<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DSM problem. :mad:]]></title><description><![CDATA[<p dir="auto">I am currently having multiple problems right now with my Talon.  The idle sucks really bad after it warms up.  Once the engine is warmed up it idles around about 800 rpms but the engine every few seconds will seem to jerk like it was missing on a cylinder or something.</p>
<p dir="auto">Also when I am approaching or have past 3000 rpms while acclerating it stutters and acclerates very slowly as if it were on a wake-up strip on the freeway.  I called a shop here in Fergus and they said it could be a timing belt.</p>
<p dir="auto">I did a little research and found out that it may be due to some bad plug wires but who really knows.  Also some other things that are wrong right now is that my power steering does not work and the CV joints are bad.  Not sure if they are related but you never really know.</p>
]]></description><link>https://fargostreet.com/topic/897/dsm-problem.-mad</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 08:13:49 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/897.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Dec 2004 17:09:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to DSM problem. :mad: on Thu, 23 Dec 2004 15:39:59 GMT]]></title><description><![CDATA[<p dir="auto">There's not really much to check. If you have low oil pressure then there's nothing short of replacing or rebuilding an engine that'll give you oil pressure. I'd just drive it for now and keep a good eye on it. I thought it might just be a bad sensor but if your guage reads low also, than it's a good indication that it's low. Save your pennies for an engine from SLS. They have done countless Jap-spec engine swaps and are reasonable about price.</p>
]]></description><link>https://fargostreet.com/post/18140</link><guid isPermaLink="true">https://fargostreet.com/post/18140</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Thu, 23 Dec 2004 15:39:59 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Thu, 23 Dec 2004 08:02:30 GMT]]></title><description><![CDATA[<p dir="auto">Can I come in and have it checked?</p>
]]></description><link>https://fargostreet.com/post/18128</link><guid isPermaLink="true">https://fargostreet.com/post/18128</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 23 Dec 2004 08:02:30 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Thu, 23 Dec 2004 05:52:46 GMT]]></title><description><![CDATA[<p dir="auto">Not a good sign. There low normaly stock but not that low.</p>
]]></description><link>https://fargostreet.com/post/18105</link><guid isPermaLink="true">https://fargostreet.com/post/18105</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Thu, 23 Dec 2004 05:52:46 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Thu, 23 Dec 2004 03:50:42 GMT]]></title><description><![CDATA[<p dir="auto">At the minimum it is usually at if I sit for a long while once it is warm.</p>
]]></description><link>https://fargostreet.com/post/18071</link><guid isPermaLink="true">https://fargostreet.com/post/18071</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 23 Dec 2004 03:50:42 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Thu, 23 Dec 2004 02:05:36 GMT]]></title><description><![CDATA[<p dir="auto">What does your stock oil pressure guage say at idle?</p>
]]></description><link>https://fargostreet.com/post/18051</link><guid isPermaLink="true">https://fargostreet.com/post/18051</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Thu, 23 Dec 2004 02:05:36 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Thu, 23 Dec 2004 00:54:14 GMT]]></title><description><![CDATA[<p dir="auto">She is running great now but th oil light comes on every time I stop. I read on <a href="http://dsmtuenrs.com" rel="nofollow ugc">dsmtuenrs.com</a> that this is OK but just wanted to double check with you guys.</p>
]]></description><link>https://fargostreet.com/post/18041</link><guid isPermaLink="true">https://fargostreet.com/post/18041</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 23 Dec 2004 00:54:14 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Wed, 22 Dec 2004 23:03:03 GMT]]></title><description><![CDATA[<p dir="auto">lol @ kevin</p>
