<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Another full stereo]]></title><description><![CDATA[<p dir="auto">Well up for sale is my stereo out of the integra its time to take care of some stuff around the bill market lol.. not everything is rare but the 2 amps are pretty rare, in my opinion really rare. The prices that i am asking for the amps is what i want for them, and what they are worth to me so no low balling ill just have your post deleted.</p>
<p dir="auto">heres the info: They retailed near the $1k mark new asking price $250.00 per amp FIRM i don't care what they go for on ebay. you wont find them!!!<br />
the mtx thunder 2300's are limited edition amps both are chrome plated. they are old school and you'd be pretty hard pressed to find them anymore. see pictures below you will see why.</p>
<p dir="auto">i have 2 of them and they were both rated from the factory at 750 watts bridged down to mono they are a class a/b 2 channel amp stable to 2ohms mono and the birth certificate rates them well over that at 1472 watts at 2ohms and 1473 watts at 2 ohms i tried to get two matching and i got pretty close.</p>
<p dir="auto">Now for the subs i have 2 12" MTX here are the specs below These retailed at $299.99 a peice when they were new im asking $75.00 a sub which is just about half of what they are on ebay and this things freakin hit hard!!<br />
Size: 12 inch<br />
Rec. Sealed Box Dims: 1.00 - 1.50 cu.ft.<br />
Rec. Ported Box Dims: 1.75 - 2.25 cu.ft.<br />
Free Air Usage: not recommended<br />
Sensitivity: 89.4 dB<br />
Frequency Response: 45-150 Hz<br />
Recommended RMS Power: 400W<br />
Peak Power Handling: 800W<br />
Dual 4ohm Voice Coils.</p>
<p dir="auto">I also have a pair of Stinger Stiffening caps. They are 1 farad caps with digital readouts on them they work great retailed at $189.99 when they were new ill let them go for $50.00</p>
<p dir="auto">Last but not least my deck. A Pioneer 8400mp these decks retailed at close to $600.00 new. I just warrantied mine not even 3 months ago and had a whole new inside basically installed and the ribbon fixed. It is basically a brand new deck with some slight use on it and nothing out of the ordinary for wear and tear i don't have the remote for it i lost the damn thing, but they are cheap if you need one i can get it. They go for about 300 used on ebay plus shipping so about 350 ill let mine go for $275.00</p>
<p dir="auto">here are the specs sorry for the novel:<br />
SPECIFICATIONS</p>
<ul>
<li>MOSFET 50W x 4</li>
<li>XM Satellite Radio Ready<br />
o 8-character display for XM Radio text (no scroll) with GEX-P900XM or GEX-FM903XM<br />
o 16-character display for XM Radio text (auto-scroll) GEX-P910XM or GEX-FM913XM<br />
o XM Mode (Channel/Category) key</li>
<li>Card Remote</li>
<li>Rotary Volume Control (Pop-Up)</li>
<li>EEQ with EQ-EX Performance Chip<br />
o 3-Band Parametric Equalizer (Adjustable Level, Frequency and Q Factor)<br />
o Easy EQ (EEQ) with EQ-EX switches 10 Factory, 2 User EQ Presets<br />
o Source Custom EQ Memory (Independent Custom Memory for each source)<br />
o Selectable Loudness Control (Low/Mid/High/Off)</li>
<li>SFEQ (Sound Focus EQ)<br />
o Additional Independent Bass / Treble Control for Front / Rear</li>
<li>Two-Way Crossover<br />
o Front/Rear HPF (50/80/125Hz, -12dB/oct)<br />
o Selectable LPF (Low Pass Filter) (50/80/125Hz, -18dB/oct)<br />
o Sub-Out Level (-12dB to +12dB) and Phase Control<br />
o Independent Subwoofer Outputs</li>
<li>IP-Bus System Control<br />
o MCD Control<br />
o DVD Control<br />
o TV Tuner Control<br />
o Auxiliary Input (CD-RB10 or CD-RB20 required)<br />
o 2 External Unit Control</li>
<li>S.L.A. (Source Level Adjustment)</li>
<li>ASL (Auto Sound Levelizer)</li>
<li>Selectable Fader Control</li>
<li>Hi-volt RCA Preouts (x2 pair, Front &amp; Non-Fading or Front &amp; Sub) (4V)</li>
<li>Dual Motion, Dual Display Motorization swings open to reveal "hidden" Organic EL display</li>
<li>Dual Display - 8 Character LCD Display plus Organic EL (128x33) Display<br />
o 8-character LCD with LED backlighting on front faceplate<br />
o Organic EL (128x33) Display on rear faceplate<br />
