<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fired the 6.0L tonight!]]></title><description><![CDATA[<p dir="auto">Well tonight after thinking about it for about a week, i got my 6 wires soldered into my main harness, and stuckem in the fuse block.  needless to say it worked, have spark and the injectors work.<br />
You guys are gonna laugh at how i did this, just picture it in your head.  i cant for the life of me get the damn fittings in the fuel system to quit leaking, all ive ever seen is oil them up and tighten them till they dont leak, but i think ill teflon them and see if that works, b ut if i end up pulling the rails ill probably just TIG em on there.  SO, i ended up running the 2 power wires from the battery on the ground to the fuse block, and i could only find 4 spark plugs layin around, so i punched em in the heads.  ran a hot to the fuel pump feed in the fuse block till everything started to leak, and hit the key.  damn thing fired almost instantly, then died from lack of fuel of course.  But anyway that was all i was trying to do as it doesnt have oil or a damn filter on it even, BUT i know it will run now so im happy.  at least now i can pull the tune out of the PCM and change it over to 2 Bar speed density and the 65lb injectors.  Maybe next week i will be able to have it start and run on its own accord for a few minutes and see what kind of issues i have to deal with next.  But i bet it will be 2 weeks before that happens, so who knows.<br />
Gary</p>
]]></description><link>https://fargostreet.com/topic/9185/fired-the-6.0l-tonight</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 22:27:01 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/9185.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Jan 2007 06:06:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Sat, 27 Jan 2007 15:41:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">dynotune wrote:<br />
.  I got a 6.0L (402)  going in a C5 right now also, but equipped with a pair of 67s :icon_thumright:</p>
<p dir="auto">:icon_puke_r:</p>
]]></description><link>https://fargostreet.com/post/141264</link><guid isPermaLink="true">https://fargostreet.com/post/141264</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Sat, 27 Jan 2007 15:41:11 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Sat, 27 Jan 2007 15:25:56 GMT]]></title><description><![CDATA[<p dir="auto">the best way to do the ls motor is to pack the pump when you assemble the engine (with assy lube, pet jelly, whatever).  Then crank it with the plugs out until you see pressure, and tadda! yer done.  But if you crank it with no oil in it, the pump can/ will lose it's prime pretty easy.  I've done quite a few of these, and this seems to work the best.  No, you didn't hurt anything when you did that obviously, but it didn't help.  Good luck...  I got a 6.0L (402)  going in a C5 right now also, but equipped with a pair of 67s :icon_thumright:</p>
]]></description><link>https://fargostreet.com/post/141262</link><guid isPermaLink="true">https://fargostreet.com/post/141262</guid><dc:creator><![CDATA[dynotune]]></dc:creator><pubDate>Sat, 27 Jan 2007 15:25:56 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Thu, 25 Jan 2007 03:13:43 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">XJHEAD wrote:<br />
You can crank it over too. Short spurts. Just make sure you aren't dumping fuel into the engine.  Most engines will not dump fuel at WOT when cranking.</p>
<p dir="auto">I just unhook the injectors and then crank away with the plugs out.  Taking the plugs out makes it so there is no force put on the bearings while you crank it.</p>
]]></description><link>https://fargostreet.com/post/140762</link><guid isPermaLink="true">https://fargostreet.com/post/140762</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Thu, 25 Jan 2007 03:13:43 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Thu, 25 Jan 2007 01:47:20 GMT]]></title><description><![CDATA[<p dir="auto">You can crank it over too. Short spurts. Just make sure you aren't dumping fuel into the engine.  Most engines will not dump fuel at WOT when cranking.</p>
