  4. thinking about buying a domestic...
43 Posts 22 Posters 2.1k Views
    I know everyone thinks I can't hold onto a car, but i stumbled on something i dont know if I can turn down...
    I would keep my civ as a DD and put off the boost project.
    "Well, looks like it's time to sell one of my Toys. I have lot's of pics and will provide as much info as possible.
    It's an 88 Mustang Coupe with a 2.3T swap.
    5 Lug Conversion with 17" Bullits. 5 speed with LA3 Computer.
    .60/.63 T3, Stinger Header, 3" from Turbo to rear bumper (with a 3" cat) and from turbo to Throttle Body, Gutted Upper/Knifed-n-Ported Lower, 65mm Throttle Body, 31x24x3 Front Mount, Blow-Off Valve, Adj. Pressure regulator, manual boost controller, 190LPH in-tank, 3 core radiator and SN95 95 controlled by a Ford CCRM (no stupid toggle switches need to switch fan from lo to hi) 130 amp Alternator
    Everything in this car works! A/C, PowerSteering (has the infamous Ford "whine" ), brakes. Hell, the Cruise Control even works! Idles rock solid at 950 and pulls a solid 16" of Mercury all day long. Does not run hot, doesn't die when coming to stops, doesn't smoke, doesn't hesitate, pulls hard through all gears.
    Front Struts less then a year old. Rear Shocks a little over a year. New master cylinder for breaks and new slave and master on clutch. Could use some bushing in the suspension (have never been changed) and that would be a nice addition.
    Passes Texas Emissions with room to spare (have Test Results from past 2 years) and all tags are current
    I always hated the radio set-up in Foxes. The radio is behind the shifter. I moved the HVAC controls down to that spot and put the radio where the HVAC was. It's an Alpine 6025
    Built fiber glass pods for the doors to house 6.5" driver on each door. Also, next to each door pin, is a LED for the alarm, showing it's status when armed.
    http://home.earthlink.net/~te_n_me/images/New%20Folder/P1010380.JPG
    In the trunk is a fiberglass enclosure housing a 12" Kicker Solobaric. It's built in the driverside cubby hole, so no real trunk real estate was lost.
    http://home.earthlink.net/~awsomalx/images/Lil%20Red/Trunk.jpg
    Changed the front seats and they feel/support light years better then the stockers
    http://home.earthlink.net/~te_n_me/images/New%20Folder/P1010381.JPG
    Oh yeah, the pic above shows the motor set-up with the VAM in "Blow_Thru" which worked out just fine in my car (not a single problem). I currently have the meter back in front of the turbo
    http://home.earthlink.net/~awsomalx/images/Lil%20Red/ngyn.jpg
    The reason for the change was noise! The damn Blow-Off valve is freakin too loud for my taste. So I plumbed it back into the VAM air piping. It's quiet and I don't feel any loss in power. I will however provide the piping to convert it back to blow-hru (I'll help the buyer do it, shouldn't take more than a half hour). I found it "ricey" (damn thing releases air whenever you shift, very annoying after a while).
    The only real change I'd do to this car if I were to build one again is the rear gears. I'd go with 3.27 as opposed to the 3.73 that currently reside in it now.
    Outside of that, it's a great little car, for being an 88.
    $2800 OBO
    Fixed picture links for trunk and dash."
    What are your thoughts?
      do it up mang.
      Looks like a little front end damage, but overall the car looks to be in great shape. It does have stock tires on the bullitts though, so you will need a set soon if you know what I mean. 😄
      The 2.3T is a stout motor and will take a helluva beating.
        This thread will be handy in a month when you decide to sell the car. Cut & paste and you're done! Just giving ya shit but that would be a cool car!
        • ErikE Offline
          ErikE Offline
          Erik
          Hahahaha.
          Total grip!
          They call me, old man...
            shut up jason, I know I have a problem, thats the first step, isn't it?
              better ditch your honda hat for a mullet.
              • camzaro28C Offline
                camzaro28C Offline
                camzaro28
                better put down the budlight and get some old milwaukee.
                might be time for a change, GL if u do buy it
                jig 4 prez
                  damn u brian reading my myspace!
                  also, i asked the guy but got no reply about this, u think this thing would be able to run a 13?
                  • ticklemedalyT Offline
                    ticklemedaly
                    nicely put.
                    Ry
                    XBL G-tag: TickleMeDaly83
                      Time to be another slack jawed mustang owner. :lol:
                        chris, u know what these things are capable of when lightly modded? i have no idea what i should expect from it.
                          It will be a hell of a lot faster then your broken d15 civic, lol.
                            no VTEC = gaysauce 😛
                              schells gay, ask him.
                              • NickBN Offline
                                NickBN Offline
                                NickB
                                I second that.
                                  dude, mike's wife is hot, so he's got a really good cover up or something. however he is curently canadian so icant say much other good for him...
                                  • StangerBanger96S Offline
                                    StangerBanger96
                                    Joel your best bet would be to look around here:
                                    http://forums.stangnet.com/forumdisplay.php?f=137
                                    to find out about 1/4 times and such.
                                      Heh. It will be for sale in a month BROKEN.
                                        i dont see your car fixed at all? i hate the fact that people give me a rep for breaking cars when the only thing that ever broke on me was my hatch. and that totally was not my fault.
                                          i dont think gsr's even seen his car since teh day it broke.
                                          he's just tryin to become the next john daly