o OEL display features Full-motion 3D graphic animations including:<br />
o 2 screensavers (Jet Ski, Sky Gate)<br />
o 2 Spectrum Analyzers and 3 Leve Meters</li>
</ul>
<ul>
<li>2 screensavers (Water Board, WRC Racing)</li>
<li>2 Level Meters</li>
<li>6 background animations</li>
<li>Clock Display and Off (Text-only) modes<br />
o 16-character text display capability<br />
o Adjustable brightness level (16-mode)</li>
</ul>
<ul>
<li>Cellular Mute input wire</li>
<li>Clock</li>
</ul>
<p dir="auto">Compact Disc</p>
<ul>
<li>Track Scan/Pause/Repeat/Random Play</li>
<li>Audible Fast-Forward/Reverse</li>
<li>Playback Compatible with Digital CD-R and CD-RW</li>
<li>Disc Title Memory (48 Discs)</li>
<li>CD Text (SCD &amp; MCD)</li>
<li>AGC (Automatic Gain Control)</li>
<li>WMA / MP3 CD-ROM Playback<br />
o Pioneer Digital SpeedRead mechanism for faster performance<br />
o ID3 Tag Capability (32 character with Auto-Scroll, On/Off)</li>
<li>8x oversampling</li>
<li>3-beam laser pick-up</li>
<li>1-bit D/A Converter</li>
<li>Anti-shock mechanism</li>
</ul>
<p dir="auto">Chassis</p>
<ul>
<li>DIN Mountable</li>
<li>Detachable Face (faceplate carrying case included)</li>
<li>Flap Face</li>
</ul>
<p dir="auto">Radio</p>
<ul>
<li>Supertuner<img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/00ae.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--registered" style="height:23px;width:auto;vertical-align:middle" title="®" alt="®" /> III<img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/2122.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--tm" style="height:23px;width:auto;vertical-align:middle" title="™" alt="™" /> Digital Tuner</li>
<li>24-Station/6-Button (18FM / 6AM) Presets</li>
<li>BSM (Best Station Memory)</li>
<li>Up/Down Seek with Selectable Local Seek Tuning</li>
</ul>
<p dir="auto">EDIT:: If a person or group wants to go in and buy it all at once ill throw in a pretty decent prefab box for the 12's and instead if it being $1050.00 total price ill go down to $900.00 thats a far cry from the $3600.00 that all this would have cost new.</p>
<p dir="auto">And a reminder no retarded low balling whoreing my thread nothing ill take trades for the whole set up for a hatch shell or something along that lines<br />
and now its pics time whoo hoo</p>
<p dir="auto"><img src="/assets/uploads/legacy/attachments/4004/8400mp.jpg" alt="8400mp.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/legacy/attachments/4005/750012.jpg" alt="750012.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/legacy/attachments/4006/limitededition.jpg" alt="limitededition.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/legacy/attachments/4007/stinger%201ferrad.jpg" alt="stinger 1ferrad.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/legacy/attachments/4008/the%20pair.jpg" alt="the pair.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/legacy/attachments/4009/thunder2300l.jpg" alt="thunder2300l.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/legacy/attachments/4010/thunder2300lmtx.jpg" alt="thunder2300lmtx.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/topic/9494/another-full-stereo</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:34:39 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/9494.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Feb 2007 17:19:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Another full stereo on Sun, 25 Feb 2007 08:02:08 GMT]]></title><description><![CDATA[<p dir="auto">How old is the deck?  Will it work with pioneer's Ipod adaptor?</p>
]]></description><link>https://fargostreet.com/post/146341</link><guid isPermaLink="true">https://fargostreet.com/post/146341</guid><dc:creator><![CDATA[capitlj]]></dc:creator><pubDate>Sun, 25 Feb 2007 08:02:08 GMT</pubDate></item><item><title><![CDATA[Reply to Another full stereo on Sun, 25 Feb 2007 06:04:41 GMT]]></title><description><![CDATA[<p dir="auto">Bump! need to move some of this stuff</p>
]]></description><link>https://fargostreet.com/post/146323</link><guid isPermaLink="true">https://fargostreet.com/post/146323</guid><dc:creator><![CDATA[4doorsslow]]></dc:creator><pubDate>Sun, 25 Feb 2007 06:04:41 GMT</pubDate></item><item><title><![CDATA[Reply to Another full stereo on Tue, 20 Feb 2007 07:34:58 GMT]]></title><description><![CDATA[<p dir="auto">Ttt!!</p>