]]></description><link>https://fargostreet.com/post/140744</link><guid isPermaLink="true">https://fargostreet.com/post/140744</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Thu, 25 Jan 2007 01:47:20 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Thu, 25 Jan 2007 01:37:34 GMT]]></title><description><![CDATA[<p dir="auto">uhh...i know how to do it, and have before.</p>
<p dir="auto">just wanted to know the quick way thats done whenever an engine sits for over a month.</p>
<p dir="auto">sounds like a lot of work to me..</p>
]]></description><link>https://fargostreet.com/post/140740</link><guid isPermaLink="true">https://fargostreet.com/post/140740</guid><dc:creator><![CDATA[slowvo]]></dc:creator><pubDate>Thu, 25 Jan 2007 01:37:34 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Thu, 25 Jan 2007 01:22:28 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://www.jasperengines.com/pdf/FordEngineOilPrimingTB.pdf" rel="nofollow ugc">http://www.jasperengines.com/pdf/FordEngineOilPrimingTB.pdf</a></p>
]]></description><link>https://fargostreet.com/post/140733</link><guid isPermaLink="true">https://fargostreet.com/post/140733</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Thu, 25 Jan 2007 01:22:28 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Thu, 25 Jan 2007 01:20:48 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">slowvo wrote:<br />
How do you do this?</p>
<p dir="auto">Some motors have the distributor drive a shaft that connects to the oil pump.<br />
You mark dist setting and rotor setting then you pull it out and either use a speed wrench(hard) or get a drill. Fords spin in reverse not too sure on chebby rotation clockwise I think...</p>
<h2>Oh something I also saw</h2>
<p dir="auto">From: Neon John <a href="mailto:johngdNOSPAM@bellsouth.net" rel="nofollow ugc">johngdNOSPAM@bellsouth.net</a><br />
Subject: Re: Oil Priming an LT1?<br />
Date: Tue, 10 Aug 1999 18:03:00 EDT<br />
Newsgroups: rec.autos.rod-n-custom</p>
<p dir="auto"><a href="mailto:wojeda_removethistoreply@qgraph.com" rel="nofollow ugc">wojeda_removethistoreply@qgraph.com</a> wrote:</p>
<p dir="auto">Yeap, what I was thinking to do was to squirt some oil into the piston<br />
chambers of all eight and disconnect the fuel pump relay (pull the<br />
fuse) and crank it for a while. But this, I think, could still be to<br />
hard on an engine that has been sleeping for so long. I was looking<br />
for other solutions.  Any of you guys ever heard of preassure priming?<br />
I don't know how it works, but I believe it involves compressed air.<br />
And of course there is the external electric pump, but last time I<br />
checked it was in the upper $400. (not an option).</p>
<p dir="auto">I have a rig I use on all new engine starts.  It consists of a<br />
stainless steel 5 gal Coke syrup can equipped with a schrader air<br />
valve, a hose, a ball valve and a check valve.  The tank is filled<br />
with 2 gallons of oil, pressurized to 100 psi and the end of the<br />
hose with the check valve and ball valve is screwed into the oil<br />
sender port.  Or in the unusual event the sender isn't easily<br />
accessible, I use a modified freon side tapper to pierce the side of<br />
an oil filter and tap in there.</p>
<p dir="auto">In use, the can is sat on  refrigerant scales  (just because I have<br />
'em), the ball valve turned on and when the scales indicate about a<br />
gallon of oil has flowed in the engine and oil is visible through<br />
the oil filler hole, the engine is fired.  The oil is allowed to<br />
continue to flow until the scales indicate the proper quantity of<br />
oil is in the engine.  The 100 psi air pressure in the can will<br />
override the oil pump and lift its relief valve at fast idle.  The<br />
check valve prevents any oil from being pumped back to the tank in<br />
the event the air pressure is too low.  When the correct amount of<br />
oil is in the engine, turn the ball valve and continue with the cam<br />
break-in procedure.</p>
<p dir="auto">The advantage of this procedure is a) it's cheap - the tank can be<br />
had at flea markets or even from Coke, b) it fills the filter, the<br />
galleys and primes the pump, c) one can verify proper oil flow<br />
BEFORE firing the engine for the first time, and d) you don't have<br />
to fool with any sort of priming tool and the attendant risk of<br />
damage to the engine or of dropping something down the hole.</p>
