<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Used DSM Stuff]]></title><description><![CDATA[<p dir="auto">I have pics for all the items below avalabile upon request, or hell, if we can find a good time and place you can take a look at anything.</p>
<p dir="auto">Used 13g Turbo.<br />
-Working when pulled<br />
-Comp/Turbine wheels in good shape.<br />
-Virtually No shaft play with oil in the bearing.<br />
-Turbine housing is cracked, may need replacing.<br />
-Wastegate flapper not postioned quite right, MFG defect?<br />
-"Band" to hold turbine/comp housings missing.<br />
-Not sure of milage. Was told turbo was fairly new when I bought the car, I have put on about 8,000.<br />
-For non-DSM folks, this turbo spools quickly but will not hold high boost until redline. Great for low boost high compresion setups.<br />
-$50 plus shipping or best offer-</p>
<p dir="auto">1G Exhaust Manifold (Off an Auto)<br />
-No Visable Cracks<br />
-Dremel grinding on both runners and collector.<br />
-Was fine when pulled<br />
-$25 plus shipping or best offer-</p>
<p dir="auto">Auto ECU (Off 92 GSX, non-eprom)<br />
-Original Caps<br />
-Pulled from working car, no problems.<br />
<p dir="auto">MT Fuel Rail /w FPR<br />
-Not sure on year, got it cheap with 450cc injectors.<br />
-$15 plus shipping or best offer-</p>
]]></description><link>https://fargostreet.com/topic/94/used-dsm-stuff</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 13:29:35 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/94.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 22 May 2004 01:35:15 GMT</pubDate><ttl>60</ttl></channel></rss>
