<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[cat converter]]></title><description><![CDATA[<p dir="auto">getting an exhaust made for the EJ and there isn't one on it...muffler shop requires one obviously...unless somebody knows a person that doesn't care bout cat's???</p>
<p dir="auto">i know people have these things just laying around...the bigger the in/out the better...3" preferred but will take anything somebody offers (so the muffler guy can put a 3" flange there...)</p>
]]></description><link>https://fargostreet.com/topic/8895/cat-converter</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 09:39:13 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/8895.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Dec 2006 21:47:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to cat converter on Tue, 02 Jan 2007 05:24:16 GMT]]></title><description><![CDATA[<blockquote>
Why not just buy a high flow cat and go tvhat route?</p>
<p dir="auto">bc cats are expensive and useless in a state that has no emmissions testing...</p>
]]></description><link>https://fargostreet.com/post/135522</link><guid isPermaLink="true">https://fargostreet.com/post/135522</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Tue, 02 Jan 2007 05:24:16 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Tue, 02 Jan 2007 05:23:39 GMT]]></title><description><![CDATA[<blockquote>
why not spend money on boosting the car and worry about the exhaust situation when it will actually benefit your setup?</p>
<p dir="auto">the exhaust on the car right now sux balls...its 1.5 inches and has about 5 leaks...very annoying...it was a hack job. I want to get a new exhaust so i wont be annoyed by the leaks...so i figured i might as well get the 3" exhaust out of the way while i'm doing it...</p>
]]></description><link>https://fargostreet.com/post/135521</link><guid isPermaLink="true">https://fargostreet.com/post/135521</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Tue, 02 Jan 2007 05:23:39 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Tue, 02 Jan 2007 05:00:48 GMT]]></title><description><![CDATA[<p dir="auto">why not spend money on boosting the car and worry about the exhaust situation when it will actually benefit your setup?</p>
]]></description><link>https://fargostreet.com/post/135515</link><guid isPermaLink="true">https://fargostreet.com/post/135515</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Tue, 02 Jan 2007 05:00:48 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Mon, 01 Jan 2007 22:12:51 GMT]]></title><description><![CDATA[<p dir="auto">Why not just buy a high flow cat and go tvhat route?</p>
]]></description><link>https://fargostreet.com/post/135393</link><guid isPermaLink="true">https://fargostreet.com/post/135393</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Mon, 01 Jan 2007 22:12:51 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Mon, 01 Jan 2007 21:27:58 GMT]]></title><description><![CDATA[<p dir="auto">k so even if you put a cat at the end... it wont do anything anyways.... u'de be lucky if they would do that... btw why did you buy that welder if your not gonna use it?</p>
]]></description><link>https://fargostreet.com/post/135391</link><guid isPermaLink="true">https://fargostreet.com/post/135391</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Mon, 01 Jan 2007 21:27:58 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Mon, 01 Jan 2007 20:02:03 GMT]]></title><description><![CDATA[<p dir="auto">FYI</p>
<p dir="auto">The law is that if the car came originally equiped with a cat, the shop has to install one. This only applies to vehicles that are going to be driven regularly on the street.  If it is a strip, race, off-road or show car a cat doesn't need to be installed.</p>
<p dir="auto">It is a heafty fine for the shop if they are caught not installing the cat.  Place got fined around $50,000 a few years ago for not installing cats. Went out of buisness because of it.</p>
<p dir="auto">just take your car in, say you have a race only version at home the same make.  have them bend it all up based of your car, then go install it yourself.  Saves thier ass from being fined.</p>
]]></description><link>https://fargostreet.com/post/135387</link><guid isPermaLink="true">https://fargostreet.com/post/135387</guid><dc:creator><![CDATA[mattimeo]]></dc:creator><pubDate>Mon, 01 Jan 2007 20:02:03 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Mon, 01 Jan 2007 09:36:01 GMT]]></title><description><![CDATA[<blockquote>
Leroy does good work.</p>
<p dir="auto">look on mangnaflows website. and give me the numbers you want, Ill get you a price.</p>
<p dir="auto">also, Ill pm you some pics and see if that is what you want.</p>
<p dir="auto">i'll do that...also, did leroy ever give you his rules on a cat? because right now there's no cat on the car...so judging by what you told me, he should still be able to make the 3" exhaust...?</p>
