<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[what size turbo on your DSM?]]></title><description><![CDATA[<p dir="auto">i was thinking about this today when i was looking at the turbo chart i posted up.  i have an auto trans 1g, and when my 13G melted i put what i had availible on there.  Well knowing this was a little big i figured i would try it anyway.  Although, on DSMtuners where i frequent, most people say a 50-trim is sufficient if not big for a street car, well heres a comparison:</p>
<p dir="auto">20G-60 inducer,52.60mm  major, 68.00mm<br />
turbine,  TD06-S inducer, 55.10mm major, 65.00mm</p>
<p dir="auto">what i have on there currently</p>
<p dir="auto">TO4-E 60 Trim  inducer, 58.17mm  major, 74.93mm<br />
T3 stage III inducer, 56.62mm  major, 65.00mm</p>
<p dir="auto">Anyway what im getting at is that i have something on a bone stock car, except for a 3" exhaust and its quite a bit bigger than a 20G.  Thats freakin big for a DSM and i see alot of complaints about spool time with anything bigger than a 16G.  Are these people serious or am i just that much more resilient to turbo lag?  I mean i even have the stock auto cams (tiny) and no porting of any kind and i have full boost by 4500, and it pulls like a train anywhere over 4000.  Currently i am running 11-12 PSi and occasionally hit fuel cut, which is very annoying.  I know its too big, and im dropping it to this next week:</p>
<p dir="auto">TO4-B S trim  inducer-48.36mm, 69.85mm<br />
Turbine is about a 50mm inducer, 58.6mm major that was specific to Buick GNs.  This is more comparable, basically a 16G turbine, and a 18G compressor.</p>
<p dir="auto">16G-60 46.5 57.00<br />
TD05-H 49.00 56.00</p>
<p dir="auto">i think my spoolup will move into the 32-3500 range and i hope to be able to hold around 4-6psi on the footbrake.  with the 60-trim i can get .25-.5psi on the brake as it only spools to around 2300 on a 3000 stall converter.  SO, how big a turbo you have and what are your thoughts on it?  is it too laggy?  too small?  am i crazy?  Also i am doing this all with a round 3-bolt housing bolted up to the stock 1G manifold.  it was too easy to make this work BTW<br />
Gary</p>
]]></description><link>https://fargostreet.com/topic/9264/what-size-turbo-on-your-dsm</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 07:35:02 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/9264.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Jan 2007 07:38:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to what size turbo on your DSM? on Sat, 27 Jan 2007 18:52:13 GMT]]></title><description><![CDATA[<p dir="auto">i had the standard big16g evo3 turbo.....it was decent.</p>
]]></description><link>https://fargostreet.com/post/141291</link><guid isPermaLink="true">https://fargostreet.com/post/141291</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Sat, 27 Jan 2007 18:52:13 GMT</pubDate></item><item><title><![CDATA[Reply to what size turbo on your DSM? on Sat, 27 Jan 2007 15:39:34 GMT]]></title><description><![CDATA[<p dir="auto">holset hx35, great turbo, especially great price.<br />
=J-</p>
]]></description><link>https://fargostreet.com/post/141263</link><guid isPermaLink="true">https://fargostreet.com/post/141263</guid><dc:creator><![CDATA[RudeAwakening Motorsports]]></dc:creator><pubDate>Sat, 27 Jan 2007 15:39:34 GMT</pubDate></item><item><title><![CDATA[Reply to what size turbo on your DSM? on Sat, 27 Jan 2007 06:07:44 GMT]]></title><description><![CDATA[<p dir="auto">I loved my 50 trim as well...spooled quickly and definately had enough pull...</p>
]]></description><link>https://fargostreet.com/post/141243</link><guid isPermaLink="true">https://fargostreet.com/post/141243</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Sat, 27 Jan 2007 06:07:44 GMT</pubDate></item><item><title><![CDATA[Reply to what size turbo on your DSM? on Sat, 27 Jan 2007 06:00:32 GMT]]></title><description><![CDATA[<p dir="auto">Well my bros talon rocks a T4 blowzilla 61mm  we get 18psi on the stall and boosts very quick, you should get a IPT Stall converter.. theres a guy who went 10.00 with a stock engine stock tranny with shift kit stall, headstuds upgraded turbo fmic injectors,supporting mods..</p>
<p dir="auto">you can spool anything with an auto/stall and if you cant nos can...</p>
<p dir="auto">btw 20g's are old technology, I used to ran a PTE 50 TRIM and i loved it best turbo I ever had but would always smoke and blow up... I then ran a pte scm61 and it was a little big unless you did alot of drag racing/highway pulls.</p>
<p dir="auto">If i was gonna buy a turbo for a daily driven dsm id get:</p>
<p dir="auto">borg wanger s256, Garret gt30r pte bb50 trim</p>
