  4. speedo not working
speedo not working
5 Posts 3 Posters 351 Views
    ok i got my car running and everything after the sohc to dohc swap and the 5-speed swap and the speedo didnt work we tested the speed senor and that was bad so we replace and now the speedo well work sometimes and not others it was working fine for the last week and a half and now it didnt work at all. ussauly it well just all of a sudden turn on with in the first couple minutes of driving and once it works it never stops even if i stop for a while then the next morning it wont, and the tranny is in good condition
    now it doesnt work at all ever
      bump, know the odometer works all of the time but the speedo does not, could the speed sensor cause this, or is it more then likely the speedometer?
        post on 240 forums and shit...more than likely one person at least has had the same problem
        • ticklemedalyT Offline
          ticklemedaly
          your looking at a speedometer proplem. Both the odo and speedo use the same sensor to determine their output values. If the odo is working fine, and the speedo is irratic, youll need to look into replacing that.
          Ry
          XBL G-tag: TickleMeDaly83
            i did they seem to think that i have a hud and stuff related but if i dont figure it out soon ill do it again, im going to go back through and double check every wire and ground and connection in the next week as i work on illeminating all the extra wires