]]></description><link>https://fargostreet.com/post/18033</link><guid isPermaLink="true">https://fargostreet.com/post/18033</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Wed, 22 Dec 2004 23:03:03 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Wed, 22 Dec 2004 22:13:45 GMT]]></title><description><![CDATA[<p dir="auto">Driving and breaking my DSM at least once a month!</p>
<p dir="auto">Hey that happins to you too huh? Join the club.. Its never ending!! If you guys with the broken down dsms want to make a car club go for it!  Call it (broke) either way you look at it your car will be broken or your pocket book will be broke!</p>
<p dir="auto">Kevin<br />
sls</p>
]]></description><link>https://fargostreet.com/post/18024</link><guid isPermaLink="true">https://fargostreet.com/post/18024</guid><dc:creator><![CDATA[bestoneyet]]></dc:creator><pubDate>Wed, 22 Dec 2004 22:13:45 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Wed, 22 Dec 2004 21:49:29 GMT]]></title><description><![CDATA[<p dir="auto">I have a 90 plymouth laser that did the same thing. My problem was that my engine leand out and i broke a valve, and that was why my engine was doing that exact same thing. Not to scare you cause it could be something minor like what you are thinking but that is what happened to me. <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f62e.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--open_mouth" style="height:23px;width:auto;vertical-align:middle" title=":o" alt="😮" /></p>
]]></description><link>https://fargostreet.com/post/18023</link><guid isPermaLink="true">https://fargostreet.com/post/18023</guid><dc:creator><![CDATA[frntwhllaser]]></dc:creator><pubDate>Wed, 22 Dec 2004 21:49:29 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Sat, 18 Dec 2004 05:02:38 GMT]]></title><description><![CDATA[<p dir="auto">Ran 30 psi , 400+hp , rev to 7200  down the track in 11 sec's</p>
<p dir="auto">Stock is fine .....</p>
<p dir="auto">Kevin</p>
<p dir="auto">SLS</p>
<p dir="auto">PS I may have my ol stock wires for sale....</p>
]]></description><link>https://fargostreet.com/post/17352</link><guid isPermaLink="true">https://fargostreet.com/post/17352</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Sat, 18 Dec 2004 05:02:38 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Sat, 11 Dec 2004 00:45:28 GMT]]></title><description><![CDATA[<p dir="auto">I'll talk to you then.</p>
]]></description><link>https://fargostreet.com/post/16272</link><guid isPermaLink="true">https://fargostreet.com/post/16272</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sat, 11 Dec 2004 00:45:28 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Fri, 10 Dec 2004 17:35:02 GMT]]></title><description><![CDATA[<p dir="auto">I will call some time next week maybe tues. to get the tires put on.</p>
]]></description><link>https://fargostreet.com/post/16237</link><guid isPermaLink="true">https://fargostreet.com/post/16237</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 10 Dec 2004 17:35:02 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Fri, 10 Dec 2004 06:24:57 GMT]]></title><description><![CDATA[<p dir="auto">Glad to hear it.</p>
]]></description><link>https://fargostreet.com/post/16213</link><guid isPermaLink="true">https://fargostreet.com/post/16213</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Fri, 10 Dec 2004 06:24:57 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Fri, 10 Dec 2004 06:14:35 GMT]]></title><description><![CDATA[<p dir="auto">Ok just to follw-up on the problem I was having.  Weshole helped me get some plug wires which therefore once installed ended my problem.  Car feels so much better now.</p>
]]></description><link>https://fargostreet.com/post/16210</link><guid isPermaLink="true">https://fargostreet.com/post/16210</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 10 Dec 2004 06:14:35 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Sun, 05 Dec 2004 06:24:53 GMT]]></title><description><![CDATA[<p dir="auto">OK will do.</p>
<p dir="auto">Hopefully it should solve one of my problems.</p>
]]></description><link>https://fargostreet.com/post/15623</link><guid isPermaLink="true">https://fargostreet.com/post/15623</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sun, 05 Dec 2004 06:24:53 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Sun, 05 Dec 2004 06:23:03 GMT]]></title><description><![CDATA[<p dir="auto">If you want to get some wires on monday, call me at work. I get there at 11:00 in the morning and will be there till we close at 7:00 pm.</p>