]]></description><link>https://fargostreet.com/post/141239</link><guid isPermaLink="true">https://fargostreet.com/post/141239</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Sat, 27 Jan 2007 06:00:32 GMT</pubDate></item><item><title><![CDATA[Reply to what size turbo on your DSM? on Sat, 27 Jan 2007 05:57:32 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Grr wrote:<br />
you should hear dual intank 255s sometime, then it starts getting loud.</p>
<p dir="auto">They aren't that loud even with 2...it just means your car is too quiet...</p>
]]></description><link>https://fargostreet.com/post/141238</link><guid isPermaLink="true">https://fargostreet.com/post/141238</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Sat, 27 Jan 2007 05:57:32 GMT</pubDate></item><item><title><![CDATA[Reply to what size turbo on your DSM? on Sat, 27 Jan 2007 04:53:28 GMT]]></title><description><![CDATA[<p dir="auto">i roll with the hahn 20g on my 2g.  Definately a little laggy, but boost hits hard.</p>
]]></description><link>https://fargostreet.com/post/141235</link><guid isPermaLink="true">https://fargostreet.com/post/141235</guid><dc:creator><![CDATA[tyklein8]]></dc:creator><pubDate>Sat, 27 Jan 2007 04:53:28 GMT</pubDate></item><item><title><![CDATA[Reply to what size turbo on your DSM? on Sat, 27 Jan 2007 03:04:50 GMT]]></title><description><![CDATA[<p dir="auto">I would say the 14b/16gs make boost too fast and you really arent making power at that low of an rpm anyways.<br />
stay with stock turbo or go with a (smaller) bit turbo. I dont think the 16G really makes much of an difference, there are way too many other variables that affect power</p>
]]></description><link>https://fargostreet.com/post/141232</link><guid isPermaLink="true">https://fargostreet.com/post/141232</guid><dc:creator><![CDATA[slowvo]]></dc:creator><pubDate>Sat, 27 Jan 2007 03:04:50 GMT</pubDate></item><item><title><![CDATA[Reply to what size turbo on your DSM? on Fri, 26 Jan 2007 23:47:58 GMT]]></title><description><![CDATA[<p dir="auto">Rockin pte 57 trim</p>
]]></description><link>https://fargostreet.com/post/141220</link><guid isPermaLink="true">https://fargostreet.com/post/141220</guid><dc:creator><![CDATA[gszzzzx]]></dc:creator><pubDate>Fri, 26 Jan 2007 23:47:58 GMT</pubDate></item><item><title><![CDATA[Reply to what size turbo on your DSM? on Fri, 26 Jan 2007 21:26:43 GMT]]></title><description><![CDATA[<p dir="auto">walbros loud??  man i must be wierd cause i dont think they are.  you should hear dual intank 255s sometime, then it starts getting loud.  I have to step up to the 2 intanks next winter on the buick.<br />
Anyway you say you had 16G's, how did you like them anyway.  thats what im trying to figure out.  I have heard alot of comments that a ball bearing 50-trim will outspool a 16G, and make about 20hp more.  And yes it is ass backwards, i was able to hold whatever i could with the 13G, and it was out of steam by 4000, now it comes on at 4000 and pulls to around 58-6200, then those tiny cams hold it back.<br />
I am excited to drive this thing with th full manual 4-speed auto and leaving with aobut 6psi, should run low 13s pretty easy.  may also put some meth injection on it and go for 18psi and some 12's<br />
Gary</p>
]]></description><link>https://fargostreet.com/post/141174</link><guid isPermaLink="true">https://fargostreet.com/post/141174</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Fri, 26 Jan 2007 21:26:43 GMT</pubDate></item><item><title><![CDATA[Reply to what size turbo on your DSM? on Fri, 26 Jan 2007 20:15:54 GMT]]></title><description><![CDATA[<p dir="auto">i was rollin the 16g back in my dsm dayz</p>
]]></description><link>https://fargostreet.com/post/141163</link><guid isPermaLink="true">https://fargostreet.com/post/141163</guid><dc:creator><![CDATA[blackcherryTSi]]></dc:creator><pubDate>Fri, 26 Jan 2007 20:15:54 GMT</pubDate></item><item><title><![CDATA[Reply to what size turbo on your DSM? on Fri, 26 Jan 2007 18:54:54 GMT]]></title><description><![CDATA[<p dir="auto">Walbros loud?..... no <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">I have pissed around with gary in that car, and the characteristics of the car are completely backwards of when the 13g was on.</p>
]]></description><link>https://fargostreet.com/post/141152</link><guid isPermaLink="true">https://fargostreet.com/post/141152</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Fri, 26 Jan 2007 18:54:54 GMT</pubDate></item><item><title><![CDATA[Reply to what size turbo on your DSM? on Fri, 26 Jan 2007 10:38:06 GMT]]></title><description><![CDATA[<p dir="auto">Im chillin with a ported 14b, eeprom ecu, stock injectors, and 3000gt fuel pump (did have a walbro 190, but it was loud), intake, exhaust etc..  I don't think thats the kind of response you are looking for though <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/141096</link><guid isPermaLink="true">https://fargostreet.com/post/141096</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Fri, 26 Jan 2007 10:38:06 GMT</pubDate></item></channel></rss>