<p dir="auto">If you don't have scales, you can simply put the correct amount of<br />
oil in the tank and flow it in until you see bubbles in the line<br />
indicating the tank is getting empty.  I use the fabric reinforced<br />
plastic hose that the coke company uses.  If that is not available,<br />
one can use the clear fabric reinforced PVC hose available at Lowes,<br />
Home Depot and the like.</p>
]]></description><link>https://fargostreet.com/post/140732</link><guid isPermaLink="true">https://fargostreet.com/post/140732</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Thu, 25 Jan 2007 01:20:48 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Wed, 24 Jan 2007 06:05:13 GMT]]></title><description><![CDATA[<blockquote>
I always prime the oil system in a vehicles thats been sitting more than a month before I fire it up...</p>
<p dir="auto">How do you do this?</p>
]]></description><link>https://fargostreet.com/post/140575</link><guid isPermaLink="true">https://fargostreet.com/post/140575</guid><dc:creator><![CDATA[slowvo]]></dc:creator><pubDate>Wed, 24 Jan 2007 06:05:13 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Tue, 23 Jan 2007 06:54:48 GMT]]></title><description><![CDATA[<p dir="auto">also i would have primed it in the first place, but guess what, LS motors have a crank driven oil pump and the only way to prime them is?, you guessed it, turning the damn thing over.  So i guess all the shops out there that build motors are fuckin morons for turning the engine over for ten seconds while the oil system pressurises, right?  YEP, i think those 4 or 5 combustion events took the babbitt right off the bearings and i have to rebuild it now.  Oh but i forgot, the whole point of this board is to bash anything that isnt yours.<br />
Gary</p>
]]></description><link>https://fargostreet.com/post/140296</link><guid isPermaLink="true">https://fargostreet.com/post/140296</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Tue, 23 Jan 2007 06:54:48 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Tue, 23 Jan 2007 03:03:59 GMT]]></title><description><![CDATA[<p dir="auto">I always prime the oil system in a vehicles thats been sitting more than a month before I fire it up...</p>
]]></description><link>https://fargostreet.com/post/140186</link><guid isPermaLink="true">https://fargostreet.com/post/140186</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Tue, 23 Jan 2007 03:03:59 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Tue, 23 Jan 2007 02:54:29 GMT]]></title><description><![CDATA[<p dir="auto">Like he said, if it only spun 4 or 5 revolutions and had a small amount of lube on it then it's going to be close to a hard startup. Just like a car that's been stored over winter and starts up for the first time will experience.</p>
]]></description><link>https://fargostreet.com/post/140179</link><guid isPermaLink="true">https://fargostreet.com/post/140179</guid><dc:creator><![CDATA[StangerBanger96]]></dc:creator><pubDate>Tue, 23 Jan 2007 02:54:29 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Tue, 23 Jan 2007 02:41:00 GMT]]></title><description><![CDATA[<p dir="auto">Still doesn't mean there wasn't damage to the bearings.  I don't know why you'd risk it on a motor you plan on making big power with.  It's not a D series honda.</p>
]]></description><link>https://fargostreet.com/post/140175</link><guid isPermaLink="true">https://fargostreet.com/post/140175</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Tue, 23 Jan 2007 02:41:00 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Tue, 23 Jan 2007 02:09:07 GMT]]></title><description><![CDATA[<p dir="auto">Especially if the engine was ran with synthetic oil. I can't find a link to it but I know there was a test on 2 engines, 1 had only used synthetic and the other only dino oil. They drained them down and ran them oilless, it was like 10min and the dino seized while the synthetic kept going for quite awhile.</p>
]]></description><link>https://fargostreet.com/post/140168</link><guid isPermaLink="true">https://fargostreet.com/post/140168</guid><dc:creator><![CDATA[StangerBanger96]]></dc:creator><pubDate>Tue, 23 Jan 2007 02:09:07 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Tue, 23 Jan 2007 02:04:43 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Grr wrote:<br />
