<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Edge EZ Power Programer]]></title><description><![CDATA[<p dir="auto"><img src="http://www.dieselperformanceparts.com/pics/fulls/EZ.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
1998.5-2000 Dodge 5.9 Liter Cummins<br />
Used Looking for $300.00</p>
<p dir="auto">Retail 500.00</p>
<p dir="auto">EZD1000 - The Power Edge EZ is a direct plug in, no wire taps or splicing, module that optomizes engine performance by monitoring engine RPM, boost pressures and fueling parameters to the individual injectors. By using this information the EZ controls the fueling and timing of the Bosch injection system. The re-calibration of the fuel and timing parameters is done via CAN-BUS communication through both the Dodge computer system and Bosch injection pump in your truck. The limits of the Bosch system and retained by the EZ module, which provides a smooth and reliable power curve. The EZ produces maximum fueling at full boost pressure to attain an additional 65 HP and 185 ft-lbs of torque with a simple 5 minute installation. The EZ plugs into the the ECM data link connector and the MAP sensor connections and your ready for more power immediately. Removal is just as easy for diagnostic servicing purposes. Being fully water tight and mounting under the hood makes the EZ the easiest performance gain available for your Dodge Cummins. Diesel Performance Parts, Inc.</p>
]]></description><link>https://fargostreet.com/topic/9725/edge-ez-power-programer</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:04:48 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/9725.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Mar 2007 06:03:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Edge EZ Power Programer on Fri, 16 Mar 2007 22:46:11 GMT]]></title><description><![CDATA[<p dir="auto">bump 235.00</p>
]]></description><link>https://fargostreet.com/post/149405</link><guid isPermaLink="true">https://fargostreet.com/post/149405</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Fri, 16 Mar 2007 22:46:11 GMT</pubDate></item><item><title><![CDATA[Reply to Edge EZ Power Programer on Thu, 15 Mar 2007 01:56:41 GMT]]></title><description><![CDATA[<p dir="auto">bump 245.oo</p>
]]></description><link>https://fargostreet.com/post/149232</link><guid isPermaLink="true">https://fargostreet.com/post/149232</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Thu, 15 Mar 2007 01:56:41 GMT</pubDate></item><item><title><![CDATA[Reply to Edge EZ Power Programer on Sat, 10 Mar 2007 04:30:53 GMT]]></title><description><![CDATA[<p dir="auto">bump -----&gt;$250.00<br />
-kevin</p>
]]></description><link>https://fargostreet.com/post/148631</link><guid isPermaLink="true">https://fargostreet.com/post/148631</guid><dc:creator><![CDATA[MazdaMP3ShiftR]]></dc:creator><pubDate>Sat, 10 Mar 2007 04:30:53 GMT</pubDate></item></channel></rss>
