6.0L and a 4l80e is a pretty stout drivetrain, the v6 just has its limits, at around 600whp then you need to step up to the big Stage II block and thats expensive as hell, this stock motor with the turbo is good to about 550-600whp, then a set of rods and pistons with good bolts makes it good to around 1000whp, for about 1/4 the cost<br />
Gary</p>
]]></description><link>https://fargostreet.com/post/128618</link><guid isPermaLink="true">https://fargostreet.com/post/128618</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Wed, 29 Nov 2006 03:32:18 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 03:29:00 GMT]]></title><description><![CDATA[<p dir="auto">I'm guessing by the pics of the motor, its a GTO <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/128617</link><guid isPermaLink="true">https://fargostreet.com/post/128617</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Wed, 29 Nov 2006 03:29:00 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 03:28:31 GMT]]></title><description><![CDATA[<p dir="auto">what is it going on?</p>
]]></description><link>https://fargostreet.com/post/128616</link><guid isPermaLink="true">https://fargostreet.com/post/128616</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Wed, 29 Nov 2006 03:28:31 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 03:24:13 GMT]]></title><description><![CDATA[<p dir="auto">yeah Dave aint got shit on me now!  jk, i guess 500-550whp this year will be more than enough, should spool around 28-3400 on my combo, actually hope its a little more laggy since im gonna have about 400lb/ft torque without the damn turbo, i hope those 275 drag radials can hold alot of power.</p>
]]></description><link>https://fargostreet.com/post/128613</link><guid isPermaLink="true">https://fargostreet.com/post/128613</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Wed, 29 Nov 2006 03:24:13 GMT</pubDate></item><item><title><![CDATA[Reply to new turbo and pregress pics on Wed, 29 Nov 2006 03:23:06 GMT]]></title><description><![CDATA[<p dir="auto">Nice:icon_thumright: :icon_thumleft:</p>
]]></description><link>https://fargostreet.com/post/128612</link><guid isPermaLink="true">https://fargostreet.com/post/128612</guid><dc:creator><![CDATA[King Ricer]]></dc:creator><pubDate>Wed, 29 Nov 2006 03:23:06 GMT</pubDate></item></channel></rss>