<p dir="auto">im gonna check magnaflow's site right now...see what comes up</p>
]]></description><link>https://fargostreet.com/post/135363</link><guid isPermaLink="true">https://fargostreet.com/post/135363</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Mon, 01 Jan 2007 09:36:01 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Mon, 01 Jan 2007 09:34:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">BumpinJCC wrote:<br />
Buy an Ebay test pipe adam.</p>
<p dir="auto">most of them are 2.25 and premade to fit where the stock cat goes...this means that if the downpipe or the catback itself is off, that the ebay test-pipe won't work...i may have to custom make one (that i could prolly do myself...i just dont wanna deal with a whole exhaust...but cutting a straight pipe and doing 2 welds wouldnt be bad...)</p>
]]></description><link>https://fargostreet.com/post/135362</link><guid isPermaLink="true">https://fargostreet.com/post/135362</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Mon, 01 Jan 2007 09:34:11 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Mon, 01 Jan 2007 09:31:53 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">DrifterExtreme wrote:<br />
wouldn't that just defeat the purpose of a cat all together....</p>
<p dir="auto">also why don't you just make an exhaust you have a welder????</p>
<p dir="auto">What are you referring to when you are saying that would defeat the purpose of a cat?...all i want is a big cat to put on the car while a shop (leroy...this is just going by his rules) does the exhaust from the cat-back. of course the cat will get taken off...i just want it there so he'll actually make the exhaust for me...i'm guessing it'll be pretty cheap beings he made a 2.5 catback for the sol 1-2 years ago for $65 plus $10 to weld the muffler on...so it'd be like 100 for him to do the piping all in 3"...</p>
<p dir="auto">to answer your second question...</p>
<p dir="auto">i dont have the piping, nor do i have a bender...and i'm not gonna spend a bunch of money on getting random piping only to have to weld it up.</p>
<p dir="auto">I would consider a premade exhaust that's already 3" too...but finding one at a half decent price can be quite a challenge.</p>
]]></description><link>https://fargostreet.com/post/135361</link><guid isPermaLink="true">https://fargostreet.com/post/135361</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Mon, 01 Jan 2007 09:31:53 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Mon, 01 Jan 2007 01:31:27 GMT]]></title><description><![CDATA[<p dir="auto">Leroy does good work.</p>
]]></description><link>https://fargostreet.com/post/135334</link><guid isPermaLink="true">https://fargostreet.com/post/135334</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Mon, 01 Jan 2007 01:31:27 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sun, 31 Dec 2006 23:47:58 GMT]]></title><description><![CDATA[<p dir="auto">Buy an Ebay test pipe adam.</p>
]]></description><link>https://fargostreet.com/post/135320</link><guid isPermaLink="true">https://fargostreet.com/post/135320</guid><dc:creator><![CDATA[DelSlow]]></dc:creator><pubDate>Sun, 31 Dec 2006 23:47:58 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sun, 31 Dec 2006 23:21:28 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">torbs wrote:<br />
Do they have one that can be used as an end muffler...like a stock looking muffler that is at the end of the exhaust with a 3" in/out...how much for that? PM me prices and such</p>
<p dir="auto">You mean like a fart can?</p>
]]></description><link>https://fargostreet.com/post/135315</link><guid isPermaLink="true">https://fargostreet.com/post/135315</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sun, 31 Dec 2006 23:21:28 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sun, 31 Dec 2006 21:59:02 GMT]]></title><description><![CDATA[<p dir="auto">wouldn't that just defeat the purpose of a cat all together....</p>
]]></description><link>https://fargostreet.com/post/135306</link><guid isPermaLink="true">https://fargostreet.com/post/135306</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Sun, 31 Dec 2006 21:59:02 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sun, 31 Dec 2006 21:36:53 GMT]]></title><description><![CDATA[<blockquote>
I can get you a good deal on some magnoflow stuff.</p>
<p dir="auto">cans FTL!</p>
<p dir="auto">Do they have one that can be used as an end muffler...like a stock looking muffler that is at the end of the exhaust with a 3" in/out...how much for that? PM me prices and such</p>
]]></description><link>https://fargostreet.com/post/135304</link><guid isPermaLink="true">https://fargostreet.com/post/135304</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Sun, 31 Dec 2006 21:36:53 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sun, 31 Dec 2006 21:36:02 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">fanaticrockford wrote:<br />