]]></description><link>https://fargostreet.com/post/15622</link><guid isPermaLink="true">https://fargostreet.com/post/15622</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sun, 05 Dec 2004 06:23:03 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Sun, 05 Dec 2004 06:10:15 GMT]]></title><description><![CDATA[<p dir="auto">I knew it was inevitable that it would go so I decided to save myself the agony of breaking during a race or something and would just get it rebuilt.</p>
]]></description><link>https://fargostreet.com/post/15620</link><guid isPermaLink="true">https://fargostreet.com/post/15620</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sun, 05 Dec 2004 06:10:15 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Sun, 05 Dec 2004 06:08:56 GMT]]></title><description><![CDATA[<p dir="auto">At least your getting prepared. At least mentally if not finacially.</p>
]]></description><link>https://fargostreet.com/post/15619</link><guid isPermaLink="true">https://fargostreet.com/post/15619</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sun, 05 Dec 2004 06:08:56 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Sun, 05 Dec 2004 06:07:02 GMT]]></title><description><![CDATA[<blockquote>
They can get JDM takeouts as far as I know.<br />
you would probably be just fine sending it to Shep or if your feeling really rich send it to T.R.E.<br />
I am thinking a Shep rebuilt tranny with a new differential and rear end should do the trick for me and it should hold all the horsepower I want to throw at it.</p>
<p dir="auto">Are any of those cars for sale and in running condition?  My sister wants to get a car like mine.</p>
]]></description><link>https://fargostreet.com/post/15616</link><guid isPermaLink="true">https://fargostreet.com/post/15616</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sun, 05 Dec 2004 06:07:02 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Sun, 05 Dec 2004 06:05:00 GMT]]></title><description><![CDATA[<p dir="auto">They can get JDM takeouts as far as I know.<br />
you would probably be just fine sending it to Shep or if your feeling really rich send it to T.R.E.</p>
]]></description><link>https://fargostreet.com/post/15615</link><guid isPermaLink="true">https://fargostreet.com/post/15615</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sun, 05 Dec 2004 06:05:00 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Sun, 05 Dec 2004 06:02:46 GMT]]></title><description><![CDATA[<blockquote>
You havent done a tranny yet but you will I have faith.<br />
That is in the plans this summer.  I was planning on sending it out to Shep.  Does SLS do Tranny rebuilds?  I am sure they have some loaner cars for me too. <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":p" alt="😛" /></p>
]]></description><link>https://fargostreet.com/post/15614</link><guid isPermaLink="true">https://fargostreet.com/post/15614</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sun, 05 Dec 2004 06:02:46 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Sun, 05 Dec 2004 05:52:48 GMT]]></title><description><![CDATA[<p dir="auto">You havent done a tranny yet but you will I have faith.</p>
]]></description><link>https://fargostreet.com/post/15613</link><guid isPermaLink="true">https://fargostreet.com/post/15613</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sun, 05 Dec 2004 05:52:48 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Sun, 05 Dec 2004 05:46:13 GMT]]></title><description><![CDATA[<blockquote>
Wait it's still a DSM, well they can't stop it from breaking. LOL. jk.<br />
I hear ya.</p>
<p dir="auto">So far really my DSM has only given the one problem and the rest of the stuff is just routine maintenance.</p>
]]></description><link>https://fargostreet.com/post/15612</link><guid isPermaLink="true">https://fargostreet.com/post/15612</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sun, 05 Dec 2004 05:46:13 GMT</pubDate></item><item><title><![CDATA[Reply to DSM problem. :mad: on Sun, 05 Dec 2004 05:39:30 GMT]]></title><description><![CDATA[<p dir="auto">Wait it's still a DSM, well they can't stop it from breaking. LOL. jk.</p>
]]></description><link>https://fargostreet.com/post/15611</link><guid isPermaLink="true">https://fargostreet.com/post/15611</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sun, 05 Dec 2004 05:39:30 GMT</pubDate></item></channel></rss>