well i really dont think that turning it over for 4 or 5 revolutions really has any type of drastic effect on bearing life.  not like i sat there and rev'ed on it for 5 minutes.  really guys get a clue, people have run motors without any oil in them for 10 minutes or better just for shits and giggles.  Also, its really no different than every time you go outside and start your car in the morning and it takes 5 revolutions to pressurise the oiling system.  It honestly isnt something that does not occur to every motor numerous times in its life in the first place.<br />
Gary<br />
OK:icon_salut:</p>
]]></description><link>https://fargostreet.com/post/140166</link><guid isPermaLink="true">https://fargostreet.com/post/140166</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Tue, 23 Jan 2007 02:04:43 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Tue, 23 Jan 2007 01:43:49 GMT]]></title><description><![CDATA[<p dir="auto">ive worked on cars that left the shop with no oil, drove 50 miles, drove back with the oil light on without any problems (30k down the road)<br />
it happens quite a bit acually...damn lube bitch!</p>
]]></description><link>https://fargostreet.com/post/140159</link><guid isPermaLink="true">https://fargostreet.com/post/140159</guid><dc:creator><![CDATA[slowvo]]></dc:creator><pubDate>Tue, 23 Jan 2007 01:43:49 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Mon, 22 Jan 2007 21:42:46 GMT]]></title><description><![CDATA[<p dir="auto">well i really dont think that turning it over for 4 or 5 revolutions really has any type of drastic effect on bearing life.  not like i sat there and rev'ed on it for 5 minutes.  really guys get a clue, people have run motors without any oil in them for 10 minutes or better just for shits and giggles.  Also, its really no different than every time you go outside and start your car in the morning and it takes 5 revolutions to pressurise the oiling system.  It honestly isnt something that does not occur to every motor numerous times in its life in the first place.<br />
Gary</p>
]]></description><link>https://fargostreet.com/post/140097</link><guid isPermaLink="true">https://fargostreet.com/post/140097</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Mon, 22 Jan 2007 21:42:46 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Mon, 22 Jan 2007 15:49:11 GMT]]></title><description><![CDATA[<p dir="auto">Congrats on getting it fired, but ouch on the bearings for no oil.  Hopefully the assembly lube did it's job.</p>
]]></description><link>https://fargostreet.com/post/139997</link><guid isPermaLink="true">https://fargostreet.com/post/139997</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Mon, 22 Jan 2007 15:49:11 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Mon, 22 Jan 2007 15:07:50 GMT]]></title><description><![CDATA[<p dir="auto">I agree.  You actually fired it with no oil in it?  That is retarded.</p>
]]></description><link>https://fargostreet.com/post/139990</link><guid isPermaLink="true">https://fargostreet.com/post/139990</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 22 Jan 2007 15:07:50 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Mon, 22 Jan 2007 13:50:06 GMT]]></title><description><![CDATA[<blockquote>
it doesnt have oil or a damn filter on it even, .  Maybe next week i will be able to have it start and run on its own accord for a few minutes and see what kind of issues i have to deal with next.  Gary<br />
:eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:</p>
<p dir="auto">I would guess maybe bad bearings???</p>
]]></description><link>https://fargostreet.com/post/139980</link><guid isPermaLink="true">https://fargostreet.com/post/139980</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Mon, 22 Jan 2007 13:50:06 GMT</pubDate></item><item><title><![CDATA[Reply to Fired the 6.0L tonight! on Mon, 22 Jan 2007 12:07:02 GMT]]></title><description><![CDATA[<p dir="auto">is this going to be the rotary smasher? <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/139973</link><guid isPermaLink="true">https://fargostreet.com/post/139973</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Mon, 22 Jan 2007 12:07:02 GMT</pubDate></item></channel></rss>
