<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[taking apart a door]]></title><description><![CDATA[<p dir="auto">Hey, I need some help.  I want to take the inside of the door off so I can put new speakers in.  The car is a 92 nissan Sentra.  I found the screws all the way around the door....got those off.  Then the handgrip, there is two parts.  Got that off.  But the door is still stuck.  The only other thing I can see is the manual window turner bar thingy, and then the door handle to open the door.  Do these have to come off too, and how?  If anyone can help that would be great.  I would much rather do it myself than take it to best buy and have them charge me up the ass to take the door apart when I have installed many speakers before so that part is easy.</p>
<p dir="auto">While your at it, if anyone knows the process for taking apart the rear dash that would be nice to know too.  All four speakers are blown.  I want to put in 4 new speakers, and install subs.  In order to get at the rear speakers, you have to take the rear seat out, and then disassemble the rear dash.  Pain in the ass, and I dont know how to do it.  Any help would be excelent!</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://fargostreet.com/topic/899/taking-apart-a-door</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 15:20:50 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/899.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Dec 2004 18:31:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to taking apart a door on Mon, 06 Dec 2004 01:31:03 GMT]]></title><description><![CDATA[<p dir="auto">wow, this is gonna be a fucking chore....wow</p>
]]></description><link>https://fargostreet.com/post/15683</link><guid isPermaLink="true">https://fargostreet.com/post/15683</guid><dc:creator><![CDATA[jct_4628]]></dc:creator><pubDate>Mon, 06 Dec 2004 01:31:03 GMT</pubDate></item><item><title><![CDATA[Reply to taking apart a door on Sun, 05 Dec 2004 23:46:28 GMT]]></title><description><![CDATA[<p dir="auto">u may have to take the side plastic off the back windows to get the back dash out, i had to w my old 93 sentra</p>
]]></description><link>https://fargostreet.com/post/15680</link><guid isPermaLink="true">https://fargostreet.com/post/15680</guid><dc:creator><![CDATA[krazysmurf]]></dc:creator><pubDate>Sun, 05 Dec 2004 23:46:28 GMT</pubDate></item><item><title><![CDATA[Reply to taking apart a door on Sat, 04 Dec 2004 01:04:52 GMT]]></title><description><![CDATA[<p dir="auto">to take the door panel off you shouldnt have to take the manual window thing.....it just slides around that....it will take a little work to get it off because ther are them little white tihngs and go into the door just pull hard they should come out...unless it sounds like its gonna break or something...usually theres just a couple of screws to take the door panel off......as for the back speakers...inside the trunk there should be 2 little clips that slide over some of the plastic or whatever it is in the trunk...you have to push them over to where there is a gap and then the carpet/cardboard shit thats covering the speakers..and then it should come right off....hopefully you can tell waht im talking about i dont konw the right terms so hopefully i was some help.</p>
]]></description><link>https://fargostreet.com/post/15416</link><guid isPermaLink="true">https://fargostreet.com/post/15416</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sat, 04 Dec 2004 01:04:52 GMT</pubDate></item><item><title><![CDATA[Reply to taking apart a door on Fri, 03 Dec 2004 23:18:04 GMT]]></title><description><![CDATA[<p dir="auto">I checked....they dont drop out.  Thats why im here posting for help</p>
]]></description><link>https://fargostreet.com/post/15403</link><guid isPermaLink="true">https://fargostreet.com/post/15403</guid><dc:creator><![CDATA[jct_4628]]></dc:creator><pubDate>Fri, 03 Dec 2004 23:18:04 GMT</pubDate></item><item><title><![CDATA[Reply to taking apart a door on Fri, 03 Dec 2004 21:45:33 GMT]]></title><description><![CDATA[<p dir="auto">yeah, the tool you most likely need to remove the crank handle is a towel as shown here -&gt; <a href="http://www.carstereohelp.com/stereoremovalChevyBlazerRSpk.htm" rel="nofollow ugc">http://www.carstereohelp.com/stereoremovalChevyBlazerRSpk.htm</a>.  Once the screws are removed the panel will still be held on by some clips and you'll need to tug pretty hard to get the panel off.  Start at the bottom and work around the sides.  The panel will probably hook over the top of the door sill so you then lift i up.  It takes some finess getting them off.</p>
<p dir="auto">Removing the rear dash usually involved removing the seat bottom, then the back and sometimes the back trim.  Have you checked to see if the speakers will drop from inside the trunk?  It'd bit a real bitch to take your back seat apart only to find they drop from in the trunk <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/15390</link><guid isPermaLink="true">https://fargostreet.com/post/15390</guid><dc:creator><![CDATA[mym6]]></dc:creator><pubDate>Fri, 03 Dec 2004 21:45:33 GMT</pubDate></item><item><title><![CDATA[Reply to taking apart a door on Fri, 03 Dec 2004 21:41:11 GMT]]></title><description><![CDATA[<p dir="auto">no on the inside of the handle there should be a pin on the handle crank push the pannel in and use pliers needle nose should work and pull that thing off and ur pannel should come off</p>
]]></description><link>https://fargostreet.com/post/15388</link><guid isPermaLink="true">https://fargostreet.com/post/15388</guid><dc:creator><![CDATA[My NOva]]></dc:creator><pubDate>Fri, 03 Dec 2004 21:41:11 GMT</pubDate></item><item><title><![CDATA[Reply to taking apart a door on Fri, 03 Dec 2004 21:26:16 GMT]]></title><description><![CDATA[<p dir="auto">there is a tool for removing window turner thingies</p>
]]></description><link>https://fargostreet.com/post/15386</link><guid isPermaLink="true">https://fargostreet.com/post/15386</guid><dc:creator><![CDATA[out there]]></dc:creator><pubDate>Fri, 03 Dec 2004 21:26:16 GMT</pubDate></item><item><title><![CDATA[Reply to taking apart a door on Fri, 03 Dec 2004 21:07:42 GMT]]></title><description><![CDATA[<p dir="auto">anything else around the door handle?? Sometimes there's a bolt in the center usually around the door handle... ?? Just a suggestion</p>
]]></description><link>https://fargostreet.com/post/15384</link><guid isPermaLink="true">https://fargostreet.com/post/15384</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 03 Dec 2004 21:07:42 GMT</pubDate></item></channel></rss>