]]></description><link>https://fargostreet.com/post/145762</link><guid isPermaLink="true">https://fargostreet.com/post/145762</guid><dc:creator><![CDATA[4doorsslow]]></dc:creator><pubDate>Tue, 20 Feb 2007 07:34:58 GMT</pubDate></item><item><title><![CDATA[Reply to Another full stereo on Fri, 16 Feb 2007 15:50:47 GMT]]></title><description><![CDATA[<blockquote>
Time for me to order you some new subs Andy?<br />
well chuck the tegs for sale as well as soon as that sells its time to start on the ody full new set up TVs and all.  we are going to have some fun</p>
]]></description><link>https://fargostreet.com/post/145101</link><guid isPermaLink="true">https://fargostreet.com/post/145101</guid><dc:creator><![CDATA[4doorsslow]]></dc:creator><pubDate>Fri, 16 Feb 2007 15:50:47 GMT</pubDate></item><item><title><![CDATA[Reply to Another full stereo on Fri, 16 Feb 2007 12:11:10 GMT]]></title><description><![CDATA[<p dir="auto">Time for me to order you some new subs Andy?</p>
]]></description><link>https://fargostreet.com/post/145083</link><guid isPermaLink="true">https://fargostreet.com/post/145083</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 16 Feb 2007 12:11:10 GMT</pubDate></item><item><title><![CDATA[Reply to Another full stereo on Fri, 16 Feb 2007 07:10:00 GMT]]></title><description><![CDATA[<p dir="auto">u forgot to mention on here that the subs are sold to me lol... just giving u crap man.. i cant wait to get them tomorrow night</p>
]]></description><link>https://fargostreet.com/post/145078</link><guid isPermaLink="true">https://fargostreet.com/post/145078</guid><dc:creator><![CDATA[wo1fpack2004]]></dc:creator><pubDate>Fri, 16 Feb 2007 07:10:00 GMT</pubDate></item><item><title><![CDATA[Reply to Another full stereo on Fri, 16 Feb 2007 03:16:29 GMT]]></title><description><![CDATA[<p dir="auto">ttt thanks for lookin guys</p>
]]></description><link>https://fargostreet.com/post/145055</link><guid isPermaLink="true">https://fargostreet.com/post/145055</guid><dc:creator><![CDATA[4doorsslow]]></dc:creator><pubDate>Fri, 16 Feb 2007 03:16:29 GMT</pubDate></item><item><title><![CDATA[Reply to Another full stereo on Wed, 14 Feb 2007 20:20:30 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">95TsiAWD wrote:<br />
Making an offer.  $250 for both 2300's.<br />
you get one for that price thats about it the amps are rare ask chuck as the resident stereo guy here on FS they arent easy to find and they wont go cheap</p>
]]></description><link>https://fargostreet.com/post/144846</link><guid isPermaLink="true">https://fargostreet.com/post/144846</guid><dc:creator><![CDATA[4doorsslow]]></dc:creator><pubDate>Wed, 14 Feb 2007 20:20:30 GMT</pubDate></item><item><title><![CDATA[Reply to Another full stereo on Wed, 14 Feb 2007 19:50:42 GMT]]></title><description><![CDATA[<p dir="auto">Making an offer.  $250 for both 2300's.</p>
]]></description><link>https://fargostreet.com/post/144841</link><guid isPermaLink="true">https://fargostreet.com/post/144841</guid><dc:creator><![CDATA[95TsiAWD]]></dc:creator><pubDate>Wed, 14 Feb 2007 19:50:42 GMT</pubDate></item><item><title><![CDATA[Reply to Another full stereo on Wed, 14 Feb 2007 17:38:26 GMT]]></title><description><![CDATA[<blockquote>
I'll give ya $200 and a kick in the ass for the whole deal....</p>
<p dir="auto">j/k  Great prices on very good products<br />
thanks Chuck</p>
]]></description><link>https://fargostreet.com/post/144820</link><guid isPermaLink="true">https://fargostreet.com/post/144820</guid><dc:creator><![CDATA[4doorsslow]]></dc:creator><pubDate>Wed, 14 Feb 2007 17:38:26 GMT</pubDate></item><item><title><![CDATA[Reply to Another full stereo on Wed, 14 Feb 2007 17:36:03 GMT]]></title><description><![CDATA[<p dir="auto">I'll give ya $200 and a kick in the ass for the whole deal....</p>
<p dir="auto">j/k  Great prices on very good products</p>
]]></description><link>https://fargostreet.com/post/144818</link><guid isPermaLink="true">https://fargostreet.com/post/144818</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Wed, 14 Feb 2007 17:36:03 GMT</pubDate></item></channel></rss>