Who was this? I have dealt with some exhaust shops in town that gave me some bs because they really didn't want to do the work because i wouldn't let them do it there way. I have pretty much always went to muffler man in moorhead and they are the ones that gave me that info.</p>
<p dir="auto">huh...really...i went to this place in west fargo...forget the name, but its a one man business and his name is Leroy</p>
]]></description><link>https://fargostreet.com/post/135303</link><guid isPermaLink="true">https://fargostreet.com/post/135303</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Sun, 31 Dec 2006 21:36:02 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sun, 31 Dec 2006 01:31:07 GMT]]></title><description><![CDATA[<p dir="auto">I can get you a good deal on some magnoflow stuff.</p>
]]></description><link>https://fargostreet.com/post/135173</link><guid isPermaLink="true">https://fargostreet.com/post/135173</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Sun, 31 Dec 2006 01:31:07 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sun, 31 Dec 2006 01:24:33 GMT]]></title><description><![CDATA[<blockquote>
really? he said he couldnt touch my car w/o one.<br />
]]></description><link>https://fargostreet.com/post/135168</link><guid isPermaLink="true">https://fargostreet.com/post/135168</guid><dc:creator><![CDATA[fanaticrockford]]></dc:creator><pubDate>Sun, 31 Dec 2006 01:24:33 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sun, 31 Dec 2006 01:19:39 GMT]]></title><description><![CDATA[<blockquote>
If there isn't a cat on it then they don't have to put one on. The can make the exhaust anyway you want. If there was a cat to begin with then they legally cannot remove it.</p>
<p dir="auto">really? he said he couldnt touch my car w/o one.</p>
]]></description><link>https://fargostreet.com/post/135163</link><guid isPermaLink="true">https://fargostreet.com/post/135163</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Sun, 31 Dec 2006 01:19:39 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sun, 31 Dec 2006 01:18:08 GMT]]></title><description><![CDATA[<p dir="auto">If there isn't a cat on it then they don't have to put one on. The can make the exhaust anyway you want. If there was a cat to begin with then they legally cannot remove it.</p>
]]></description><link>https://fargostreet.com/post/135162</link><guid isPermaLink="true">https://fargostreet.com/post/135162</guid><dc:creator><![CDATA[fanaticrockford]]></dc:creator><pubDate>Sun, 31 Dec 2006 01:18:08 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sun, 31 Dec 2006 01:16:50 GMT]]></title><description><![CDATA[<blockquote>
ya 3inch exhaust on NA is dumb. and would be loud and sound like shit</p>
<p dir="auto">doy...boost is in the works...just might as well get it done right the first time...i'm gonna go with some sort of chamber'd muffler too...dont need the fartcan</p>
]]></description><link>https://fargostreet.com/post/135159</link><guid isPermaLink="true">https://fargostreet.com/post/135159</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Sun, 31 Dec 2006 01:16:50 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sat, 30 Dec 2006 23:55:59 GMT]]></title><description><![CDATA[<p dir="auto">you have an EK?</p>
]]></description><link>https://fargostreet.com/post/135133</link><guid isPermaLink="true">https://fargostreet.com/post/135133</guid><dc:creator><![CDATA[DelSlow]]></dc:creator><pubDate>Sat, 30 Dec 2006 23:55:59 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sat, 30 Dec 2006 23:18:56 GMT]]></title><description><![CDATA[<p dir="auto">ya 3inch exhaust on NA is dumb. and would be loud and sound like shit</p>
]]></description><link>https://fargostreet.com/post/135127</link><guid isPermaLink="true">https://fargostreet.com/post/135127</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Sat, 30 Dec 2006 23:18:56 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sat, 30 Dec 2006 22:57:48 GMT]]></title><description><![CDATA[<p dir="auto">I hope you are boosting it with 3'' exhaust on a Honda...</p>
]]></description><link>https://fargostreet.com/post/135123</link><guid isPermaLink="true">https://fargostreet.com/post/135123</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Sat, 30 Dec 2006 22:57:48 GMT</pubDate></item><item><title><![CDATA[Reply to cat converter on Sat, 30 Dec 2006 22:55:41 GMT]]></title><description><![CDATA[<p dir="auto">Catalytic converters FTL.</p>
<p dir="auto">Just have them fab up the entire system without a cat and not bolt it on since its for "off-road" use.  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
]]></description><link>https://fargostreet.com/post/135118</link><guid isPermaLink="true">https://fargostreet.com/post/135118</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sat, 30 Dec 2006 22:55:41 GMT</pubDate></item></channel></rss>
